Hello,
I have bought AMD X2 245, Biostar 780L3 and Corsair 2Gb DDR3 ram 1333mhz.
I used the old 1Tb Seagate from my old config...with pre installed winxp
I have installed all the drivers from the given driver CD....
the problem is its hows two realtek network and two HD audio in device manager one normal and one with yellow mark....
The audio works fine.
I have Hathway cable net...when i try to connect to internet i am unable to do so as its not getting any ip address....with ipconfig \all is not showing me anything...the hathway guys say its problem with my network card(onboard).....
Before i rush back to dealer i want to be sure where the problem lies....and solution for same if any ...
shall i reinstall Winxp....
