Re: help choose lappy its urgent
Acer 5740G is one of the best budget gaming laptop available and built quality is also good. 2 of my friends has bought Acer 5740G after my suggestion and I have tested both the laptop u mentioned.
The new Acer laptops are having solid built quality, but not as good looking as Sony laptops are and in any day it is better than the Dell and HP Compaq offering.
It is having very good battery life also, 3 Hrs. Even when watching HD movies battery life is 2 Hrs.
If you want some expert review comments, go to some good sites like AnandTech, NotebookCheck, NotebookReview etc. All of them have highly positive review about this ACER laptop.
And one thing, one may have problem with Acer laptop, but that does not imply anything. I know tons of people having bad experience with Specially Dell laptops.
In case of performance the combination of i5 and HD 5650 is far better than rest of the competition. HD 5470 offered by other manufacturer is an HTPC gfx card, will not be able to play any current games in even medium setting. It is having 80 Stream processors, compared to 400 of HD 5650.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
