Old 08-07-2010, 02:15 AM   #1 (permalink)
Default Urgent help with a PC under 50-60k
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: High end gaming
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Yes
3. What is your MAX budget?
A: 50-60k
4. Planning to overclock?
A: No
A: Windows 7 Ultimate
A: 500GB- 1 TB
A: 7
A:I have built one before, will be assembling it myself.
A: In around 2-3 days tops
A: Yes
A: I don't need anything outside of the PC cabinet, everything else is already provided for
A: New Delhi
Here is what I've come up with so far:
RAM: 2X2 GB KingsTon/ADATA 1333 MHz DDR3
Processor:Core i7 930 2.8GHz
Motherboard:ASUS P6X58D-E
Graphics Card: Sapphire HD5850 1GB GDDR5
Hard drive: Western Digital Caviar Black 500 GB
Could you also suggest a cabinet extra fans required if any and appropriate power. Do I require a sound card?
Thank you, I need to know within the next day or two.
arjun1991 is offline   Reply With Quote
Old 08-07-2010, 09:07 AM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Urgent help with a PC under 50-60k
whats your monitor size...what resolution will your screen run at..
Jaskanwar Singh is offline   Reply With Quote
Old 08-07-2010, 05:13 PM   #3 (permalink)
Uhm...it's a 19 inch wide runs at 1440x900. I'll get a better one later.
Also I don't know whether that particular motherboard is available in Delhi, any idea>
Old 08-07-2010, 07:28 PM   #4 (permalink)
Core i7 930 2.8GHz @ 13.5k
MSI X58 Pro @ 10k
Corsair 4GB DDR3 1600MHz C9 Titanium @ 6.8k
Sapphire HD5870 1GB GDDR5 @ 22k
Western Digital Caviar Black 500GB @ 2.7k
Corsair VX550W @ 4.6k
NZXT Gamma @ 2k
Total-61.6k
Old 08-07-2010, 07:53 PM   #5 (permalink)
How does the MSI X58 Pro compare with the ASUS P6X58D-E since the asus board even has USB 3.0 and 2 6gbps SATA ports.
I'd rather cut down on the graphics card right now since my parents aren't willing to spend over 16-17k on the graphics card.
Old 08-07-2010, 07:58 PM   #6 (permalink)
but why?
you have got a total budget and you should get whatever fits in that perfectly.
i dont suggest you to fix prices for individual components.
talk to your parents once again..
Old 08-07-2010, 08:05 PM   #7 (permalink)
Ok I asked and he says that the cost for Windows 7 Ultimate and the AntiVirus should be included in that budget. Could you also tell me about the motherboard?
Old 08-07-2010, 08:08 PM   #8 (permalink)
i think windows 7 ultimate will cost around 10k and antivirus around 1.5 to 2k. can you get a cheaper version of windows.
Old 08-07-2010, 08:17 PM   #9 (permalink)
Yeah I sat down with him and discussed the differences in the different versions and he said he'll settle for Windows 7 Professional which really isn't much of a cost difference. So uh..yeah
Old 08-07-2010, 08:35 PM   #10 (permalink)
this means that your budget is reduces to 50k for gaming--
Core i5 750 2.66GHz @ 9.5k
Gigabyte GA-P55M-UD2 @ 7k
2 * 2GB DDR3 1333MHz @ 5.2k
Western Digital Caviar Blue 500GB @ 2k
NZXT Gamma @ 2k
Total - 52.3k
Old 08-07-2010, 08:53 PM   #11 (permalink)
ARIGHT! I told him someone on the digit forums advised me the graphics card and he said fine. YOU ROCK!
So I'm picking up the earlier rig you suggested, now the only problem is whether I can pick up the ASUS P6X58D-E for the better features.
Any advice on that?
Old 08-07-2010, 09:12 PM   #12 (permalink)
how much does that board cost?
Old 08-07-2010, 10:25 PM   #13 (permalink)
around 12-13k abroad. I have no idea about here.
Old 14-07-2010, 06:23 PM   #14 (permalink)
So my Budget went up drastically and here's what I've gone and bought now finally:
Processor: Intel Core i7 930
Motherboard: Asus Rampage III Extreme
Ram: 3x2GB Corsair 1600 Mhz Platinum Tri-Channel Kit
Power Supply: Corsair TX750W Power Supply
Cabinet: Cooler Master HAF 922
Hard disk: 500 GB Western Digital Caviar Black
So now I've got to get the Graphics Card.....Sapphire 5870 ran out of stock in India apparently since I talked to the main distributor for India.
*sniff* why do they run out of Sapphire ATI graphics cards so fast >.<
So I have to wait a full week for the Graphics Card.
Old 14-07-2010, 06:31 PM   #15 (permalink)
congrats. nice purchase. BTW can you state the prices against each item?
also for graphics card, you maybe interested in 2X GTX460 in SLI. the 768Mb version. will cost you same as HD5870.
Old 14-07-2010, 06:42 PM   #16 (permalink)
I bought everything from Nehru Place and here are the prices:
Processor:
Intel Core i7 930 @ 14.4k
Motherboard: Asus Rampage III Extreme @ 30k-ish in India but I got mine from Malaysia @21k
Ram: 3x2GB Corsair 1600 Mhz Platinum Tri-Channel Kit @10.5k
Power Supply: Corsair TX750W Power Supply @ 6.8k
Cabinet: Cooler Master HAF 922 @6.5k
Hard disk: 500 GB Western Digital Caviar Black @2.9k
Backup: 1KVA APC UPS with Software for shutting down @5.5k
OS: Windows 7 Professional 64 bit @9.1k
There you go, the cabinet has provisions for liquid cooling tubes so I'll be OCing the moment this rig starts getting a wee bit old since the motherboard allows me to hook up my Laptop or Phone via bluetooth to overclock every bit of it.
Don't that particular SLI config run really hot?
Old 14-07-2010, 08:28 PM   #17 (permalink)
Processor:
pricing is nice. & you got that Extreme for just 21k. excellent.
no. as the cards already runs cool so SLI will raise temperature by just 5degree or so. also as Rampage III Extreme have support for 4 way SLI. you can install the cards a bit away. say 1st & 5th or 4th slot. & SLI them.
Old 14-07-2010, 08:58 PM   #18 (permalink)
fatalcore's Avatar
Awesome......rig...bro.....can u please post few pictures....i would love to see the beast.....Again....for u ...AWESOME !!!
Q9550+GA-EP45-UD3L+4GB CORSAIR DDR2 800FSB+XFX GTS250 1GB+250GB SATA+CORSAIR VX450+CM V8+ASUS XONER D2+SATURN+LGDVDRW+CREATIVE 5.1 INSPIRE+500GBX6 FREE GO AGENT+RAZER MOUSE+DELL LATITUDE 6400.
fatalcore is offline   Reply With Quote
Old 15-07-2010, 02:01 AM   #19 (permalink)
Techie By Heart
mavihs's Avatar
which shop?
you'll have warranty probs!!!!
you got it over priced!!!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 16-07-2010, 12:07 PM   #20 (permalink)
Thanks guys! ^_^
Originally Posted by mavihs View Post
which shop?
I got it from an official cooler master dealer called Pappi/Gurmeet(SMC International) and Crux Electronics
Yeah warranty problems will be there.
And I bought the full pack 64 bit man, not the 32 bit OEM. So yeah. It's a standard cost.
I haven't got pictures yet cause I haven't got the graphics card yet, the moment I get one, I'll put pics up
Old 16-07-2010, 12:25 PM   #21 (permalink)
Techie By Heart
mavihs's Avatar
Thanks guys! ^_^
wat did you buy from Crux Electronics?
Old 16-07-2010, 01:55 PM   #22 (permalink)
why not the UD9 ? would have been 32k in india....
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 16-07-2010, 03:02 PM   #23 (permalink)
Windows 7 Professional Retail version price has gone up by 1000/- in the past one month.
Also with 750W Corsair PSU you will not be able to go above GTX460 in SLI. Crossfire with ATI 5800 series is not possible on this PSU. So finally you got very good rig but still limited by by its GPU power due to PSU. You should have opted for Corsair 850W (atleast) so that you had decent headroom for future GPUs (in SLI/Crossfire). This would have done justice to your CPU and MoBo.
Thanks guys! ^_^
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline   Reply With Quote
Old 19-07-2010, 01:17 AM   #24 (permalink)
I bought the PSU, the UPS and the Ram, going ot buy my Graphics Card from there.
Also a 750 watt is quite enough for 5870's in crossfire without too large an OC.
Corsair TX750 Watt Enough For HD 5870 Crossfire? - Overclock.net - Overclocking.net
When I do overclock - when I get back from college, I'll buy a 1kW, I intend to take this to a stable 4.2 atleast.
Old 19-07-2010, 02:21 AM   #25 (permalink)
^^ without OC, HD5850 X2. with OC, GTX460 X2. wasting so much money on going for 2XHD5870 doesn't seems good. at least performancerice point of view.
Old 19-07-2010, 10:58 AM   #26 (permalink)
My comment was based on Corsair's website where they have recommended Min. 850W PSU for running 2 5800 cards in crossfire with system running on stock speed.
HElP ME BUY LCD TV {URGENT} napster007 Hardware Q&A 3 23-06-2010 02:05 PM
Urgent Help Required solmri Software Q&A 5 17-05-2010 10:39 PM
Best 15'' Gaming Laptop within 60k!!! george101 Laptops and Netbooks 8 22-04-2010 06:38 PM
Urgent please suggest (Acer 5740/Dell Inspiron/ Dell Stuido15 )??????? phanisrinivas Hardware Q&A 11 19-04-2010 02:17 PM
Want A Phone For 7-8K..Help Urgent TheLetterD Mobiles and Tablets 12 19-03-2010 07:54 PM
- by kool
- by ax3
