1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:basic gaming . internet , n watching hd movies
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:yes
3. What is your MAX budget?
A:20000
4. Planning to overclock?
A:no
A:windows 7 64 bit or wind xp
A:500gb
7. What resolution will the screen run at & whats the size of the screen you want?
A:i guess i dont hv a good idea abt dis but u can decide it 4 me
A:6
A:yes
A:in a week
A:
A:no include every thing
A:mumbai yes ill buy it 4rm lamington rd
A:see if you can fit a graphic card
n give me a conf with and without gpu
