1. I have never done overclocking before. Will ocing shorten the life span of the CPU if a good CPU cooler is used?
I have a Core i3 530 Processor with Gigabyte GA-H55M-USB3 Mobo and want to overclock the CPU.
Kindly suggest a good and silent CPU cooler for the same. Is the Arctic Cooling Alpine 11 Pro good for the i3? Is it available in India?
2. Which is the best among these four? I'll be using it with Gigabyte GA-H55M-USB3 (Rev 1.0) and Intel Core i3 530. Are these RAMs compatible with the system I'm having? You may suggest if you know a better option within the same price range
a) GSKill 2GB X 2 DDR3 DUAL CHANNEL KIT 1600MHZ CL9 RIPJAWS - F3-12800CL9D-4GBRL
b) G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-4GBRM
c) Mushkin 996768 - 4GB DDR3 PC3-10666 9-9-9-24 Silverline
d) CORSAIR XMS3 4GB (2 x 2GB) DDR3 SDRAM 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model TW3X4G1333C9
