Old 09-07-2010, 12:05 PM   #1 (permalink)
prateek007391's Avatar
Default HP Officejet J3608
I recently bought a HP Officejet J3608 All in one Printer.
Earlier I was searching on internet, and found Officejet J3680 All in one and all its features were good, and the most impressive features was that it uses the same cartridges as my old Printers HP D1460 and HP F370 i.e. 21 and 22 no. Cartridges.
However when I ordered the product, the shop owner gave me J3608 instead of J3680 and I found both of them similar
Later on unpacking and assembling I discovered that J3608 uses 702 black cartridge instead of 21 no. Black Cartridge
The rates of 21 and 702 has a very wide gap and I would like to know can I use 21 no. Cartridge in J3608 or not,
every time I insert my old cartridge whether it be 22 or 21 it always says the cartridge is not intended to be used on this printer
prateek007391 is offline   Reply With Quote
Old 11-07-2010, 05:33 AM   #2 (permalink)
Default Re: HP Officejet J3608
No, you can't.
HP Officejet 4355 All-in-One... sam9s Reviews 2 25-08-2010 04:08 PM
HP Officejet 5610 or 5680 sachin_kothari Hardware Q&A 1 06-10-2007 02:47 PM
Which All in One FROM :Canon Pixma MP 150/HP Deskjet F380 AIO/HP Officejet 4355 AIO jiteshbhimani Software Q&A 1 17-09-2006 12:57 PM
- by kool
- by ax3
