Re: Intel DH55TC or DP55WB ?
The DP55WB is a P55 chipset, so it will need a discrete VGA. Either get a separate GPU, or give it back to your dealer. DO NOT dock the I3-530 on this to even try or experiment.
Side note:
Your dealer knows jack-squat. Stop using him, else give him a list of component parts (we can help you here), and tell him "ONLY GET THESE MODEL NUMBERS -- NO SUBSTITUTE OR SELF RECOMMENDATION". End of the day 99.99% of Indian dealers are a$$-holes of the highest order who try to rip you off and/or get rid of inventory.
