I bought a new 500 GB HDD and I need to increase the size of my Games installed folder.If I copy whole files to another big drive and letter the drive as the old one, will the games work..?
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
The games will work exactly as they do right now. But try to do this in safe mode, reason- some games may have services running and might update links when you move the folders or some such stupid thing. Do it in same mode and you are good to go, and there's no need for reinstalling anything.
I have done it and all the games worked perfect.Games were moved from a 50GB drive to a 100GB drive.Only thing I lost is the volume settings for each game in windows 7
A crude way to do it, but yes it will work. You will get warped registery entries, and a bloated system. Best is to uninstall, and install on the new file-path.
