Old 10-07-2010, 01:24 AM   #1 (permalink)
Arrow Suggest me a pc around 20k ..the max i can get :)
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: gaming,study,all i can do...max use
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A: around 15k
4. Planning to overclock?
A:yes
A:7 or more in future
A:500gb or better
7. What resolution will the screen run at & whats the size of the screen you want?
A: can say ..if my budget exceeds i will buy screen later
A:4
A:i will assemble my self
A:2-4 day from nehru place
A:yes
A:
A: delhi
A:
Hi everyone..new to this forum my friend suggested me this one...
please suggest me a pc around 15k ... the best i can get as i m planning to do evrything including games
i live in delhi so can easily get all hardware from nehru place...
suggest me a shop too if u know any so tht i can get all easily...
w8ing for u r replies..
tarunjain07 is offline   Reply With Quote
Old 10-07-2010, 07:50 AM   #2 (permalink)
bORn To RIse....
rahul.007's Avatar
Default Re: Suggest me a pc around 20k ..the max i can get :)
get this:-
Athlon II X3 435 2.9GHz @ 4k
Biostar TA785G3 HD @ 4.1k
kingston 2GB DDR3 1333MHz C9 @ 2.6k
Seagate Barracuda 7200.12 500GB @ 2k
Zebronics Bijli @ 1.1K
FSP Saga II 350 Watts @ 1.7k
lg dvd sata @ 1k
logitech mult. keyboard + value optical mouse @ 0.65k
samsung 17/19" (whichever available at 5.5k) @ 5.5k
total:-23k
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline   Reply With Quote
Old 10-07-2010, 09:06 AM   #3 (permalink)
Jaskanwar Singh's Avatar
this will be more than enough--
Athlon II X4 635 2.9GHz @ 5k
Biostar TA785G3 HD @ 4.2k
2GB DDR3 1333MHz @ 2.6k
Samsung 500GB SATA @ 1.9k
Local Cabinet + 350W psu @ 1.5k
Dell/AOC 16" Monitor @ 5k
Total - 20.2k
Jaskanwar Singh is offline   Reply With Quote
Old 10-07-2010, 11:48 AM   #4 (permalink)
^^ jas pc config better & cheaper.
Old 10-07-2010, 12:44 PM   #5 (permalink)
thnxs guys for such a mind blowing an quick replies
edited :- budget is 15k
please suggest me one around 15k(please try to stick to 15k only)
thnxs Jaskanwar Singh
rahul.007
Old 10-07-2010, 12:51 PM   #6 (permalink)
^^ inc monitor?
Old 10-07-2010, 12:57 PM   #7 (permalink)
nopes 15k excluding ups,monitor,keyboard -mouse etc
15k only for cpu
Old 10-07-2010, 01:34 PM   #8 (permalink)
than take jas config. remove monitor. total pricing will be at 15-15.3k. i doubt you will find a better config at that price.
Old 10-07-2010, 04:14 PM   #9 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Total - 20.2k
There is a hidden danger in this config.TA 785G3 HD comes under medium range boards.So local SMPS will be a risk.Biostar people enquired about my PSU when I bought this board.
get
Athlon II X4 630 @ 4.7k
AOC 15.6" @ 4.7k
FSP Saga II 350W @ 1.5k
Local cabby
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 10-07-2010, 07:42 PM   #10 (permalink)
The Assassin
Cybertonic's Avatar
WD Caviar Blue 500GB SATA @ 2k
Local Cabinet - 0.4k
FSP saga 400w @ 1.8k
Total - 15k
For the monitor, zebronics 17" flat CRT is available at 2.5k
(by http://www.bwindia.net )
Cybertonic is offline   Reply With Quote
Old 10-07-2010, 07:59 PM   #11 (permalink)
get
AOC 15.6" @ 4.7k
Local cabby
really? that nice to hear that even for 4-4.3k you get a good board
Old 10-07-2010, 08:29 PM   #12 (permalink)
cybertonic a 17"crt and 400w for that rig....ahmmmmmm
Old 10-07-2010, 08:52 PM   #13 (permalink)
not able get you
Old 10-07-2010, 09:27 PM   #14 (permalink)
oh ho sammy yar...i meant that was too much for the psu and a crt if lcd was in his budget...
Old 10-07-2010, 09:36 PM   #15 (permalink)
well yes. LCD should be considered over CRT even if budget it very very low. CRT in 2010. its like a super ROFL
Old 12-07-2010, 05:29 PM   #16 (permalink)
bought :
AMD X4 635
Asus M4A88T-M/USB3
WD 500Gb
2Gb DDR3 Dynet
Cooler Master PSU : 500w
Zebronics blaze..
Lg Dvd
Total : 19900
Delhi : Np Bee Kay Computers next to cost to cost
hwz it ?
Old 12-07-2010, 06:16 PM   #17 (permalink)
should not have brought Asus, dynite & CM, assuming its Extreme Power or derivative.
anyway congrats on the purchase. check the motherboard well well.
Old 12-07-2010, 07:01 PM   #18 (permalink)
bORn To RIse....
rahul.007's Avatar
bought :
AMD X4 635
Asus M4A88T-M/USB3
WD 500Gb
2Gb DDR3 Dynet
Zebronics blaze..
Lg Dvd
Total : 19900
hwz it ?
you should have gone to smc....
and no to cm extreme power and dynet....
but nevertheless ts a good purchase....
Old 12-07-2010, 09:42 PM   #19 (permalink)
Wise Old Ghoul
Piyush's Avatar
@OP
overall a nice purchase but asus 880.....is overpriced and could have been swapped with MSI/GIGA
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 13-07-2010, 01:00 AM   #20 (permalink)
went to smc..he was also offering cm not saga...
dynet i bought bcoz my direct warranty is from the shop keeper i don have to go to any service centre...
Asus yaar i went their no one was offering SAGA ....
Suggest AMD rig worth 20k urgent!!!! Vensanga Hardware Q&A 18 10-07-2010 01:10 PM
Suggest how to start with Microcontroller Electronics hotshot05 Chit-Chat 1 28-06-2010 06:33 AM
Suggest a PSU... Swift Hardware Q&A 43 22-06-2010 10:27 PM
suggest a mouse within rs 1000-1500.. himadri_sm Hardware Q&A 4 18-05-2010 06:57 AM
Suggest me some games ajai5777 Gamerz 7 23-04-2010 02:53 PM
- by kool
- by ax3
