Old 30-06-2010, 05:30 PM   #1 (permalink)
Default Pc hangs frequently
My friend is using intel pentium D 2.66 on asus P5RD1-VM board with 2gb ddr1 ram and 160GB sata HDD. When he uses his PC it just hangs for some seconds and stop the working of keyboard and mouse. When he used ubuntu live, there was no problem, when he runs XP problem is less frequent....what do u think the problem might be? I guess its the HDD, but he got it replaced, after using new HDD the same problem started within few days....
Plz give some solution
ani1751 is offline   Reply With Quote
Old 30-06-2010, 05:40 PM   #2 (permalink)
Default Re: Pc hangs frequently
check the HDD & the slot. i using exactly same motherboard with a P4 3Ghz. and i2 faced same problem. my IDE slot's side was broken.
Old 30-06-2010, 05:49 PM   #3 (permalink)
What can i do to check the slot? and as i mentioned the HDD was just replaced...
---------- Post added at 05:48 PM ---------- Previous post was at 05:46 PM ----------
@ sam u got any solution for urself?
I tried all the slots and HDD....nothing wrong except if HDD is ruined again...
---------- Post added at 05:49 PM ---------- Previous post was at 05:48 PM ----------
Old 30-06-2010, 05:57 PM   #4 (permalink)
i guess he using IDE HDD. as sata HDD isn't detected on this particular motherboard.
i simply used the optical drive slot to run both my 250Gb HDD + DVD writer. the primary IDE slot rendered useless. or can say it'll give problem so i better off staying away.
Old 30-06-2010, 10:11 PM   #5 (permalink)
Actually u can detect sata HDD on the board in windows vista and windows 7, using drivers in pendrive. I am sure that he is using sata HDD. Is sata HDD the problem??
Old 01-07-2010, 01:48 AM   #6 (permalink)
about sata i got no idea buddy. i use onboard graphics. so Vista or 7 out of question. add to it ram is only 1Gb.
Old 01-07-2010, 08:31 AM   #7 (permalink)
Wise Old Ghoul
Piyush's Avatar
how old is ur cpu?
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 01-07-2010, 09:19 AM   #8 (permalink)
i guess 3 years
Old 01-07-2010, 09:28 PM   #9 (permalink)
Wise Old Ghoul
Piyush's Avatar
did u ever applied thermal paste between ur cpu and hsf after ur 1st assembed?
if not try it out
but first u should have to clean up the surfaces (i forgot the name of the liquid for cleaning)
--Get Backers
Old 01-07-2010, 09:40 PM   #10 (permalink)
Isopropyl alcohol
Old 01-07-2010, 09:43 PM   #11 (permalink)
Wise Old Ghoul
Piyush's Avatar
Originally Posted by Sam.Shab View Post
Isopropyl alcohol
oh yes
it as one of the alcohol based liquid
but dunno the exact name
thanks for partially making me remember
--Get Backers
Old 05-07-2010, 08:45 AM   #12 (permalink)
yea, i applied paste. BTW what does it do?
Old 05-07-2010, 10:33 AM   #13 (permalink)
Super Moderator
asingh's Avatar
When the HSF and CPU heat spreader surfaces make contact, the join is not 100% integral. There will be minute air gaps. This material fills those gaps so the heat dissipation is proper.
asingh is offline   Reply With Quote
Old 06-07-2010, 09:04 AM   #14 (permalink)
Okay....thats smart...
Old 10-07-2010, 04:33 PM   #15 (permalink)
Robert Gentle
Posts: n/a
Red face Re: Pc hangs frequently
Hello ani1751,
There may be some hardware compatibility problem. You don't change your HDD, just change your motherboard of INTEL essential series with same processor intel pentium D 2.66. Right It may be solve your problem.
Regards..
Digital Signage
Windows 7 hangs on boot screen(starting windows) sarangbokil.23 Software Q&A 4 01-06-2010 08:08 PM
Systm getting restarted very frequently.... mack1983 Hardware Q&A 8 14-05-2010 10:17 PM
Internet Disconnect frequently jrkraj Software Q&A 5 29-03-2010 09:00 PM
My PC Hangs or Re-start frequently Rajibchakma Hardware Q&A 5 12-02-2007 09:40 PM
system hangs frequently , sufficient memory shreyadr QnA (read only) 5 26-04-2005 06:20 PM
- by kool
- by ax3
