Old 03-07-2010, 12:42 AM   #1 (permalink)
Default 40 GB HDD on P3
Is it possiable to attach a 40gb HDD(Segate , Baracuta) in P3 machine. I tried but when I want to install Xp or other OS it stopped working. The P3 machine work with 10 gb hdd. If I work the 40 gb hdd only for data storage then that is work fine.
Is any solution to boot the 40 gb HDD in P3.
Thanx.
amit58414 is offline   Reply With Quote
Manufacturer HDD creating Problem!!! tiwarisatyadeep Hardware Q&A 0 30-05-2010 12:22 PM
Manufacturer HDD creating Problem!!! tiwarisatyadeep Software Q&A 0 30-05-2010 12:17 PM
Max. HDD support for Intel 915GAV bajaj151 Hardware Q&A 4 26-04-2010 10:48 PM
Did a clean on hdd and need help!!!!!!!! yoursnayak Hardware Q&A 4 11-03-2010 11:51 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
- by kool
- by ax3
