Old 27-06-2010, 02:57 AM   #1 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
Default Got 40k for New Animation rig (Amd)Part -2
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that) Animation & VFX (First prefrence) & Gaming(COD, MOH,ALPHA PROTOCOL, Single person shooting games)
Software which i will work on :- Abobe:- Photoshop,Premiere, Affter effects.
Autodesk :- Maya + Dynamics, Mudbox, Sketchbook pro,Soft Image, Motion Builder.
Others :- Nuke, Fusion
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?Yes Plz Suggest
3. What is your MAX budget?40k (Dad allows only upto this) maximum 42k
4. Planning to overclock? Yes but at Stock HSF
5. Which OS are you planning to use? Win 7 x64 & win Xp X64 Sp2
6. How much hard drive space is needed? 500 GB(already have 80+ 500gb segate Barcuda)
7. What resolution will the screen run at & whats the size of the screen? Already have LG 19" wide (1440x 900)
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest)7.5
9. Have you ever built a desktop before or will this be done by an assembler? Assemble myself(if they are offering free assembling then i don't mind)
10. When are you planning to buy the system?within 3-4 days( I need NZXT Gamma cabby first then the rest of components)
Atleast for next 3-4 years.
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention. DVD-Rw,Monitor, Speakers
13. Which city do you live in and are you open to buying from shops from other city/states? Delhi, Nehru Palace
Previously I had extra 2k but now i spent them . I made a config in mind
Processor - AMD Phenom x6 1055t @ Rs.10000
Motherboard - MSI 890 gx -65 @ Rs.7200
Ram - G-Skills Ripjaws 1600 Mhz or Plz Suggest Cosair rams.@ Rs.6800
GPU - Sapphire 5670( please tell me what is the difference between msi nd sapphire.is sapphire have a good heatsink?) @ Rs.6500
SMPS -Cosair gx 550@ Rs.4750
Cabby - Nzxt Gamma (don't to abt its availablity in Nehru Palace, SMS Guys told the have ordered 50 Cabby but no news mail from there side abt is availablity , anyone plz conform)@ Rs. 2400 (maximum affordable price)
HDD- Wd claviar Blue 500 G.B.@ Rs. 2000
All suggestion are welcomed to improve my Rig .
Previously thanks to Sam.Shab
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Old 27-06-2010, 07:29 AM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Got 40k for New Animation rig (Amd)Part -2
get this -
Phenom II X6 1055T 2.8GHz @ 9.6k
MSI 880GMA-E45 @6k
Corsair 4GB DDR3 1600MHz C9 Titanium @ 6.8k
Samsung 500GB SATA @ 1.8k
Corsair VX450W @ 3.8k
NZXT Gamma @ 2k
Total - 30.2k
NOT SURE ABOUT THE GRAPHICS CARD (SINCE YOU ARE BOTH INTO ANIMATION AND GAMING) WAIT FOR OTHERS SUGGESTIONS.
Jaskanwar Singh is offline   Reply With Quote
Old 27-06-2010, 12:14 PM   #3 (permalink)
change the bold marked items:
1. why are you paying so much for those ram kits? get some value rams. that will do it.
2. MSI uses an open cooler. Sapphire uses Arctic Cooler. difference is Sapphire's cooler runs little extra silent. cooling is same in both. get 512Mb. well 1Gb card will be helpful cause the apps you mentioned all will be heavy on the ram as well as the graphics.
3. thats totally not needed. get VX450W or something like FSP Saga II 500W (provided you find it). moreover i think its Cooler Master which have a series known as GX
NOTE: you getting a 890GX motherboard. you may go with a single HD5670 512Mb for now. and add another in Xfire setup later, when Nvidia outs its GT420-440 cards. or you can do 1 thing. add a 9400GT for Physics (if your apps utilize it. they should. but games will welcome it openhanded)
Old 27-06-2010, 07:57 PM   #4 (permalink)
CG Artist++
Thanks Jaskanwar nd sam for ur best config , ... I will go to nehru palace for price estimate 2marrow nd by it on tuesday . Final Config .
GPU - Sapphire 5670@ Rs.6500(512 mb ver. is nt available in whole nehru palace)
SMPS -Cosair vx 450 @ 3800
Cabby - Nzxt Gamma@ 2400
Ram- Still Confused as facilty suggest go for performance ram but sam suggested value ram, Please put some light on it , becuase it one time purchase for next 3 years.also please tell which is better Cosair C9 Titanium or G-skills ripjaws ?
Old 27-06-2010, 08:04 PM   #5 (permalink)
i'll suggest change the card to GTS250 512Mb. cause 1Gb is waste. moreover HD5670 isn't a very powerful card for DX11 gaming. it'll spoil everything.
as for ram, if you can go with the ripjaws. if you can include them in your budget.
Old 27-06-2010, 08:32 PM   #6 (permalink)
CG Artist++
why gt 250 , wat if i overclock 5670 .Can i play dx 11 cards on dx 10 cards ?
SMC now selling Gskill Ripjaws 1600 Mhz 4 GB DDR3 Kit @ Rs6,200.00
Link Gskill Ripjaws 1600 Mhz 4 GB DDR3 Kit
Old 27-06-2010, 08:43 PM   #7 (permalink)
HD5670 fits between GT240 1Gb & GTS250 512Mb. OC it & it only narrows the gap to GTS250. if you use it on a 19" monitor, gaming is possible. but turn DX11 mode on (on games that support GX11) the card immediately falls behind all its competitor. so if DX11 you want, go with the cheapest HD5770.
that price is a killer one. well can go for those.
Old 27-06-2010, 09:14 PM   #8 (permalink)
CG Artist++
thanks sam bhai ....
Old 27-06-2010, 09:21 PM   #9 (permalink)
my pleasure buddy
Old 27-06-2010, 09:26 PM   #10 (permalink)
CG Artist++
new config made suggest me if i am wrong anywhere
Name SKU Price Subtotal
AMD Phenom II X6 1055T Rs 10,250.00
MSI 890GXM-G65 Rs 7,200.00
Gskill Ripjaws 1600 Mhz 4 GB DDR3 Kit Rs 6,200.00
WD 500GB Caviar Blue HDD Rs 2,050.00
CM 690 II Advanced Rs 5,600.00
MSI N250GTS-2D1G Rs 7,450.00
Cooler Master GX 550 Rs 4,500.00
Subtotal: Rs 43,250.00
Total: Rs 43,250.00
Old 27-06-2010, 10:12 PM   #11 (permalink)
Total: Rs 43,250.00
so costly cabinet?
also don't go for HD5750 how much they force you to. its a bad card. and more badly priced. also for the card keep it as it is. don't go for 512Mb. lacks firepower a bit.
Old 27-06-2010, 10:21 PM   #12 (permalink)
Wise Old Ghoul
Piyush's Avatar
so costly cabinet?
may be the cabinet is of transparent sidepanel
and CM advanced is a superb cabinet
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 27-06-2010, 10:49 PM   #13 (permalink)
CG Artist++
so costly cabinet?
Delhi ka temp pata hai sam bhai(extremeLy hot, I don't have a ac in my room ) ...Currently my Cpu temp is 60 degree , I will buy this cabby only if NZXT Gamma Not available with them .
---------- Post added at 10:49 PM ---------- Previous post was at 10:39 PM ----------
Cabinnet is this one CM 690 II Advanced
the cabby have 2 models wit side window/ without side window,plz sugget for which 1 i will go for.
Don't worry Sam Bhai i will not buy 5750, its better to stick with IGp then 5750 , i know 5670 will give the same performance if overclock . I know once the sardarji will defently suggest me to go with 5750 as he want to sale amd products with 1st preference.
Old 27-06-2010, 11:55 PM   #14 (permalink)
Wise Old Ghoul
Piyush's Avatar
go for transparent side panel if u r looking for good looks
otherwise the plain vanilla is best suited for you
--Get Backers
Old 28-06-2010, 12:15 AM   #15 (permalink)
CG Artist++
it will be hide in computer table so i don't think tranparent one will have any advantage for me, beekar mein extra paise spend karne ka khya faida.
Old 28-06-2010, 01:11 AM   #16 (permalink)
ha. pata hain. been to Delhi last year only. thankfully not in months of June-July
than i think cabby choice is good.
yup. than its wastage. stick to non transparent panel. but sell out the extra money in adding fans
Old 28-06-2010, 09:32 PM   #17 (permalink)
CG Artist++
Today i went to SMC and Computer Empire Nd got the price as follows.
MSI 890GXM-G65 Gskill Combo Set @ Rs.16800 SMC
Ripjaws 1600 Mhz 4 GB DDR3 Kit Rs 6400 SMC ( online price is 6200 , order Online)
WD 500GB Caviar Blue HDD Rs 2,000.00 SMC
CM 690 II Advanced Rs 5,500.00 SMC
MSI N250GTS-Twin forz /MSI 5770 Hwak 7500/9400 Computer Empire
COsair VX 550 Rs 4,650.00 Computer Empire
Total: Rs 35350 Excluding GPU.
Please suggest me a gpu, Should i go for 5670, or gts 250 512 mb
Please suggest me soon as i will buy it 2marrow
Old 28-06-2010, 09:43 PM   #18 (permalink)
Wise Old Ghoul
Piyush's Avatar
the prices are decent
go grab them
anyways 1 week ago i also bought a system from SMC
--Get Backers
Old 28-06-2010, 10:14 PM   #19 (permalink)
please clarify the price of the graphics card. unable understand what you written
also i'll simply suggest get VX450W or GX550W (don't get scared seeing the size )
Old 28-06-2010, 10:42 PM   #20 (permalink)
CG Artist++
MSI 5770 @9.4K ND GTS 250 @7.5 K which one is better , should i go 4 gts 250 512 mb or sapphire 5670 1 gb anyone intrested in Zotac Geforce 9300 gs mobo purchared @6.5 just 5-6 month old nd 4.5 years warranty left(2 year extended warranty) only @5 k with bill ne extended warranty .
---------- Post added at 10:42 PM ---------- Previous post was at 10:40 PM ----------
don't worry sam i have seen it before
Old 28-06-2010, 10:44 PM   #21 (permalink)
Wise Old Ghoul
Piyush's Avatar
if u have that budget then u can opt for 5770
otherwise go for 5670 and OC it if u feel so
--Get Backers
Old 28-06-2010, 10:52 PM   #22 (permalink)
laborare est orare
Cilus's Avatar
Total: Rs 43,250.00
1st of all, why going for such expensive Hi-Speed Ram? AMD Phenom II series does support DDR3 memory controller, but their memory controller's speed is not as fast as their Intel Core series counter parts. You will only have negligible performance improvement, as slower memory controller of Phenom II series cannot take advantage of the hi speed memory.
Instead go for 4 GB value Ram at 5.2k and with the rest of the money go for a HD 5770.
GTS 250 is a good card, but they are near to obsolete now. Their availability and quality may not be up to the mark right now.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 29-06-2010, 06:08 AM   #23 (permalink)
CG Artist++
valuable ram is for Rs. 5700 nt a major price difference,one more does overclocking void warranty?
Old 29-06-2010, 05:56 PM   #24 (permalink)
Techie By Heart
mavihs's Avatar
have you bought it yet or planning to buy 2moro?
if OCing don't go fro value RAM! OCing does void the warranty but it really doesn't matter in India coz they really can't find out if it was OCed or not!
Also you got low budget for a workstation! are you learning animation & from where?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 29-06-2010, 10:58 PM   #25 (permalink)
CG Artist++
i purchased my pc today nw installing os on it .thanks to everyone for your suggestions ne config.i will post the price tommarrow nd the pics after 3 july.mavihs bhai i am learning nw nd from frameboxx south ex.
Old 30-06-2010, 12:01 AM   #26 (permalink)
Techie By Heart
mavihs's Avatar
how about meeting sometime....i live pretty close by!
btw i'm also learning Animation!
Old 02-07-2010, 02:39 AM   #27 (permalink)
CG Artist++
System Purchased hee is the final config.
AMD Phenom II X6 1055T 2.8 ghz RS.10,100
MSI 890GXM-G65 890 gxm G65 RS7,200.00
G.Skill Ripkaws F3-10600 1600MHz CL9 2GB1600mhz RS6,200.00
Segate Barcuda 5000 g.b 500GB RS 2,000.00
Cooler Master 690 II Advanced RS5,500.00
Cosair VX 550W Rs.4600.00
Purchased 2*120MM Cooler Master(Non-Led) fans Rs. 400(both)
Total Rs.35800
Purchased from SMC International (Nehru Place_.I will Post Images Soon.
@Sure, From where u r pursuing ur animation , is it a diploma or degree?
Old 02-07-2010, 07:36 AM   #28 (permalink)
Wise Old Ghoul
Piyush's Avatar
Total Rs.35800
congrats
did u got that vx 550w from smc too?
--Get Backers
Old 02-07-2010, 07:48 AM   #29 (permalink)
CG Artist++
congrats
yeah , they have one in there stock as i already informed mr. Saini for this.
Old 02-07-2010, 07:55 AM   #30 (permalink)
Wise Old Ghoul
Piyush's Avatar
nice
and did asked about any NZXT cabinets there?
--Get Backers
New Rig @ 38k Vensanga Hardware Q&A 16 15-04-2010 01:01 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
Career in 3D animation. Help! abhi.eternal QnA (read only) 11 25-09-2007 02:15 PM
Indian Animation Sector Booming up ! Are you ready ! devauniversal Technology News 3 05-07-2007 04:58 PM
- by kool
- by ax3
