Old 02-07-2010, 09:43 PM   #1 (permalink)
avichandana20000's Avatar
Default Retention bracket needed.
Asus am3 socket . Needed a hsf retention bracket.
avichandana20000 is online now   Reply With Quote
Old 02-07-2010, 10:54 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Retention bracket needed.
For which HSF..?
asingh is offline   Reply With Quote
Old 06-07-2010, 11:31 AM   #3 (permalink)
Originally Posted by asigh View Post
For which HSF..?
it is the default HSF that comes with 955 BE. The board is ASUS
M4A78T-E. One of the grooves in the retention bracket that holds the clips of HSF is broken.
First i thought i need that bracket but after reading another review from another forum I think Thermalright AM2/AM2+/AM3 will be right for me.
But i do not know it is available in KOLKATA or not. i am also not habituated in online shopping.
Old 06-07-2010, 01:58 PM   #4 (permalink)
^^ can go for a CM TX3.
Old 06-07-2010, 10:49 PM   #5 (permalink)
but in CM TX3 for AM3 socket that retention bracket is required.
Old 06-07-2010, 11:24 PM   #6 (permalink)
you better talk to azzu. he got himself a TX3. he broken or can be told that his retention bracket came off. so he must have got some kind of back plate or so.
Old 07-07-2010, 12:23 AM   #7 (permalink)
Super Moderator
asingh's Avatar
What HSF you get, make sure it is bolt-down, and not the dumb push-pin. Push-pin is useless.
Old 07-07-2010, 09:30 PM   #8 (permalink)
that is what i am asking for . The retention bracket is holded by four screws with the backplate.What i want to know is : if i unscrew those four and remove the broken retention bracket along with the back plate what will be the exact replacement of that?
In Thermalright AMD Socket AM2 / AM3 Bolt-Thru-Kit Rev.2 product they are giving a back plate, mounting bracket, spring loaded screws.
1) what HSF is that given in the example?
2) Is it a bolt down OR dumb push-pin ?
3) Will the mounting bracket pass through the heat pipes of my HSF which comes with 955 BE proccy?
4)Can i get simply another retention module which can be screwed up with the mobo?
Old 07-07-2010, 09:56 PM   #9 (permalink)
Super Moderator
asingh's Avatar
When you mount an OEM HSF, every thing related to the stock one will be removed. So that black bracket above will also be removed. The back plate will go at the back, and screwed on the top via the bracket. The HSF will be then screwed down.
Old 08-07-2010, 11:47 AM   #10 (permalink)
not getting you fully.
OEM HSF means after market hsf(y/n)
my qns is can i get that black bracket only in the market? if yes, then i can screw the new bracket with the new backplate.
but, if it is not available what option is there then?
Old 08-07-2010, 11:58 AM   #11 (permalink)
OEM HSF needs the retention bracket to be removed (not all). some comes with backplate. else one have to use the backplate the motherboard comes with.
the retention bracket was available in ebay. not sure if its still available.
Old 08-07-2010, 02:33 PM   #12 (permalink)
Super Moderator
asingh's Avatar
Basically the OEM HSF will supply you with everything you need to mount it. Be it bracket/backplate/screws/pin outs.
Old 08-07-2010, 09:15 PM   #13 (permalink)
what is the option if it is not?
SO buying HSF will give the required accessories. now suggest a OEM HSF (which requires either a black bracket or can be directly bolt down via backplate)which i can fit in my M4A78T-E(AM3 SOCKET) mobo. My cabby is CM ELITE 310.
Old 08-07-2010, 09:51 PM   #14 (permalink)
if it isn't, only thing possible is get the cheapest HSF. talk to pulsar_swift. he got TX3. if he have received backplate, get it. else there are lot of costlt (above 2k) options. another one is Scythe katana3. this one is a kind of low profile. and actually is a much better cooler yet costing just 1.5k.
Old 08-07-2010, 11:17 PM   #15 (permalink)
Super Moderator
asingh's Avatar
How much can you spend..?
Old 09-07-2010, 04:45 PM   #16 (permalink)
not more than 1.5k.
Please share Your IELTS Experience-Badly needed mike08 International Education 4 22-12-2010 10:32 AM
Best smartphone+multimedia phone at 15k needed sakumar79 Buying Advice 24 09-06-2010 07:00 PM
needed middleware sudhansagar Software Q&A 2 16-03-2010 12:33 PM
Suggestions needed for purchase ajai5777 Hardware Q&A 11 12-02-2010 06:30 PM
Installing VLC in FC-6??? The Unknown Open Source 14 20-08-2007 06:39 PM
- by kool
- by ax3
