Old 02-07-2010, 03:53 PM   #1 (permalink)
Arrow Suggest a DDR3 Mobo For 955BE
Plz suggest a good motherboard for AMD phenom II X 4 955 BE.
he mobo sud have ---
1. Budget not exceed from Rs.5000.
2. DDR3 ram supported with 4 ram slot.
3. It sud be decent overclocker.
sumanz is offline   Reply With Quote
Old 02-07-2010, 04:14 PM   #2 (permalink)
What The.... !!!
funkysourav's Avatar
Default Re: Suggest a DDR3 Mobo For 955BE
in a budget of 5k, idoubt you will get agood overclocker mobo
if you dont overclock, gigabyte785gmt-us2h@4.6k will do fine
but no oc'ing
funkysourav is offline   Reply With Quote
Old 02-07-2010, 05:14 PM   #3 (permalink)
Biostar TA785G3 HD. if you have OC in your to do list. don't look anywhere other than Biostar mobos.
Old 02-07-2010, 06:45 PM   #4 (permalink)
is that any reason. is biostar is better overclocker ?
Old 02-07-2010, 06:50 PM   #5 (permalink)
Jaskanwar Singh's Avatar
now for ocing a gigabyte, evga, msi, foxconn, asus mobos are recommended. go with what funkysourav suggested...biostar if gigabyte mobo not available..
Jaskanwar Singh is offline   Reply With Quote
Old 02-07-2010, 09:35 PM   #6 (permalink)
what abut MSI 785GM-E51 ? is it gud mobo, better dan the biostar one.
Old 02-07-2010, 09:44 PM   #7 (permalink)
i would suggest the gigabyte GA-MA785GMT-US2H
Old 02-07-2010, 10:02 PM   #8 (permalink)
Wise Old Ghoul
Piyush's Avatar
for OC blindly get one bio* mobo
the one sam suggested
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 02-07-2010, 10:22 PM   #9 (permalink)
bORn To RIse....
rahul.007's Avatar
yup.... bio* mobo best budget mobo having sideport memory + a great budget oc'ing board.... get it and save around 900 bucks....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline   Reply With Quote
Old 02-07-2010, 11:06 PM   #10 (permalink)
can i have some reviews for overclocking on biostar mobo....
Old 03-07-2010, 08:12 AM   #11 (permalink)
@rahul giga one costs just 400 bucks more than bio..
Old 05-07-2010, 07:13 AM   #12 (permalink)
is the bio* mobo better overclocker than gigabyte or msi ?
---------- Post added at 07:13 AM ---------- Previous post was at 07:12 AM ----------
but no oc'ing
is this mobo cant support oc'ing ??
Old 05-07-2010, 08:44 AM   #13 (permalink)
sumanz gigabyte one supports ocing
Old 06-07-2010, 11:50 AM   #14 (permalink)
avichandana20000's Avatar
in context to this i just want to know what will the best board for 955 BE with budget no bar?
avichandana20000 is online now   Reply With Quote
Old 06-07-2010, 12:01 PM   #15 (permalink)
asus crosshair IV formula for 18k
Old 06-07-2010, 02:01 PM   #16 (permalink)
replace it with Extreme soon.
Old 06-07-2010, 02:19 PM   #17 (permalink)
bORn To RIse....
rahul.007's Avatar
how much time??
Old 06-07-2010, 02:43 PM   #18 (permalink)
Originally Posted by rahul.007 View Post
how much time??
should be this month. as it been announced a long time ago (Q1 2010). it got Lucid Hydra. so cross breed of GPUs possible.
Old 06-07-2010, 06:01 PM   #19 (permalink)
bORn To RIse....
rahul.007's Avatar
would it be costing 18k only then too????
Old 06-07-2010, 06:16 PM   #20 (permalink)
18k will be a good pricing. take 3-4k more than Formula.
Old 07-07-2010, 01:16 PM   #21 (permalink)
pulsar_swift's Avatar
what a joke. 7.5K processor and 20K Mobo
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 07-07-2010, 01:24 PM   #22 (permalink)
actually its meant for X6 1090T BE + some uber cool HSF.
Old 07-07-2010, 01:38 PM   #23 (permalink)
How abt gigabyte 880 gm - usb3 @ 6.5k or ga 880 gma -ud2h @ 6.7k..'
I have the usb3 one and its features r good.. Can have a look but 1.5k is more than ur budget..'
Arnab boss is offline   Reply With Quote
Old 07-07-2010, 01:44 PM   #24 (permalink)
currently 8 series isn't much of a hit as it cost way more than 7 series. also Sata 6Gbps isn't mainstream yet nor will be this year. USB 3.0, add 1 yr more (till Sata 3 pendrives become cheap & widely available).
Old 07-07-2010, 11:29 PM   #25 (permalink)
Ya I agree with u but it would b more future proof...'
---------- Post added at 11:29 PM ---------- Previous post was at 11:03 PM ----------
Ya I agree with u but it would b more future proof...' its features and apps r also good and user friendly..'
Suggest a PSU... Swift Hardware Q&A 43 22-06-2010 10:27 PM
Suggest a gaming PC within 22k happy20b Hardware Q&A 7 28-05-2010 06:31 PM
suggest a mouse within rs 1000-1500.. himadri_sm Hardware Q&A 4 18-05-2010 06:57 AM
Suggest AMD config under rs.60,000 arshadmajeed PC Components / Configurations 11 08-05-2010 07:29 PM
High end gaming & graphics machine - suggest config rajatrao PC Components / Configurations 30 27-03-2010 06:47 PM
- by kool
- by ax3
