Re: [URGENT]0xc0000001 ERROR in New PC Please help
Reinstall windows.
If it doesnt work, your disc is corrupt, get another one 7 then reinstall.
Originally Posted by dheeraj_kumar
Reinstall windows.
My HDD Is unformatted..Brand new.No OS is there....
Xp also gives Me a BSOD
After loading files finishes and the Choose partition Screen Is about to come
Please Please help me
Steve Jobs (February 24, 1955 – October 5, 2011) & Jagjit Singh (8 February 1941 – 10 October 2011)
RIP
Try a different OS disc... XP or 7, its your preference. Are you sure the installation media you have are working correctly?
Or, your RAM may be corrupt, that's a reason for BSODs. If its old, clean the golden ports on the RAM and insert it back.
