Old 08-07-2010, 12:20 AM   #1 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Some hardware questions.
Had a couple of questions which I could use some help on. One was I'm considering of getting a laptop. Although I am quite concerned about the budget. What I'm looking for is extreme value for money. Im trying to keep my budget at a minimum but if the laptop justifies the cost I won't mind spending on it as well. However I would appreciate the best I could possibly get for the least cost.
Secondly, my cousin happens to be starting a computer store thingie and hes basically taking me along to help him out purchase (I think he just wants me to carry stuff ) some stuff as well. What components would you say would be the most worthwhile stocking from your experience . Also try to focus on accessories which wont see that much of a change of price in the coming days.
Third need some advice for purchasing another system which pretty much follows the above terms for the laptop. Ill fill in the following template as well .
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Basic How Use, Watch a movie or two, Maybe install some Linux OS , code a bit maybe.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
Yes
3. What is your MAX budget?
I'm not sure I know how to specify this but as I said earlier cheapest possible with maximum returns .
4. Planning to overclock?
Nope
Maybe Windows XP and Linux else just Linux if I do ever get an original copy of WIndowsd & I might give it a whirl on it.
The more the merrier. Ive been downloading quite alot ever since I started using Linux so I guess the more space the better.
7. What resolution will the screen run at & whats the size of the screen you want?
Erm I haven't really given this much thought . Do 21 inch worthwhile monitors come cheap?
5 .
Yes I usually put together my stuff.
Tomorrow or day after D: .
Definitely the more future proof the better but I think Id rather be a bit more budget conscious considering the purpose of the system.
Nope.
Ill be buying from a store Ive always been getting my stuff from.
FilledVoid is offline   Reply With Quote
Old 08-07-2010, 09:22 AM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Some hardware questions.
Athlon II X4 635 2.9GHz @ 5k
Biostar TA785G3 HD @ 4.2k
2GB DDR3 1333MHz * 2 @ 5.1k
Western Digital Caviar Blue 500GB *2 @ 4k
LG H55N DVD @ 1k
FSP saga II 350W @ 1.5k
Zebronics Blaze @ 1k
BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
Logitech Keyboard and Mouse @ 0.7k
Total - 29.8k
do you want speakers and UPS??
---------- Post added at 09:22 AM ---------- Previous post was at 09:21 AM ----------
But i think if you specify your maximum budget it will be easier for us to suggest....
Jaskanwar Singh is offline   Reply With Quote
Old 08-07-2010, 09:36 AM   #3 (permalink)
I will go for Intel range of processors instead of AMD. Look out for their new i3 or i5 range.
Also get a entry level graphics card even if you don't plan to play games. Having a graphics card lessens the load of the CPU, especially while watching movies.
pauldmps is offline   Reply With Quote
Old 08-07-2010, 09:45 AM   #4 (permalink)
i dont know how many times we have argued in this forum that is i3 better or athlon 635. you should check the previous threads
and concerning graphics card the onboard hd4200 is fine for hd content..no bottlenecks..
Old 08-07-2010, 10:05 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Bhai english main type karlo, sab ko hindi naheen athee...!
asingh is offline   Reply With Quote
Old 08-07-2010, 10:28 AM   #6 (permalink)
FilledVoid's Avatar
My Fluency in Hindi is horrible so Id appreciate a translation if any advice was in it :< .
No I'm going to avoid this as I already have a speaker set I can use for this system. As for UPS I have an APC 600 VA I can use with the system as well so you can bypass that .
For the system I would think 35 k would be tops perhaps . For the laptop I'm not sure yet . I just want to get something that doesn't require me to sell a kidney but get the maximum benefit for the cost as well .
Also any idea on the second question. From experience Ive seen alot of SMPS and Hard Disks fried but I might be wrong.
From my understanding I was thinking that AMD was much more VFM than Intel and if I'm correct i3 and i5 aren't really new processors either are they?
Old 08-07-2010, 10:42 AM   #7 (permalink)
ok asigh...english typing from now on...
this will be sufficient for your needs-
LG H55N DVD @ 1k
CM elite 310 @ 1.5k
Total - 30.3k
Old 08-07-2010, 10:42 AM   #8 (permalink)
FilledVoid's Avatar
Oh I see . Yes indeed that sounds reasonable .
Old 08-07-2010, 10:54 AM   #9 (permalink)
asigh i edited all my posts...i am sorry if that was irritating..
Old 08-07-2010, 11:02 AM   #10 (permalink)
FilledVoid's Avatar
What do you guys think about Acer Laptops? Ive had a good experience from them btu I guess the others have a bad experience after checking the number of threads that say otherwise. Was thinking of the Following Models .
Aspire 5740G
Aspire 5738 Z
Also what about Inspiron 14 R ?
Old 08-07-2010, 12:19 PM   #11 (permalink)
LG H55N DVD @ 1k
CM elite 310 @ 1.5k
Total - 30.3k
better get 400W PSU from FSP or maybe Corsair (if availability is a problem).
Old 08-07-2010, 01:33 PM   #12 (permalink)
oh yes i forgot to change the psu to FSP saga II 400W @ 2k
thanks sam..
Old 08-07-2010, 02:37 PM   #13 (permalink)
thanks sam..
welcome buddy. well the config looks good. & is a good one as gaming not on list (IGP & Full HD monitor never mixes well).
Old 08-07-2010, 07:44 PM   #14 (permalink)
yah i know gaming with IGP on a 22" monitor!!just the thought feels bad!!
Old 08-07-2010, 07:58 PM   #15 (permalink)
FilledVoid's Avatar
The damage has been done . Ive made the purchase for everything but the Biostar motherboard and had to settle for a different one. I made a change for the monitor also. I decided to splurge a bit more and got the 22" Dell one . The 24" was not available for purchase either and coming from a 17" inch display I have got to say that this thing is HUGE.
Also got myself a Dell Inspiron 14 R . Just the plain black laptop . It seems to be nice and it came with Win 7 but it did cost an additional 1.5k I think D: . I believe someone has already done a review of these products at this point so Im not going to do the same . but if anyone has any questions be free to message .
Old 08-07-2010, 08:09 PM   #16 (permalink)
which mobo? congrats dude
Old 08-07-2010, 09:46 PM   #17 (permalink)
FilledVoid's Avatar
I know people might be sad that I bought this but I really didnt have much option I guess. I think it was an Asus 785G -EVO something. On the cover it has something Extreme Edition written if I recall right. I'm too tired to get up and go look. Ill post the correct name tomorrow.
Old 08-07-2010, 09:55 PM   #18 (permalink)
Wise Old Ghoul
Piyush's Avatar
V-evo or M-evo ?
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 08-07-2010, 10:04 PM   #19 (permalink)
i think you brought yourself Asus M4A785TD-V EVO. its Xtreme Design. its just Gigabyte's Ultra Durable 3 + a few other things. labelled the name Xtreme Design. but i have heard a few bad things about this & a few Asus motherboard. ram unable to run in dual channel. the VIA audio unable give proper sound in win7 & yes the heatsink (north bridge) heats up badly. if you face no issues like this, than you on safe side. anyway congrats on the purchase
Old 08-07-2010, 10:10 PM   #20 (permalink)
Wise Old Ghoul
Piyush's Avatar
v-evo score is almost equal to that of m-evo
only some features are different
like crossfire/sli,....
--Get Backers
Old 08-07-2010, 10:15 PM   #21 (permalink)
actually M-EVO better buy. problem is its isn't available here.
also AMD = no SLI.
Old 08-07-2010, 10:17 PM   #22 (permalink)
Wise Old Ghoul
Piyush's Avatar
why???
also AMD = no SLI.
ooops
sry
my mistake
--Get Backers
Old 08-07-2010, 10:56 PM   #23 (permalink)
why???
M-EVO is firstly cheap. no Xfire (who needs X16+X4 Xfire? it'll make Xfire snail slow). also the sideport memory is Empadei or some company. it can be OC past 2000Mhz (desktop memory can't match).
Old 09-07-2010, 09:38 PM   #24 (permalink)
Wise Old Ghoul
Piyush's Avatar
never heard of that one.. i mean the company
--Get Backers
Old 09-07-2010, 10:08 PM   #25 (permalink)
me2 never heard. BTW, V-EVO's sideport memory is from Nanya.
Old 10-07-2010, 12:15 AM   #26 (permalink)
FilledVoid's Avatar
HEhe I forgot to check the cover to get the name and the bill has it misprinted I think. It says
Asus M4A785E-DD-EVO . Will confirm for sure tomorrow. Installed Windows 7 . My first hands on experience with WIn 7 and I do feel a bit weird but Ill get over it hopefully. The system seems to be running cool so far so hopefully it wont go up in smokes D: .
Collection of Interesting Articles on OSS Rahim Open Source 136 11-02-2012 09:15 PM
Is it worth taking Dell Service: Hardware Maintenance Accidental Damage Protection mack1983 Mobiles and Tablets 10 03-05-2010 08:39 PM
Query on existing hardware mohdnajm Hardware Q&A 1 24-04-2010 01:58 PM
Just what is DirectX? rajat22 Tutorials 1 11-06-2005 12:30 PM
Top 20 XP Questions & Remedies rajat22 Software Q&A 9 09-06-2005 01:26 PM
- by kool
- by ax3
