Old 30-06-2010, 08:58 AM   #1 (permalink)
spm
Default confused by biostar.
from u guys i know that the biostar TA785G3 HD is a nice MB. then i check out there website and am confused abount all the different models they have with the 785g chipset
1. TA785G3 HD
2. TA785G3+
3. TA785-A3
4. TA785G3
5. A785G3.
i just wanna know whats the difference between these boards and which one of them have the sideport memory and what type of memory do they have (ddr3, ddr2, like that). most of them have two revisions as in the biostar site whats the difference between them.
and the final thing is how good is this sideport thing provided i will not be going for discrete graphics priced more than Rs 4000.
thanks in advance friends
spm is offline   Reply With Quote
Old 30-06-2010, 09:06 AM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: confused by biostar.
since you will be using discrete graphics you want need sideport memory. only the first has that...its used when you are not going with discrete graphics and thus the igp uses sideport instead of the ram....
1 suggestion go with first mobo, use onboard graphics(they are pretty much good), save upto 5200 and blow it on hd5670...
Jaskanwar Singh is offline   Reply With Quote
Old 30-06-2010, 09:11 AM   #3 (permalink)
spm
ok
i hear that a lot about the saphire hd5670 cards. they must be so good i believe.
BTW what about this mobo
TA785GE 128M
they say it also has sideport memory. whats the difference between this and the TA785G3 HD
Old 30-06-2010, 09:19 AM   #4 (permalink)
TA785GE 128M supports only 125W proccy and old DDR2 ram...
HD one supports 140W proccy and DDR3 ram...
Old 30-06-2010, 09:26 AM   #5 (permalink)
spm
OH THANKS buddy.
what type is the memory used is it ddr3 in TA785G3 HD
Old 30-06-2010, 09:27 AM   #6 (permalink)
Originally Posted by spm View Post
OH THANKS buddy.
yup........
Old 30-06-2010, 09:47 AM   #7 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
TA785G3 - 125W proccy support, 2 DDR3 DIMM slots, mATX
TA785G3+ - 125W proccy support, 4 DDR3 DIMM slots, mATX
TA785G3 A3 -125W proccy support, 4 DDR3 DIMM slots, ATX, 3 PCI slots
TA785G3 HD - 140W proccy support, 4 DDR3 DIMM slots, 128MB DDR3 sideport
mATX
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 30-06-2010, 09:53 AM   #8 (permalink)
mATX
correction-- TA785 A3
Free disk space in system drive.. Really confused... rohit330 Open Source 5 15-06-2010 07:34 PM
I am very Confused..need your Advise my Friends insaneYLN Career Planning and Progression 10 01-06-2010 02:11 PM
confused between samsung spica and Nokia N79 vinit suri Mobiles and Tablets 5 27-05-2010 12:46 PM
confused between zune hd & sony X series walkman karthik55859 Hardware Q&A 4 06-02-2010 12:06 AM
- by kool
- by ax3
