Old 06-07-2010, 04:37 PM   #1 (permalink)
Default Which DVD drive to buy?
Ok,i'm planning to buy a new dvd drive. My config is
core i3+DH55TC mobo
ATI radeon SApphire HD 5670
yamaha sound card
2 GB DDR3 RAM
500w cooler master
i need this one for your DVD's,writing music cd's
please suggest A SATA Dvd drive and also a usb drive.
my budget is Rs 1500.
medmonster is offline   Reply With Quote
Old 06-07-2010, 07:58 PM   #2 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Re: Which DVD drive to buy?
Answered many times before.You will end up with different answers.Let me start the debate, SONY !!
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 07-07-2010, 01:45 AM   #3 (permalink)
I would vote for lite-on DVD-drives... ultra reliable and give highest burn speeds
bharatbharija is offline   Reply With Quote
Old 07-07-2010, 09:40 AM   #4 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Take a die..
1 Sony
2 Samsung
3 LG
4 HP
5 Lite on
6 Moserbaer
Write these names on its 6 faces and throw then decide!
Old 07-07-2010, 04:33 PM   #5 (permalink)
static_x's Avatar
not again!!!!!
Buy the drive whose service center is in your city.....I would suggest SAMSUNG
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
static_x is offline   Reply With Quote
Old 07-07-2010, 11:21 PM   #6 (permalink)
Guyz sorry for the interruption,but really i do have a sony DVD RW(which is connected through A IDE to sata adapter),and its speed is really terrible.
So i need to get one which is more reliable in terms of reading DVD's.
Old 08-07-2010, 09:56 AM   #7 (permalink)
static_x's Avatar
These adapters are useless...the speed problem is due to that only...get SAMSUNG or ASUS...do not get into this debate better go to the nearby shop and buy one for you...
Old 08-07-2010, 10:28 AM   #8 (permalink)
CA50's Avatar
Get a LG 22x drive for 1.1k. Its cheap, fast and also reliable
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 08-07-2010, 11:09 AM   #9 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
LG drives performance has let down too less a people...I will suggest go for LG.
I had a LG CD Writer long time back. Never had any issues. No also for two years I have been using a LG DVD Writer...no probs at all...
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 08-07-2010, 12:13 PM   #10 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
you cant say like that.My 5 year old Sony DVD RW working fine in my old p4 rig with out any single issue.Many of my friends have SONY (recommended by me) zero issues so far.
So I have a solid reason to recommend it.
Old 08-07-2010, 02:29 PM   #11 (permalink)
Pravas's Avatar
Lately my Lite On DVD drive stopped working and i gave it to some guys(namely Silicon Technologies)and they couldn't fix it. So this time i bought a Sony one.....and moreover if something happens...I can reach Rashi Peripherals Any time
!!!!*Little Knowledge Is Dangerous*!!!!!
Pravas is offline   Reply With Quote
Old 08-07-2010, 05:32 PM   #12 (permalink)
CA50's Avatar
Can`t agree to that, few weeks back i got a sony dvd rw for my friend, the performance was horrible, gave it to the dealer and got a lg, it rocks. I myself have two lg dvd rws, they rocks
| Nokia 2700c |
Old 08-07-2010, 06:16 PM   #13 (permalink)
thanx all...gonna take LG soon...
Old 08-07-2010, 06:51 PM   #14 (permalink)
Tech.Masti's Avatar
its fully depends on person for dvdrw, everyone have different experience with different brands....
Tech.Masti is offline   Reply With Quote
Old 09-07-2010, 11:05 PM   #15 (permalink)
hey i got one LG 22x,but wen i inserting any cd or dvd it is not reading them.
should i go back and change it aur do somethin else.
Old 10-07-2010, 12:20 AM   #16 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
I wont answer it as I didnt recommend it. Where are LG supprters..? just solve it for him.
Old 10-07-2010, 02:28 AM   #17 (permalink)
Rockstar11's Avatar
Samsung..............
Zindagi Toofani Hai... Jahan Hai DuckBurg!
Rockstar11 is offline   Reply With Quote
Old 10-07-2010, 10:28 AM   #18 (permalink)
gagan007's Avatar
Make sure all the connections are proper...A new hardware such a this should not fail on its maiden trial. It is properly tested before sending in the market. Why do not you get help from someone more experienced in hardware?
If all else fails, take the cabinet to the store from where you have made the purchase...it will work out...
Old 10-07-2010, 11:27 AM   #19 (permalink)
15.0 GHz
VarDOS's Avatar
recently we had a great discussion over the DVD Drive. Where is that thread?
VarDOS is offline   Reply With Quote
Old 10-07-2010, 12:18 PM   #20 (permalink)
gagan007's Avatar
someone has removed that thread...i couldn't search that either...the post that I made in that is also untraceable...
BTW that gentleman purchased a Sony DVD writer...
Old 10-07-2010, 12:27 PM   #21 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Right choice he made
Trouble upgrading firmware of MOSER BAER DH-20A3S DVD Drive vinay_001 Hardware Q&A 0 27-06-2010 10:47 PM
WinX DVD Author the best tool to Personalized DVD from Your Own Video in Clicks bigit Random News 2 21-06-2007 01:15 PM
[Preview + Feedback] Digit December Mega Issue Raaabo Feedback 298 25-03-2006 12:09 PM
- by kool
- by ax3
