View Poll Results: WHICH MOTHERBOARD IS BEST?
ASUS M4A785D-M PRO 0 0%
GIGABYTE GA-MA785GM-US2H 0 0%
Voters: 0. You may not vote on this poll
Old 09-07-2010, 06:37 AM   #1 (permalink)
Default Is Asus M4A785D-M Board is better than Asus M4A785-M
Hi All!
Please tell me which one is better among ASUS M4A785D-M PRO adn GIGABYTE GA-MA785GM-US2
Please cast your vote and tell your opinion
Thanks
prakum is offline   Reply With Quote
Old 09-07-2010, 09:21 AM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Is Asus M4A785D-M Board is better than Asus M4A785-M
avoid asus
are you building a new pc, if so give your budget and purpose...
Jaskanwar Singh is offline   Reply With Quote
Old 09-07-2010, 10:33 AM   #3 (permalink)
^^ yup. avoid Asus at all cost.
Old 09-07-2010, 09:48 PM   #4 (permalink)
Swimming, eh??
toad_frog09's Avatar
ok, i am lazy a$$ here, didnt want to make new thread. so reading all the posts bout asus,
I thought to get my mobo changed.
Its m4a78tdv evo, if you remember.
So i just want your quick hands off advice, what eva you say, your word...' whats the best ddr3 mobo, worth getting over evo, with two pcie2.0 slots at 8x/8x, under the budget of 6.5-7k.'
toad_frog09 is offline   Reply With Quote
Old 09-07-2010, 10:00 PM   #5 (permalink)
but why? if you not going for Xfire & your board isn't showing any "super odd" problem, stick to it.
anyway for 6.5-7k, with X8+X8 Xfire, you have an AsRock 785G based mobo. full name forgotten. can check MSI 790GX mobo. it should come a bit cheap now. Gigabyte will be costly. Biostar don't have good one (only a single 790GX). & skip the rest like ECS, Foxconn, etc.
Old 09-07-2010, 10:04 PM   #6 (permalink)
pulsar_swift's Avatar
msi 890 gxm e65 - 7.2k
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 09-07-2010, 10:13 PM   #7 (permalink)
than 790GX definitely should be cheaper but i feel this mobo best value. Sata 3.0. USB 3.0. for less than 1k over the 790GX.
@OP, pulsar already highlighted a good deal. get it.
Asus board warranty avichandana20000 Hardware Q&A 3 30-06-2010 01:03 PM
Asus Immensity: ROG board with on-board HD 5770 mavihs Technology News 0 05-06-2010 02:06 AM
Can I use grfx cards in Asus P5KPL-AM IN SERIES Motherboard. kanhadey Hardware Q&A 5 14-05-2010 12:59 PM
Gigabyte 880GMA-UD2H Review The Sorcerer Reviews 1 13-05-2010 03:02 PM
- by kool
- by ax3
