Old 09-07-2010, 11:21 PM   #1 (permalink)
heartripple's Avatar
Arrow Need Help to decide new system.......
Hi guys.....
My 4 years old system is dying now.First of all my onboard graphics card is not usable for months..then usb devices stopped detecting and now cpu fan error come each time I turn on my system....So I am looking to buy a new system....
I have 50k of budget And I want Motherboard,processor,Ram,cabinet......
I want Intel i7 rig...with Asus motherboard and 4 gb DDR3 Ram.....So guys suggest me some choice.....
Thanks in advance
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout ||
Nokia N-8, Sony Ericsson C905 both rocks my world...
heartripple is offline   Reply With Quote
Old 10-07-2010, 01:18 AM   #2 (permalink)
Default Re: Need Help to decide new system.......
whats your existing system? cause you may also need change PSU & will need graphics card as well. also what is the use of your system?
Old 10-07-2010, 10:01 AM   #3 (permalink)
Jaskanwar Singh's Avatar
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
Jaskanwar Singh is offline   Reply With Quote
Old 10-07-2010, 02:53 PM   #4 (permalink)
Cool Re: Need Help to decide new system.......
Well I have EVGA 9800gtx and CM True power 600 watts smps . And 320+750 gb wd hdd so no need to change dis stuff.
Old 11-07-2010, 12:01 AM   #5 (permalink)
Question Re: Need Help to decide new system.......
A:
A:
A:
A:
A:
A:
A:
A:
A:
A:
A:
A:
A:
A:
1) Gaming and animation
2) Yeah
3) 50k
4) Yeah
5) Windows 7 Ultimate
6) No Hard Drive needed
7) I will use my current crt display
8) 7
9) Yeah
10) In this month
11) Yeah
12) SMPS,KeyBoard and Mouse,Monitor,Graphics card,Hard Drive
13) Surat-yeah
Old 11-07-2010, 01:26 PM   #6 (permalink)
Unhappy Re: Need Help to decide new system.......
No suggestions......
Old 11-07-2010, 02:38 PM   #7 (permalink)
Intel:
Core i7 930 + MSI X58 Pro + 6Gb DDR3 from Corsair/S.Skill or Muskin. performance ram: 33.5k
AMD:
AMD Phenom II X6 1090T + MSI 890FXA-GD70 + 4Gb DDR3 value/performance ram from same: 31k.
Cabinet: NZXT M59 @ 3.8k (if you want simple but uncommon. but extra fans necessary)
Cooler Master HAF 932 (full tower)
also get a CPU cooler. i don't have much idea about which one is good & compatible with either AMD & Intel.
Old 11-07-2010, 02:50 PM   #8 (permalink)
pulsar_swift's Avatar
What is this CM True Power ? Is it real power pro ?
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 11-07-2010, 03:54 PM   #9 (permalink)
check your psu once again
never came across cm true power, is it extreme power?
Old 11-07-2010, 04:47 PM   #10 (permalink)
only Antec have TruePower series of PSU.
Old 11-07-2010, 09:16 PM   #11 (permalink)
Sorry......Its Extreme Power.....
---------- Post added at 09:16 PM ---------- Previous post was at 09:10 PM ----------
Intel:
AMD:
I think Asus Rampage II Gene would be great choice...because I am planning to over clock .
And I would prefer Thermaltake Armor + or Kandalf cabinet......
Old 11-07-2010, 10:01 PM   #12 (permalink)
first wait!!!
change that dangerous psu - Corsair VX550W @ 4.7k
Old 11-07-2010, 10:37 PM   #13 (permalink)
upgrade your PSU before you plan any thing.
Old 11-07-2010, 10:56 PM   #14 (permalink)
both jas & pulsar have already put forward their suggestion. so i won't repeat.
for OC, you have other options. but going for Asus can be a little bad move. 1st. nowadays Asus is having a hell lot of issues. & Rampage series is no different. 2nd. let whatever reviewers tell, its mATX & it isn't a good choice. get ATX motherboard. also other motherboard priced in same range excel in OC. look out for EVGA X58 FTW3.
but if you want something thats best in OC. get Biostar.
about the cabinet, yes Armor+ is a good choice. but instead of Kandalf you can settle for NZXT's top of line cabinet. but all depends on personal choices.
Old 11-07-2010, 11:45 PM   #15 (permalink)
first wait!!!
Buddy my psu is absolutely fi9...I have overclocked my Graphics card and processor and also I am using 2 hdds ...I didnt ever face problem .....
---------- Post added at 11:45 PM ---------- Previous post was at 11:35 PM ----------
Kadalf is Liquid cooled cabinet.......
Where to find NZXT products in India...Suggest me some cabinets from that......
And also tell me what if I settle for Armor and Cooler master's liquid cooling system???????
Say something about this.
Old 12-07-2010, 06:16 PM   #16 (permalink)
that book is somehow interesting as it provides me some useful background knowledge.
brayanaustin is offline   Reply With Quote
Old 13-07-2010, 09:13 PM   #17 (permalink)
Now what's this?
Old 13-07-2010, 10:52 PM   #18 (permalink)
just when you look away, trouble will strike. don't take the risk. change that PSU. or use it at your own risk.
will you go for liquid cooling? all NZXT cabbies comes with pre drilled holes for liquid cooling.
can go but i'll suggest get NZXT M59 (or some other derivatives) + a good air cooler. liquid cooling will bring in lot of hassle. if you ready to accept the increased hassle, can go ahead. BTW, which CM liquid cooling kit you have decided to move to?
Now what's this?
spam
Old 14-07-2010, 09:05 AM   #19 (permalink)
spam
so I would have to change my psu.....well I was thinking to change my psu and graphics card by the end of this year.....neways...then suggest my a psu with 700watts bcause I have planned to do crossfire or sli ........
I want full tower cabinets only.....One of my friend has Cooler Master Cosmos cabinet...he opted for 3rd party heatsink and fan... Now he is facing problem ...the heat sink is huge enough to cool down cpu but it touches the side panel of cabinet.....so his cabinet is open......Thats why I am thinking of liquid cooling system
I dont know much about liquid cooling systems....
Old 14-07-2010, 09:19 AM   #20 (permalink)
CORSAIR TX650 should be enough to drive your setup. TX 850 will be MACHO. One of the forum members Asigh is using a Noctua DH14 in his CM 690. I think that HSF will be enough for yours as well. For the cabinet you can look at HAF mid tower
Old 14-07-2010, 11:13 AM   #21 (permalink)
yup corsaitx650w is enough for croosfire.
Old 15-07-2010, 01:02 AM   #22 (permalink)
Techie By Heart
mavihs's Avatar
first of all you have way less budget for all the H/W you want!
2nd i would tell you to go for the AMD setup as it'll provide better rendering in Animation!
3rd a good/decent Liquid cooling setup will cost you around 15K!
4th change that SMPS, its blow/burn/fry your comp as your going for high end components! (Wattage doesn't matter, its the effieciency & the quality of the SMPS which matters)
5th for OCing go for a good HSF like Venomous X (cost 4.7K with brackets). Also a full tower will be good for you but it'll cost 8K+!
Are you learning Animation for doing it as professionally?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 15-07-2010, 04:59 PM   #23 (permalink)
Smile Re: Need Help to decide new system.......
I know my budget is very less for all these stuff..
I would go for i7 ....
I will buy liquid cooling system later..
Old 15-07-2010, 06:29 PM   #24 (permalink)
Techie By Heart
mavihs's Avatar
any reason you want to go for i7?
you didn't answer my last question!
Old 17-07-2010, 04:04 PM   #25 (permalink)
This time I wanna try Intel...
I think my friend has same HSF....and he is not satisfied with that product....
Are their any copper based HSF available?
Linux is a doomed operating system; here's how you can save it xitij2000 Open Source 30 15-07-2010 05:24 PM
Computer restarts GEEKCOMPUTER_GEEK Software Q&A 6 23-06-2010 02:30 PM
Unleash the Power of Ubuntu 6.06!! JGuru Open Source 72 06-12-2006 10:45 PM
Very Strange Problem!!! shivaranjan.b QnA (read only) 1 15-06-2005 09:00 PM
- by kool
- by ax3
