1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that) - Casual to Serious Gaming,Video Encoding
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why? - yap anything that is available in Kolkata
3. What is your MAX budget? - 14K
5. Which OS are you planning to use? - Windows 7,xp sp3
6. How much hard drive space is needed? - as much as possible
7. What resolution will the screen run at & whats the size of the screen?i will buy a benq E2220HD So may be 1980x1020
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest) - 6
9. Have you ever built a desktop before or will this be done by an assembler? - no,assembler
10. When are you planning to buy the system? - ASAP
11. Are you one of the types looking out for "future proof" configurations? - Sure
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention. - KB,Mouse,VDU,Speaker,UPS
13. Which city do you live in and are you open to buying from shops from other city/states? Kolkata ,Nope
14. Mention any other points if deemed necessary - DDR3 RAM Plz
