Old 02-07-2010, 05:52 PM   #1 (permalink)
Default AMD Phenom II unlocking issues
hi,
i got myself a phenome x2 555be with biostar TA790GXE128M.
stock cpuz reported normal cpu details
after unlocking the third core cpuz shows the cpu as amd athlon x3 455
whats with the renaming of my cpu.
dr_ashish is offline   Reply With Quote
Old 02-07-2010, 07:37 PM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: Amd ii phenome unlocking issues
yeah its correct. As no phenom series has 3 cores.. so according to cores; its showing X3. Did you check the config by rightclicking the my computer?
If you unlock the last core then it will show Phenom X4
VarDOS is offline   Reply With Quote
Old 02-07-2010, 08:51 PM   #3 (permalink)
well you not fully correct buddy. i put it this way. no Phenom II X3 got speed of 3.2Ghz. and as AMD going release more Athlon II X3. so one might have coincided with OP's speed i.e. 3.2Ghz tri core. so its displayed as X3 455. but still got 6Mb L3 cache.
PS: if u follow AMD's naming scheme. X3 455 should end up with speed of 3.3Ghz not 3.2Ghz.
Old 02-07-2010, 10:07 PM   #4 (permalink)
Wise Old Ghoul
Piyush's Avatar
how come it is showing athlon?
it should be phenom
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 02-07-2010, 10:16 PM   #5 (permalink)
bORn To RIse....
rahul.007's Avatar
it should be phenom
same question.... cpuz should show it as phenom.... just like mine....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline   Reply With Quote
Old 02-07-2010, 10:19 PM   #6 (permalink)
bORn To RIse....
rahul.007's Avatar
& as far as i know, there is no amd phenom II*4 B55 B.E proccy.... why is it showing that in op's specs????
Old 03-07-2010, 08:19 AM   #7 (permalink)
15.0 GHz
VarDOS's Avatar
thanks for correcting me buddy
Old 03-07-2010, 11:02 AM   #8 (permalink)
rahul, please hack the p-state. and lower the voltage as you having cool & quite on. 1.232V @ 800Mhz. its a bit too much. 1V is more than enough here.
Old 03-07-2010, 12:37 PM   #9 (permalink)
Super Moderator
asingh's Avatar
Default Re: AMD Phenom II unlocking issues
Get the latest CPU-Z version.
asingh is offline   Reply With Quote
Old 03-07-2010, 02:27 PM   #10 (permalink)
mine is the latest cpuid 1.54 version
Old 04-07-2010, 08:21 PM   #11 (permalink)
bORn To RIse....
rahul.007's Avatar
and same is mine....
@ sam:- will do that in a week.... rite now tuitions are a big headache and UTs also going on....
Old 17-08-2010, 07:41 PM   #12 (permalink)
in my case unlocking my remaining cores of phenom II x2 555 black edition is not safe. My computer experience troubles in detecting my computer's hard disk when I am in quad core mode
jerryoblego is offline   Reply With Quote
Old 17-08-2010, 08:41 PM   #13 (permalink)
Techie By Heart
mavihs's Avatar
just do stability test with prime95 to check if each core is stable or not by manually switching each core on(3rd & 4rth) one by one!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5532 Yesterday 10:13 PM
amd troubles spm Hardware Q&A 15 27-05-2010 07:47 PM
Suggest AMD config under rs.60,000 arshadmajeed PC Components / Configurations 11 08-05-2010 07:29 PM
AMD announced 6-Core Processor for Desktops celldweller1591 Technology News 6 03-05-2010 11:06 AM
AMD Phenom Motherboard Support hellknight CPU / Motherboards 1 26-05-2008 09:27 AM
- by kool
- by ax3
