Old 13-07-2010, 04:49 PM   #1 (permalink)
Cool help needed to connect lcd tv with hdmi...?
Hi guys..,hope to get my psu tommorow. I.e. The burnt cm xtreme 600w..' but I will b replacing it with a vx550..'
Now guys I have bought a Hdmi cable to connect it with my 32 inch lcd tv.. But here r few ques..'
First of all my mobo has a Hdmi output and built in Hd 4250..,will it suffice in 32 inch lcd if connected through Hdmi..'secondly will Hdmi work better than vga..lastly I have a 5.1 ch speakers and its connected with the mobo sound card..,if I connect the mobo with Hdmi cable will the audio pass In the tv speakers..or only video will pass..?
Guys I know this sound little noobish but have no idea of Hdmi cables rather than vga or dvi..' thnkz in adv..'
Arnab boss is offline   Reply With Quote
Old 14-07-2010, 12:30 AM   #2 (permalink)
Default Re: help needed to connect lcd tv with hdmi...?
Guys I'm waiting...'
P2 x4 955 B.e,ga880gm-usb3,corsair 6gb,tx650,sea 1tb+500*2,cm690 with 7 fans 120mm,curve 2000 and mx518,sony &hp optical drive,sunbeam cold cathode*2 & bubble lights,benq g2222hdl.samsung 32"full hd.
Old 14-07-2010, 10:14 AM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
your board will handle the LCD but will not support games @ 1080p.
HDMI is always better than VGA (HDMI = Digital / VGA = Analogue)
Couldn't understand your last question. But the HDMI will pass sound in the TV Speaker.
VarDOS is offline   Reply With Quote
Old 14-07-2010, 12:04 PM   #4 (permalink)
^^ thnkz 4 help..'
Last ques was abt the audio as Hdmi transfers both audio and video through same cable so I am confused abt the audio output..I mean the audio will come from home theater or tv speakers...?
As my home theater is connected with motherboard sound card jacks..so If I connect Hdmi cables will it also take the sound along with video..' In tv speakers..? As I want only the video to b transferred in Hdmi...?
Old 01-08-2010, 10:52 PM   #5 (permalink)
hi guys.., as i suspected the same thing happened after i connected my lcd tv with hdmi cable...? the sound travels in my tv speakers and connot reconize my home theatre system...!!
now if i install a sound card will this problem would b solved..?
help me guys...
Old 02-08-2010, 12:26 AM   #6 (permalink)
dissel's Avatar
I think there must be setting like HDMI-HDTV (audio enabled) and HDMI-HDTV (audio disabled).
as u don't want to send audio to the tv choose the latter one.
it must be in the ATI control panel for you case.
as mine is Nvidia Control panel --->Display--->Change Resolution
dissel is offline   Reply With Quote
Old 04-08-2010, 11:16 AM   #7 (permalink)
Cool Re: help needed to connect lcd tv with hdmi...?
hi guys..got the solution for this problem..
it was in the realtec audio enhancer program..it had a option of audio output and i chosse speakers in place of hdmi..it worked..
now i am watching hd movies in 32 inch full hd tv with digital dolby surround sound effect in my living room...!!!
thanks dissel for ur info and @mods close this theard as my mission is accomplished....
DVI to HDMI : Any Improvement ??? bajaj151 Hardware Q&A 8 13-07-2010 10:09 AM
22" lcd monitor kartikkapo Hardware Q&A 30 24-06-2010 12:59 PM
LCD (Samsung or Dell) y2j826 Hardware Q&A 13 05-06-2010 06:53 PM
howz this LCD TV ?? sharma_atul85 Hardware Q&A 0 11-05-2010 07:34 PM
Multi Screen setup needed arpanmukherjee1 Software Q&A 0 06-05-2010 12:39 PM
- by kool
- by ax3
