Old 27-06-2010, 11:43 AM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Default UPS charging
Im using APC Back-UPS RS 550 ups. So will it charge if I only plug ups to wall socket with ups power off, or should I turn ups power on?
IronCruz is offline   Reply With Quote
Old 27-06-2010, 11:53 AM   #2 (permalink)
The Unknown's Avatar
Default Re: UPS charging
It doesn't matter whether the UPS is on or off. You can use your computer while its charging.
KDE on ArchLinux
The Unknown is offline   Reply With Quote
Old 27-06-2010, 01:47 PM   #3 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
No not like that. If I want to charge my ups should I turn on the ups or it ll charge even its off?
Old 27-06-2010, 01:52 PM   #4 (permalink)
You just have to put its cable in the main socket. It doesn't matter whether the switch in front of your UPS is on or off. It will always charge (or not charge if battery is full) when the main supply is on.
KDE on ArchLinux
Old 27-06-2010, 02:14 PM   #5 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Ah! Thanx dude.
UPS (Uninterruptible_power_supply) and UPS battery Buying Advice? Help Digitians!!! RajivKumar123456 Hardware Q&A 6 02-07-2010 11:41 PM
UPS issues a_k_s_h_a_y Hardware Q&A 7 05-04-2010 08:27 PM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
Is 500V UPS enough? Knight QnA (read only) 35 08-01-2005 07:52 PM
- by kool
- by ax3
