10-07-2010, 08:59 PM
android lover
want advice on rig around 20k
Hi,friends my name is kamal . Its my first thread . I just want you guys to help me to buy a pc for 20k. Its my first pc.Want to get it with AMD processor.So please give your valueable time to query.
1. What is the purpose of the computer? A:can go for any processor, Games,internet,movies,music
2. What is your MAX budget? A: Around 20 k. I did like if I would get something good at a lesser budget. 3. Planning to overclock? A: No 4. Which OS are you planning to use? A: Windows 7 64 bit / windows xp 64bit
5. How much hard drive space is needed? A: 500 GB HDD
6. What resolution will the screen run at & whats the size of the screen you want? A:whichever possible want to purchase 19" lcd
8. When are you planning to buy the system? A: Within a week maybe or maybe I' ll give it some more time
9. Are you one of the types looking out for "future proof" configurations? A: Yes
10. Are there going to be any components that you don't want to include in this new rig? If yes, do mention. A:yes,ups already have interverter at home.
11. Mention any other points if deemed necessary A: I would like a onboard gpu near about 512MB Memory.
12.From where you are going to buy . A:Ludhiana,punjab
13.Any other query ? A: want to get creative speakers.What i can survive without speakers if die die situation in budget.
10-07-2010, 09:23 PM
Re: want advice on rig around 20k
Athlon II X3 435 2.9GHz @ 4k
Biostar TA785G A3 @ 3.7k
2GB DDR3 1333MHz @ 2.6k
Samsung 500GB SATA @ 1.9k
LG H55N DVD @ 1k
Local Cabinet + 400W VIP PSU @ 1.6k
DELL/AOC 16" Monitor @ 5k
Logitech Keyboard & Mouse @ 0.7k
Creative SBS A200 @ 1.3k
Total - 21.8k
10-07-2010, 09:26 PM
The Assassin
Proccesor : AMD athlon ii x3 435 - 4k
Motherboard : Biostar 785G3 HD - 4k
RAM : 2 GB DDR3 1333 MHz - 2.5k
HDD : WD caviar blue 500 GB - 2k
Cabinet - local cabby - 0.3k
SMPS - FSP Saga 350W - 1.5k
ODD : Samsung/LG/Sony DVD Writer - 1.2k
Total 16.2k
Not sure about monitor
An inverter is not a UPS, if there is fluctuation or power cut inverter takes too much time to switch on as compared to UPS. Therefore, your PC will first lose its power and then get power from the inverter whereas a UPS will not allows your PC to lose its power
10-07-2010, 09:30 PM
LG H55N DVD @ 1k
Total - 21.8k
good try jas but 20k & gaming. seriously. not possible.
1. a VIP 400W PSU cost ~1.5k.
2. 16" too much small.
3. better settle for some cheap speakers.
10-07-2010, 09:32 PM
some amount of gaming will be possible with hd4200 and x3 2.9ghz sam
i could not find a budget 19" monitor...suggest please
10-07-2010, 09:37 PM
yes i know but i meant 15" too small for any gaming. in 20k, if one want gaming, he/she must have monitor already. else it'll have bad affect on pc specs immediately.
10-07-2010, 10:27 PM
android lover
LG H55N DVD @ 1k
Total - 21.8k
if i just leave speakers then can i go for dell 19" lcd and also please only 20k . My parents will not allow a single penny more than this but i can upgrade it later in 1 month or 2 months
---------- Post added at 10:26 PM ---------- Previous post was at 09:57 PM ----------
Can i go for AMD X2 series processors if yes then advice a good one please.
Is there any other thing that we can leave now but in next few months i will add that. Then i can go for good system. And also please tell the price of a computer table or give any alternative to it.
---------- Post added at 10:27 PM ---------- Previous post was at 10:26 PM ----------
11-07-2010, 11:13 AM
Biostar TA785G3 @ 3.7k
LG H55N DVD @ 1k
Local Cabinet + 400W VIP PSU @ 1.8k
Dell 19" IN1920 Wide Screen LCD @ 6k
total - 20.7
11-07-2010, 05:24 PM
android lover
LG H55N DVD @ 1k
total - 20.7
Can i go for AMD X2 series processors if yes then advice a good one please. Is there any other thing that we can leave now but in next few months i will add that. Then i can go for good system. And also please tell the price of a computer table or give any alternative to it.
11-07-2010, 05:27 PM
better get x3 series...get zebronics bijli with bundled psu @ 1.5k instead of Local Cabinet + 400W VIP PSU @ 1.8k
12-07-2010, 09:06 PM
android lover
Can i play god of war 3,igi,assanins creed 2,mafia 2 at good settings on jaskanwar bros configuration
12-07-2010, 09:37 PM
Wise Old Ghoul
lets say
1024 resolution low-medium settings
and
800 resolution medium-high settings
12-07-2010, 09:52 PM
GOW3 ---> PS3.
IGI --> max out. highest resolution & settings. will get 100+ FPS.
Assassins Creed 2 ---> full resolution, lowest details or vice versa.
mafia 2 ---> as not yet released. can't say.
13-07-2010, 07:25 AM
android lover
Check jaskanwar bros configuration there is a mistake in sum total it is 21.7k not 20.7k so please solve it pull it to 20k
---------- Post added at 07:24 AM ---------- Previous post was at 07:22 AM ----------
Pull it near to 20k otherwise jaskanwar bros configuration is good . I will go with it.Is that mobo he suggested is also compatible with athlon x2 series if not please suggest a biostar mobo.
---------- Post added at 07:25 AM ---------- Previous post was at 07:24 AM ----------
13-07-2010, 09:02 AM
oops i made a mistake
its 21.7k
14-07-2010, 08:32 AM
^ @clshoe031
wtf is this?
Q9550+GA-EP45-UD3L+4GB CORSAIR DDR2 800FSB+XFX GTS250 1GB+250GB SATA+CORSAIR VX450+CM V8+ASUS XONER D2+SATURN+LGDVDRW+CREATIVE 5.1 INSPIRE+500GBX6 FREE GO AGENT+RAZER MOUSE+DELL LATITUDE 6400.
14-07-2010, 08:33 AM
recently i have seen many unusual posts like this.....whats happening i dont know.........
14-07-2010, 08:37 AM
^^This is very wrong. in my option this is the only forum in India which has some of the most talented guys all over India at one place.I dont understand why few people spoil the flavor of this forum.
14-07-2010, 11:14 AM
#19 (permalink)
whts very wrong???
my post or what clshoe31
14-07-2010, 08:45 PM
#20 (permalink)
laborare est orare
whts very wrong???
Obviously yours.
By the way, for monitor go for AOC 19" monitor, available at 5.4k in Kolkata. They are some great VFM monitors available. I have two of them, one 19" and one 16"
Guys spending 4k for an X3 is seriously not a good choice. Ask the OP to increase his budget to few hundred bucks to get a Athlon II X4 630 at 4.6k.
My suggestion will be
Athlon II X3 425 2.7GHz @ 3.5k
2 GB Kingston DDR3 @ 2.6k
500 GB HDD @ 1.9k
AOC 19" monitor 5.5k
Biostar TA785G3 HD @ 4.3k
LG H55N DVD @ 1k
Local cabinet @ 0.7k
Any good Local 500W/600W SMPS (FOxin) @ 0.6k
Guys, these local psu will be able to run upto 9600 GT or HD 4650. I tested the Foxin 500W with HD 5650 and 9500 GT.
Total is around 20.8k. Now the Street price of CPU and processor are little less. So best of luck to get everything within your budget.
By the way, this is not at all my suggestion at all. The credit goes to Jaskanwar Singh. I just modified some components.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
14-07-2010, 08:53 PM
#21 (permalink)
its a bot
Originally Posted by Cilus
15-07-2010, 05:45 PM
#22 (permalink)
android lover
Hello guys ,sorry for not replying. Yesterday i went to our local market to know the price of configuration you provided me.
I came up with this price list:
Athlon II X 3 435 2.9 GHz @ 4.2 k
Biostar TA785 G3 @ 3.5 k
2 GB DDR3 1333MHz @2.1 k
HDD 500 GB SATA @1.9k
LG H55 N DVD @0.95 k cabinet @1.2 k Dell 19 " IN1920 Wide Screen LCD @ 6k Logitech Keyboard & Mouse @0.350 k
total :20.2k
so is it worthy and also i did not bargain. i am thinking that i can bargain upto 1k on whole system.
15-07-2010, 06:58 PM
#23 (permalink)
absolutely fine
which brand of ram???
15-07-2010, 07:41 PM
#24 (permalink)
laborare est orare
When you are spending 4.2k, just spend a few hundreds buck more to get a Athlon II X4 630. It is currently having street price 4.6k to 4.9k. Try to get this one.
The gaming performance increase will be marginal (or not at all ) but performance increase in multi-Threaded application will be great and it is a better future-proof solution.
15-07-2010, 08:00 PM
#25 (permalink)
Jaskanwar can you please suggest a value graphics card for your configuration.
A computer once beat me at chess, but it was no match for me at kick boxing.
15-07-2010, 09:35 PM
#26 (permalink)
android lover
ok i will try to get that. Also one more thing . I am going to buy these things after 1.5 months. So is there will be any price decrease in rate list.
---------- Post added at 09:35 PM ---------- Previous post was at 09:31 PM ----------
absolutely fine
actually brother i forgot to ask about brand of ram to dealer.I will post it soon.
16-07-2010, 08:31 PM
#27 (permalink)
android lover
Hello guys please can u suggest a good hd lcd in 6.5k
16-07-2010, 09:05 PM
#28 (permalink)
Wise Old Ghoul
^^AOC brand to go for
otherwise DELL 20" is available at 6.5k
22-07-2010, 10:25 PM
#29 (permalink)
android lover
Hello friends . Today i am surfing internet to find a good lcd and i find that there are near about two choices . first is Dell st2010 and second is samsung 2033 sw so please tell me which one to get . Personally i liked that dell one its having hdmi port and also if i connect hdmi port of motherboard to monitor's hdmi port then will all things in high defination.
23-07-2010, 09:37 PM
#30 (permalink)
Wise Old Ghoul
whats the budget?
and ur requirement?
