Old 27-06-2010, 04:45 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Red face Use beetel 450TC1 adsl modem as only a wifi router
Hi Friends,
I'm in a big need and so am resolving to ask the experts. I have a beetel 450TC1 (http://www.pcwintech.com/screenshots-be ... l-firmware) on which my airtel broadband is configured. Now i have shifted to beam cable, which provided me only with a lan cable thru which i am able to connect. What i want to do now is to use the wireless modem by airtel (beetel 450TC1) and use it's wifi capibilities to make my beam connection available via wifi. I don't know how to turn off ADSL on the modem and configure it the right way. Anyone has done it, any idea?
Thanks a lot in advance.
Anirudh
krazineurons is offline   Reply With Quote
Old 27-06-2010, 07:47 PM   #2 (permalink)
Default Re: Use beetel 450TC1 adsl modem as only a wifi router
It would actually depend upon whether your router supports DHCP relay and allows you to use only the "wifi + switch" part. I really don't think that Airtel's ADSL + Wifi routers provide such options.
If you had a Linksys or a D-link ADSL + Wifi router, you would have still had a chance.
The "easy" and also the "real-world" solution would be just buy a standard Wifi router imho.
Old 28-06-2010, 03:18 AM   #3 (permalink)
AAAAAAARGHH
450TCI does support DHCP relay...
I think you can do this..
diabolicdude is offline   Reply With Quote
Old 06-10-2010, 09:51 AM   #4 (permalink)
i am also looking for same solution.if you know how to configure it then please share the solution with us.
Thanx
sunil2singh is offline   Reply With Quote
Old 12-06-2011, 07:21 AM   #5 (permalink)
Smile Re: Use beetel 450TC1 adsl modem as only a wifi router
hi i done it i am connected three systems one is desktop, which is connected to internet using mobile dialup, and 2 laptops using wifi. I am define a ip to desktop and this ip used as gateway in laptops systems shows connected but a problem is in this system i can access only google server using google ip and if this ip put in proxy address in internet explorer then only google opening using url.
Question is how can i access all sites on laptops and what settings are i missed? please help me.
abc2009xyz is offline   Reply With Quote
Old 12-11-2011, 11:27 PM   #6 (permalink)
ajayritik's Avatar
Sorry for bumping into an old thread even I'm looking for something like this.
ajayritik is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/128789-use-beetel-450tc1-adsl-modem-only-wifi-router.html
Thread how can I get the User manual for Beetel 450Bx ADSL+2 Router | TechArena Community - Technology and Computer Hardware Support Forums of India | BoardReader This thread Refback 15-06-2011 09:00 AM
HELP : BSNL wifi router WA3002G4 on/off automatically after some time esumitkumar Hardware Q&A 6 01-07-2010 11:17 PM
Good WIFI N series router abhinav_bipnesh Hardware Q&A 7 28-06-2010 09:40 PM
Need help in setting up Belkin Wifi Router dreamcatcher Chit-Chat 0 24-04-2010 01:21 PM
Internet Connection in Linux via Mobile Manshahia Open Source 108 16-01-2009 10:48 PM
- by kool
- by ax3
