Old 06-07-2010, 09:14 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Pro/An---tagonist xD
Default Reboot and insert proper boot device error. -___-
I am getting this weird error message sometimes when I am turning on my PC.
Its not happening everytime,but at times,instead of the "windows" loading screen I am getting a black screen with the message "Reboot and select proper Boot device or insert Boot media" . When I go into the boot menu,The HDD isn't shown there in the boot sequence selection option. But when the system works normally the HDD is shown there. Don't know what the problem is.It happens at random times.Any help??
P.S:- I have tried changing the boot order to HDD first and other variations.Not working. :\
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is online now   Reply With Quote
Old 06-07-2010, 09:41 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Reboot and insert proper boot device error. -___-
Re do the SATA jumpers.
asingh is offline   Reply With Quote
Old 06-07-2010, 10:31 AM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
also rest the BIOS and again set the priority of the HDD's.
VarDOS is offline   Reply With Quote
Old 06-07-2010, 10:33 AM   #4 (permalink)
cute.bandar's Avatar
Google says that the PC is trying to boot from usb
cute.bandar is offline   Reply With Quote
Old 06-07-2010, 07:14 PM   #5 (permalink)
I already set the boot order 3-4 times. :\ And sometimes the problem disappears when I restart with the usb mouse disconnected(not always though).Its not an HDD problem since i have tried 3 HDD's.
Will try the jumpers.
Old 06-07-2010, 08:18 PM   #6 (permalink)
Swimming, eh??
toad_frog09's Avatar
Did u, by any chance, buy a new motherboard?
Soln-jumpers.
Also,check the sata cables.
toad_frog09 is offline   Reply With Quote
Old 07-07-2010, 10:30 AM   #7 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
try to update ur bios it could be due to bios issue
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Old 07-07-2010, 11:25 AM   #8 (permalink)
check the cables & the slot where the cable gets fitted well. i2 faced same problem many times. at last know both cable & the slot have slowly gone bad. bowever mine is IDE & i don't have any USB mouse.
you already OC your proccy?
Old 07-07-2010, 01:25 PM   #9 (permalink)
CG Artist++
yes sam, I oc it before i boot it.
Old 07-07-2010, 01:46 PM   #10 (permalink)
ok but i think you should have ran it for 1 week before doing the OC. still its ok. BTW, what is the load & idle temperature?
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/129140-reboot-insert-proper-boot-device-error-___.html
Thread Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key? - Yahoo! Answers | Computers & Internet - Yahoo! Answers | BoardReader This thread Refback 10-10-2010 11:19 PM
"Reboot and Select Proper Boot Device" getting error sxyadii Hardware Q&A 2 10-02-2010 10:10 PM
Cannot boot from Samsung DVD drive GigaHeartz Hardware Q&A 6 03-09-2009 03:53 PM
Boot Error Message ashisharya Software Q&A 2 29-06-2006 12:25 PM
Cool Xp Tips/Tricks heart-breaker Software Q&A 2 11-04-2006 07:18 AM
- by kool
- by ax3
