Old 07-07-2010, 08:34 PM   #1 (permalink)
Pravas's Avatar
Default Microtek UPS Backup Lasts Only For Few Seconds
Hi techies , I'm using a Microtek UPS(HGE600AZ)from last 3yrs.. and it's backup time has significantly reduced,around 5 seconds....
So i called up a nearest service center and told them my problem, they replied me that i need to replace the battery...
Now i would like to know, can't it be repaired or something???
And moreover the cost estimation told was Rs 800 INR....
I am from Hyderabad, if any localites would refer me some shop then would be a great help..
!!!!*Little Knowledge Is Dangerous*!!!!!
Pravas is offline   Reply With Quote
Old 08-07-2010, 02:23 PM   #2 (permalink)
Pravas's Avatar
Please Anyone out there can help me...anyhow I'm given till Monday by this Service Center people as they don't any batteries in stock.
I can't stop using my pc..so guys please help me before this power cuts damage my PC....
Old 08-07-2010, 02:42 PM   #3 (permalink)
Tech.Masti's Avatar
Default Re: Microtek UPS Backup Lasts Only For Few Seconds
You have to change battery.... I dont think any other option is available....
I changed my microtek double battery ups battery in last february and service centre people said that its better to shut down pc within 5- 10 minutes after electric gone, they also told that full battery discharge will decrease your battery life quickly
Tech.Masti is offline   Reply With Quote
Old 08-07-2010, 02:46 PM   #4 (permalink)
New Gen Guru
sujoyp's Avatar
UPS battery cant be repaired...it had to be replaced..on an average UPS battery cost 600+ here..
After replacement ur UPS will be as good as new one
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now   Reply With Quote
Old 08-07-2010, 02:54 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
Ya change the battery.
Also my APC ups is dying. hardly stays on till 2 min. Any idea how much a battery cost? or any other battery I should look for?
mine is 650VA...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Old 08-07-2010, 05:30 PM   #6 (permalink)
CA50's Avatar
I think the cost of the battery is more, I changed my ups battery 4-5 months back for 600 bucks, it was of luminous.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 08-07-2010, 06:43 PM   #7 (permalink)
Tech.Masti's Avatar
@rhitwick
call apc service centre, they will inform you all details.....
Old 08-07-2010, 08:16 PM   #8 (permalink)
Pravas's Avatar
Thanks a lot everybody, then i'll better change the battery. And like i said i will be charged around 800bucks....
But hope they give me a warranty along with that
Old 08-07-2010, 10:10 PM   #9 (permalink)
Just to add here, you can buy good batteries for Rs. 500 or less if you give them old battery. You can change your battery yourself, its pretty easy... I do it almost every year when backup get reduced to 10 min or less(since I have double battery UPS with backup upto 1 hour when batteries are new .. on 22" LCD )
Amaron is the costliest I find, exide is good, but I usually buy Amco as the dealer is near my house and if any fault in battery, he replaces it instantly.
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline   Reply With Quote
Old 09-07-2010, 01:07 AM   #10 (permalink)
Pravas's Avatar
@Ricky...then could i exchange with the same Service Center.
Old 09-07-2010, 01:28 AM   #11 (permalink)
Tech.Masti's Avatar
@pravas
they will give u 1 year warranty on battery when you take new battery....
UPS for 2-3 hours backup sanju_nlp81 Hardware Q&A 6 24-07-2010 10:06 PM
UPS (Uninterruptible_power_supply) and UPS battery Buying Advice? Help Digitians!!! RajivKumar123456 Hardware Q&A 6 02-07-2010 11:41 PM
Best UPS for 1/2/3Hr. Backup for 400Watt System vishyvishy Hardware Q&A 1 30-06-2010 03:45 AM
ups not providing backup upon power failure ivanpatro2000 Hardware Q&A 1 07-06-2010 07:26 AM
UPS backup calculation iiamvin Hardware Q&A 3 22-02-2010 10:37 PM
- by kool
- by ax3
