Old 04-07-2010, 05:37 PM   #1 (permalink)
Post Portable Hard Disk
I need to purchase a portable hard drive.My budget is 3500...Since there are many portable hard drive available in the market...i am a bit confused.
The capacity of the hard drive must be greater or equal to 320 GB.
udbhavdwivedi is offline   Reply With Quote
Old 04-07-2010, 05:47 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Portable Hard Disk
WD passport essential is available for 3k for 320gb and 500gb for 4k
---------- Post added at 05:47 PM ---------- Previous post was at 05:46 PM ----------
you need 2.5" or 3.5"
Jaskanwar Singh is offline   Reply With Quote
Old 05-07-2010, 12:17 PM   #3 (permalink)
static_x's Avatar
Portable means 2.5"
Go for WD 320 @ 2900 & 500 gb @ 3950
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
static_x is offline   Reply With Quote
Old 05-07-2010, 02:05 PM   #4 (permalink)
cute.bandar's Avatar
how about the option of making your own ? Buy a 2.5" drive and a External HDD case, and just stick the drive in the case! will save 200-300 bucks
cute.bandar is offline   Reply With Quote
Old 05-07-2010, 10:23 PM   #5 (permalink)
I need 2.5"
Thanks a lot...
Old 06-07-2010, 11:08 AM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
External Case + Laptop HDD can do but then you have to go for a branded external casing. Local will reduce the transfer speed. But branded Casing like Transcend costs more which will be = My Passport / FreeAgent
I'm using WD My Passport Essential for last two years, its awesome in performance and no ISSUES yet.
My Passport looks cute n sexy! I'll impress girls
VarDOS is offline   Reply With Quote
Suggest a 1 TB Hard disk sarincv PC Components / Configurations 6 20-08-2010 02:06 AM
Hard disk is getting too hot Cool Buddy Hardware Q&A 7 06-06-2010 07:18 AM
Which hard disk ?? Tenida Hardware Q&A 7 27-05-2010 09:07 PM
hard disk crash problem anant197 Hardware Q&A 3 17-03-2010 07:57 PM
- by kool
- by ax3
