Hi guys
1. What is the purpose of the computer?
A: General use mostly plus have to run stuff eclipse, visual studio etc. I dont play games at all.
3. What is your MAX budget?
A: Around 20k. I did like if I would get something good at a lesser budget.
4. Planning to overclock?
A: No
A: Windows 7 64bit / Linux
A: Already have HDD
7. What resolution will the screen run at & whats the size of the screen you want?
A: Already have a 22" samsung running at 1920 x 1080
A: Within a week maybe or maybe I'll give it some more time
A: Yes
A: CPU/MB/RAM/PSU/cabinet/UPS are the only things that I'm going to buy. All other components would be retained.
A: I would like a VFM system. so most probably a AMD unless something else good is available. And I wouldn't upgrade for like 3 years.
I'm thinking atleast a quad would be necessary. And 2GB might be good enough now, I could add another 2 later on. I'm more inclined toward those cheap PSU's as Im just buying a basic system with onboard GPU etc.
Please give me your suggestions. Thanks in advance
