Old 28-06-2010, 09:39 PM   #1 (permalink)
Smile Please for purchasing New PC
Hi guys can u help me for purchasing new PC
1. What is your MAX budget:
40 K
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers: Yes
3. What is the purpose of the computer:
Software Development ( Like to run Oracle, Sql Server, Dotnet, SSRS) and sometimes gaming
4. Planning to overclock: 3
5. Which OS are you planning to use: Window 7
6. How much hard drive space is needed: 500 GB
7. What resolution will the screen run at: 19"
8. How would you rate your hardware knowledge from the count of 1-10
5
9. Have you ever built a desktop before or will this be done by an assembler: Yes
10. When are you planning to buy the system: This week
11. Are you one of the types looking out for "future proof" configurations: Yes
12. Are there going to be any components that you don't want to include in this new rig: No
13. Which city do you live in and are you open to buying from shops from other city/states? Delhi
14. Mention any other points if deemed necessary: No
rpsingh is offline   Reply With Quote
Old 28-06-2010, 10:27 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Please for purchasing New PC
Phenom II X6 1055T 2.8GHz @ 9.6k
MSI 890GXM-G65 @7.2k
Kingston 2GB DDR3 1333MHz * 2 @ 5.1k
MSI HD5770 HAWX 1GB GDDR5 @ 9.6k
Samsung 500GB SATA @ 1.8k
Corsair VX450W @ 3.8k
NZXT Gamma @ 2k
Total - 39.1k
Jaskanwar Singh is offline   Reply With Quote
Old 29-06-2010, 11:45 AM   #3 (permalink)
thanks for ur reply...
one question like to ask, i heard somewhere that AMD processors are not gud..
is it right or any limitation with AMD processors
Old 29-06-2010, 01:22 PM   #4 (permalink)
Cool G5's Avatar
That's not at all right. If they were bad why would many overclockers & enthusiast PC users use them anyway. I'm myself an AMD user & I'm not saying AMD is good because I use it but because I have even used Intel earlier on. AMD provides great value for money when compared to an Intel counterpart. In your budget settle for an AMD system itself.
Cool G5 is offline   Reply With Quote
Old 15-07-2010, 05:31 PM   #5 (permalink)
I am unable to find at Nehru place
Corsair VX450W, NZXT Gamma
Old 15-07-2010, 06:43 PM   #6 (permalink)
try finding FSP saga II 500W and CM elite 310
DO NOT SETTLE FOR CM EXTREME POWER PSU
Old 16-07-2010, 11:45 AM   #7 (permalink)
Thanks for ur suggestion.
I am also unable to find MSI HD5770 HAWX 1GB GDDR5 , is there any other option.
Old 16-07-2010, 12:25 PM   #8 (permalink)
Sapphire/powercolor
Old 16-07-2010, 01:34 PM   #9 (permalink)
thanks for ur quick reply ... I want to ask one more thing the above given rates are tax inclusive or not
Old 16-07-2010, 02:22 PM   #10 (permalink)
What config have you decided on finally ?
spacescreamer is online now   Reply With Quote
Old 16-07-2010, 08:29 PM   #11 (permalink)
you have to check the prices yourself at your place also
Old 16-07-2010, 10:00 PM   #12 (permalink)
Techie By Heart
mavihs's Avatar
Corsair vx450is available but NZXT isn't. if you want the NZXT cabby, you'll have to order it from Mumbai from primabgb or itwares!
if you can wait 1 week then you might be able to be get it, i enquired about it, even my friend needs it!!!
if you want i can help you out getting it!!!! :-P
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 17-07-2010, 04:49 PM   #13 (permalink)
Yeah Corsair vx450W is available.. but how i will get NZXT cabby..and that grapics card
Old 17-07-2010, 09:08 PM   #14 (permalink)
try SMC. they should have it.
a costlier alternate to Corsair VX450W is CoolerMaster GX550W. not so good but the price is nice one. but try Corsair first.
forget NZXT. theres many better choice available.
Old 18-07-2010, 02:25 AM   #15 (permalink)
Techie By Heart
mavihs's Avatar
NZXT you'll have to ship it from Mumbai as i wrote above but it'll cost you above 2.5K including shipping!
already checked, its not available anywhere!!!!
like?
Old 18-07-2010, 04:41 PM   #16 (permalink)
The Assassin
Cybertonic's Avatar
Who says MSI HD 5770 HAWK is not available check at
MSI 5770 HAWK
Cybertonic is offline   Reply With Quote
Old 18-07-2010, 04:58 PM   #17 (permalink)
Techie By Heart
mavihs's Avatar
MSI 5770 HAWK
as i said before, its not available!!!! forget the site!
Old 18-07-2010, 08:27 PM   #18 (permalink)
Originally Posted by mavihs View Post
like?
Cooler Master Elite series or Thermalright. many don't like the Gamma. Gamma/M59 is a personal favorite of mine but many show dissatisfaction over its peculiar design.
MSI 5770 HAWK
don't go by their site. its not updated.
Old 19-07-2010, 01:59 AM   #19 (permalink)
Techie By Heart
mavihs's Avatar
Personally i hate the Elite Series for there design & air flow, etc!
which one are you suggesting from Thermalright?
Old 19-07-2010, 03:23 PM   #20 (permalink)
hi guys thanks for replies and suggestions..
I am confused about cabinet and power supply which one is good
and support above given config.
Old 19-07-2010, 03:28 PM   #21 (permalink)
Techie By Heart
mavihs's Avatar
are you planning to OC or not?
Old 19-07-2010, 04:15 PM   #22 (permalink)
i have no idea about OC, whats advantage or disadvantage of it..
Old 19-07-2010, 05:33 PM   #23 (permalink)
in short, Elites sucks.
Thermalright Wing. i think theres 2 model priced at around 2.5k. a better alternate to NZXT Gamma without opting for CM Elites.
Old 19-07-2010, 05:58 PM   #24 (permalink)
Techie By Heart
mavihs's Avatar
you mean Thermaltake! Wing has 3 - 4 model, which model are you referring to? Also will it be available here?
Old 19-07-2010, 08:35 PM   #25 (permalink)
the most cheapest one. seen in Lynx. SMC told they can arrange one for me if i need. but went for NZXT from IT wares instead.
Old 19-07-2010, 09:54 PM   #26 (permalink)
Techie By Heart
mavihs's Avatar
don't trust Lynx, its got really bad reputation!
even the OP can buy the Gamma from ITWares only then!!!
Old 19-07-2010, 10:29 PM   #27 (permalink)
itwares charges 1k shipping for gamma
Old 19-07-2010, 10:56 PM   #28 (permalink)
Techie By Heart
mavihs's Avatar
then he can buy from primeabgb.com!
Old 20-07-2010, 12:08 AM   #29 (permalink)
yes i know so use Lynx just as reference point for products available here as well as rough idea of pricing.
Old 21-07-2010, 05:29 PM   #30 (permalink)
I am going to purchase cooler master 690 and corsair vx450W..
and planning to purchase graphics card for next month as my budget exceeds.
is that right...
- by kool
- by ax3
