Old 08-07-2010, 11:54 AM   #1 (permalink)
Swimming, eh??
toad_frog09's Avatar
Default M not sure where to post this.
Hello guys, its Mr. Toad again.
I am experimenting with HSF these days.
So I'v gathered a nice heat sink.
The only problem is that its underside surface is pretty rough.
I sanded it with point 600 sand paper, but no tick.
So i wanted to know if theres any way to give it a mirror like finish.
Also, m not sure what category this post belongs to. My apologies.
toad_frog09 is offline   Reply With Quote
Old 11-07-2010, 05:40 AM   #2 (permalink)
Default Re: M not sure where to post this.
hmmm you mean Chrome Polish?
Old 11-07-2010, 02:52 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Use finer sand paper.
asingh is offline   Reply With Quote
- by kool
- by ax3
