Old 08-07-2010, 06:16 PM   #1 (permalink)
Am here for u
Vensanga's Avatar
Default Suggest AMD rig worth 20k urgent!!!!
Guys am planning to assemble a new system for a friend..will be using as a multimedia PC so please can u suggest a good configuration and the budget is 20k....if possible were in favour of the DDR3..will not be needing monitor(already have Samsung B2030) and Cabinet..
1.AMD Processor
2.Motherboard(with decent onboard graphics to play decent games)
3.Ram (2gb DDR3)
4.Smps (looking at CorsairVX 450)
5.HDD (looking at WD 500)
6.DVD Rom (around 1.2k)
Like i've said Monitor and Cabinet not required...Will be buying online from Lynx @ Chandigarh or Prime ABGB @Mumbai!!!
Acer aspire TimelineX 4820T, Nokia 5800XM
Vensanga is offline   Reply With Quote
Old 08-07-2010, 06:46 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: Suggest AMD rig worth 20k urgent!!!!
Processor - AMD Athlon ii x4 630 - 5k
Motherboard - Biostar 785G3 HD - 4k
RAM - 2*2 GB DDR3 - 5k
PSU - Corsair VX 450 - 4k
HDD - WD Caviar Blue 500GB - 2k
DVD Drive - LG/Samsung/Sony DVD Writer - 1k
Total - 21k
if you are on a really tight budget go for FSP Saga 500W for 3k
Cybertonic is offline   Reply With Quote
Old 08-07-2010, 07:36 PM   #3 (permalink)
Am here for u
Vensanga's Avatar
so if i stick with ur configuration will there be a problem is i wanted to buy graphics card in the future...the smps will be fine and will the processor and mobo be good enough???What about the Phenon processor???
Old 08-07-2010, 07:38 PM   #4 (permalink)
Jaskanwar Singh's Avatar
Athlon II X4 635 2.9GHz @ 5k
Biostar TA785G3 HD @ 4.2k
2*2 GB DDR3 1333MHz @ 5.2k
WD Caviar Blue 500GB @ 2k
LG H55N @ 1k
FSP saga II 400W @ 2k
Total - 19.4k
---------- Post added at 07:38 PM ---------- Previous post was at 07:37 PM ----------
which graphics card?
then change the psu to FSP saga II 500W @ 2.7k and the total cost comes to be 20.1k
Jaskanwar Singh is offline   Reply With Quote
Old 08-07-2010, 07:41 PM   #5 (permalink)
Am here for u
Vensanga's Avatar
will be purchasing a new graphics card in the future(may be 3 or 4 months from now)..the budget will be fine...
Old 08-07-2010, 07:46 PM   #6 (permalink)
i mean if you will go with HD5770 in the future then fsp 500w is fine.
but if you plan a hd5850 or something then corsair vx550w @ 4.7k.
Old 08-07-2010, 07:49 PM   #7 (permalink)
Am here for u
Vensanga's Avatar
HD5770 will be more than enough if the VX450 can handle it....he will not be gaming that much so 5850 will not be required...
Old 08-07-2010, 08:13 PM   #8 (permalink)
hd5770 will run good on fsp saga II 500w
although if you go with corsair vx450w then it will be very good.
Old 09-07-2010, 12:19 AM   #9 (permalink)
get from IT wares (mumbai) or SMC international (Delhi, best rates i ever seen. price inc of tax & carry charge). or Media Home (Delhi)
LG H55N @ 1k
Total - 19.4k
jas has already suggested a good config. don't so any experiment with his config. do change PSU according to this:
FSP Saga II 400W or Gigabyte 460W ---> HD5670.
FSP Saga II 500W or Corsair VX450W ---> HD5770.
Old 09-07-2010, 01:16 AM   #10 (permalink)
Am here for u
Vensanga's Avatar
i was wondering about the AMD Phenom II 555 BE,the Price is not that similar and what about MSI 785G-53 rather than Biostar...will stick with the Corsairvx450...
Lynx seems to be selling at the lowest prices as compared to others (dont know about the service though)...
Old 09-07-2010, 01:56 AM   #11 (permalink)
X2 555 is a dual core. better stay away from it. you can try unlock its extra cores but theres always a risk it won't unlock. if it fails to unlock, than you stuck. about the MSI board, check its pricing. if its high, skip it & instead get 8 series mobo.
Lynx pricing is excluding of tax & carry charge.
SMC ---> inc of tax & carry charge.
Prime, Media, IT & others ---> inc of tax only.
Old 09-07-2010, 09:01 AM   #12 (permalink)
Am here for u
Vensanga's Avatar
ok thnks alot for clearing that...here are my suggestion..
1.AMD Athlon II X4 635
2.MSI 785-E53
3.Corsair VS 1333Mhz DDR3 2gb
4.Corsair VX 450
5.WD 500 HDD...
will these configuration do????
Old 09-07-2010, 09:38 AM   #13 (permalink)
dude biostar mobo is excellent..spend the rest on ram as i mentioned..
Old 09-07-2010, 05:44 PM   #14 (permalink)
Am here for u
Vensanga's Avatar
ok then if i change the mobo to Biostar TA785G3 HD and the RAM to a better one it will be ok???
Old 09-07-2010, 07:53 PM   #15 (permalink)
dude i have already suggested you a good config....you just need to change the powersupply as sam suggested
Old 09-07-2010, 11:00 PM   #16 (permalink)
Am here for u
Vensanga's Avatar
wats wrong with Corsair 450...will be upgrading to 4gb and with decent graphics so i think the Vx450 will be more future proof....
Old 10-07-2010, 02:12 AM   #17 (permalink)
if you can include it within your budget, go for it.
Old 10-07-2010, 09:44 AM   #18 (permalink)
there is nothing wrong with corsair 450w
its the best if you can include it in your budget
Old 10-07-2010, 01:10 PM   #19 (permalink)
Am here for u
Vensanga's Avatar
thnks alot to u guys..will place an order ass doon as possible....
Gaming PC For 20K muraliand PC Components / Configurations 36 30-07-2010 12:31 PM
Very high end configuration rig needed..Please suggest kanishka PC Components / Configurations 179 14-07-2010 07:00 AM
Suggest how to start with Microcontroller Electronics hotshot05 Chit-Chat 1 28-06-2010 06:33 AM
Buy Rig In April doom2010 Hardware Q&A 11 09-04-2010 07:34 PM
Help to buy Amd 64 rig... akshayt CPU / Motherboards 12 11-10-2004 09:02 PM
- by kool
- by ax3
