26-06-2010, 02:11 PM
Intel Only: Gamin PC @40-45K
Dear All,
Plz suggest me some INTEL based config only for a Gaming application. It should run all the latest games, I'm not going to overclock it.
Please suggest i5 or Quad core config preferably.
Please also tell if I go for an i7 based gaming PC then how much should I stretch my Budget?
Please DO NOT SUGGEST ANY AMD CONFIG.
Intel has wide support when it comes to latest Hardware/Software/Games/Updates.
26-06-2010, 02:34 PM
Re: Intel Only: Gamin PC @40-45K
please fill in this--
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is your MAX budget?
4. Planning to overclock?
7. What resolution will the screen run at & whats the size of the screen?
---------- Post added at 02:29 PM ---------- Previous post was at 02:22 PM ----------
there is no such thing.
softwares run as good on amd configs as on intel.
while intel keeps on changing sockets amd has provided new processors for previous sockets and they are great proccys.
amd phenom x6 beats core i7 in multi threaded apps while the later is good for gaming. each has its own pros and cons.
---------- Post added at 02:34 PM ---------- Previous post was at 02:29 PM ----------
moreover amd is great vfm. phenom 2 x6 1090t provides 2/3 of the performance of core i7 980x at a price which 1/3 the price of the later.
26-06-2010, 02:48 PM
Engineering Stuff & Gaming.
NO. Plz suggest Intel i5/Quad core/i7 config only.
40K to 45K for i5/Quad core. Plz tell budget for i7.
Not at all.
Windows XP or Windows 7
500GB.
Anything above 17" LCD.
8.
I have built it my own.
Within a month.
Somewhat for 3 years at-least.
NA
From Mumbai only.(It has it all)
---------- Post added at 02:48 PM ---------- Previous post was at 02:45 PM ----------
Whatever may be the reasons but I want INTEL only.
All of ur suggestions to people are for AMD PC only & appears that u are reluctant to suggest INTEL config, whereas 80% of the WORLD uses it.
26-06-2010, 02:58 PM
Core i5 750 @ 9.5k
Gigabyte GA-P55M-UD2 @ 7k
Kingston 2GB DDR3 1333MHz * 2 @ 5.1k
MSI HD5770 HAWX 1GB GDDR5 @ 9.6k
Samsung 500GB SATA @ 1.8k
Corsair VX450W @ 3.7k
NZXT Gamma @ 2k
BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
Logitech Keyboard & Mouse @ 0.7k
Total - 47k
26-06-2010, 03:03 PM
I am the night! I am....
Dude i agree with you completely. 80% world users are intel but amd's recently launched procyy's are good vfm if you see the reviews and pricing.
Its true that amd's architecture stands nowhere near intel's gulftown which is highly efficient core per core but intel's pricing makes it out of reach for 90% buyers to reap the benefits.
About your config. go through my signature and change the board to msi p55 cd53 & gpu to either 5670 or 5770(your choice).
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
26-06-2010, 03:33 PM
SEE THIS RIG---
Phenom II X4 955 3.2GHz B.E. @ 7.9k
Gigabyte GA-MA785GMT-US2H @ 4.6K
Sapphire HD5850 1GB GDDR5 @ 15.8k
Cooler Master GX-550W @ 4.2k
NZXT Gamma @ 2k
Total - around 48k
at the same price you are getting a better graphics card for gaming and a processor thats just behind i5 750.
if getting i5 DO NOT GO for H55/H57 chipsets. they are useless.
26-06-2010, 04:11 PM
little explanation on this topic will be helpful.
26-06-2010, 04:36 PM
bORn To RIse....
F.A.N.B.O.Y
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
26-06-2010, 05:04 PM
Core i5 750 @ 9.5k
NZXT Gamma @ 2k
Total - 47k
Excellent man. good config
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
27-06-2010, 06:44 AM
What The.... !!!
Core i5 750 @ 9.5k
NZXT Gamma @ 2k
Total - 47k
Jaskanwar singh's rig is a very potent one indeed
but i feel it is a bit processor centric
i have made a few subtle changes if his concern is gaming
CORE I3 530 5.5k
POWERCOLOR HD 5850 15k
tis way he can have the best of both worlds
the op can change the proccy to accomodate the i5 750 in the future
27-06-2010, 07:08 AM
CORE I3 530 5.5k
dude even an athlon 2 x4 630 will be better then core i3 in the future. the rig that i mentioned second time is in my opinion better than the first one.
27-06-2010, 07:59 AM
What The.... !!!
no , the athlon II X4 630 is not better than Core I3 530
see anandtech.com CPU bench
http://www.anandtech.com/bench/CPU/2
http://www.anandtech.com/bench/Product/118?vs=122
you'll see that core I3 beats the hell out of ATHLON II X4 635
also coming little lower than none other than phenom II X4 940
Athlon II X4 and X3 are poor man's choice(read budget builders with cost constraints)
the combo i suggested is a much better piece of hardware for his money
you'll see
The Athlon II X4 is not as vfm as athlon IIX3
if you have a budget of 11k on the MOBO-PROccy combo,
it is better to have I3 530
also check out this link
it lets you compare the performance of (based on FUTUREMARK)various sytem combinations
Gigabyte System Builder
27-06-2010, 08:12 AM
dude listen, at present athlon is better in multithreading and i3 is better in gaming as most of the games hardly use more than 3 cores.
but as more and more games become multithreaded in future a quad core will benefit.
in gaming also there is a difference of 6-7 fps at present.
see this
27-06-2010, 08:31 AM
What The.... !!!
just because athlon II x4 has more cores for the same price and maybe a 100mhz speed bump,
doesnt mean that it is better than I3 530
i am not a F.A.N.B.O.Y
neither is the op
but we have reasons to trust INTEL with our precious hard earned money
I am going for athlon II x3 440 in my own build only because of budget constraints
no other reason
Personally i think PHENOM II is an over hyped series
the only VFM in amd seems to be athlon IIX3 series
P.s.
Intel manages to kick the **** out of AMD even in terms of power consumption and temperature[COLOR="Silver"]
---------- Post added at 08:31 AM ---------- Previous post was at 08:19 AM ----------
see this
we have not seen the future yet
all we have is the present
all we can do is speculate about the future
i heard this same argument in 2008 when the phenom(first gen)was released
but look at all the future readiness(of 2008) with quad core phenom now in 2010.compared to the core 2 duos available then
the best we can do is being PRESENT READY
AND HOPE TO HELL THAT WE ARE READY FOR THE FUTURE
27-06-2010, 09:13 AM
ok, please give me the reasons why you prefer core i3.
---------- Post added at 09:07 AM ---------- Previous post was at 09:04 AM ----------
i will just say 1 thing --- comparisons tell everything. go the anandtech site i have mentioned.
---------- Post added at 09:11 AM ---------- Previous post was at 09:07 AM ----------
ok you mentioned the comparison on the gigabyte website--
i compared athlon 2 x4 635 and gigabyte ga ma785gmt ud2h WITH core i3 530 and gigabyte p55m ud2. see the results.
athlon -
3d marks - 10687
price - 522 $
core i3 -
3d marks - 10355
price - 528 $
now answer??
---------- Post added at 09:13 AM ---------- Previous post was at 09:11 AM ----------
athlon 630 is just 100mhz slower than 635, so imagine its results on your own.
635 and i3 530 are prices identically.
What The.... !!!
1.Brand Value
2.Lower Temp(compared to athlon II x4 635)
3.better performance(in games and also in productivity)
4.better overclockability
5.more and more game manufacturers are biased towards intel(HELL! they should be as the op pointed out 80% of the world uses intel)
6.do i really need to say more?
my point is
go for amd if you budget constrains you to only 8k in combo)
27-06-2010, 09:15 AM
see the above scores and tell me dude
27-06-2010, 09:27 AM
brand value ?? whats that ? Buy INTEL, neighbors envy ??
27-06-2010, 09:59 AM
#19 (permalink)
see the passmark score--
athlon 2 x4 630 - 3361
athlon 2 x4 635 - 3360
core i3 540 - 2869
core i3 530 - 2722
27-06-2010, 10:10 AM
#20 (permalink)
arey leave it JAS, we can only suggest. Its up to the OP to buy whichever he wishes to.
27-06-2010, 10:35 AM
#21 (permalink)
What The.... !!!
athlon -
3d marks - 10687
price - 522 $
core i3 -
3d marks - 10355
price - 528 $
now answer??
dude
you are so so so Wrong!
i3 530 combo shows 11273
(Intel Core I3 530+GA-P55M-UD2+HD5770)@387.99$
or if you go for H55 MOTHERBOARD(GA-H55M-S2H)same score FIY
it is 372$
while athlon 635 is 10676
(Athlon II X4 635+GA-785GMT-UD2H+HD5770)@381.99$
check out the attachments if you dont believe me
27-06-2010, 10:45 AM
#22 (permalink)
What The.... !!!
now the question is
are you willing to bypass the much better offer from intel just to save 300 bucks or so?
just to choose an offering from amd ?
you decide and tell me
---------- Post added at 10:45 AM ---------- Previous post was at 10:38 AM ----------
even anandtech shows that I3 530 is beating athlon II X4 635 to pulp
in every scenario
Bench - CPU - AnandTech :: Your Source for Hardware Analysis and News
p.s. maybe it is ignorant of me,
but i never heard of passmark
no-one seems to use it
the primary concern is not benchmarking software , but in games
27-06-2010, 12:00 PM
#23 (permalink)
@everyone, please stop this cat fight.
CORE I3 530 5.5k
his rig is a good one. a value processor + a very good graphics card. everything balanced.
in future? in future i.e. next year H55 or say LGA1156 socket will be history (taken over by LGA1155). from where will you find a LGA1156 processor? so i'll simply advice, if going with Intel don't back on these "Future Stuff" slogans. please.
X4 got some discrete advantage over i3. but the opposite is true also. i3 is much faster than X4 or X3. OC is much more better. bad thing, these only advantage.
X4 is futureproof. sticking to a dual core, now is i think a totally stupid decision. forget that HT thing. it yields nothing. i3 faster than X3 & X4 cause of its superior architecture & 32nm process node. also as i mentioned above, with Intel its best to not spell the word "futureproof". cause its like making fun of yourself.
thats what i mentioned above. i3 faster than AMD's X3 & X4s.
don't forget mention: only in gaming.
~15W makes a difference (difference in TDP between X3 & i3)? you can save much more by simply going for AMD with a more efficient PSU.
about temperature, they aren't that much cooler. they almost same as the Athlon II X3-X4s.
1.Brand Value
1. whats Brand value? ok take Asus. its top most famous brand in motherboard. and now see, we hardly recommend Asus to anyone cause it comes with a host of problems that aren't easy to solve.
2. already mentioned above buddy.
3. true. performance is considerably high.
4. this true also.
5. than? whats the relation between game developers & Intel/AMD. do Intel pay compensation to game studios to make games that need Intel processor or give lower performance in AMD processors? do check clearly what you say here buddy. you may end up making joke of yourself.
6. you gave just 2 good points. 3 are what i say is either biased or totally out of this world points. that matters nothing.
dude
it is 372$
please give cost in INR. cause here the prices differ a lot in many products.
27-06-2010, 02:00 PM
#24 (permalink)
ok see this from your gigabyte site funkysourav--
3DMARKS
-------------------athlon II x4 630---------------core i3 530
HD5870--------------12314------------------------ 14275
GTX275-------------- 10687------------------------10355
HD4890-------------- 10745------------------------10004
HD5770--------------10676------------------------ 11273
GTS250--------------- 6891------------------------6103
HD5750--------------- 9983------------------------7433
GT240---------------- 5985------------------------5880
GT220----------------2252------------------------ 2480
HD4670--------------- 2193------------------------2138
GT210-----------------778------------------------- 824
MOREOVER THAT PASSMARK MEASURES THE PERFORMANCE AND SPEED OF A PC. SEE IT HERE - PassMark Intel vs AMD CPU Benchmarks - High End
core i3 540 - 2869
core i3 530 - 2722
---------- Post added at 01:57 PM ---------- Previous post was at 01:52 PM ----------
in the anandtech cpu bench you will see that 635 is better in multithreading by BIG MARGINS and there is a difference of 6-7 fps in gaming. SO WHAT WILL YOU CHOOSE?
---------- Post added at 02:00 PM ---------- Previous post was at 01:57 PM ----------
in anandtech cpu bench SEE CAREFULLY THAT IN SOME COMPARISONS LOWER IS BETTER IS ALSO WRITTEN.
27-06-2010, 08:21 PM
#25 (permalink)
What The.... !!!
3DMARKS
core i3 540 - 2869
core i3 530 - 2722
Thanks Jaskanwar,
I am happy to say that you have just convinced me to choose athlon 635 over intel i3 530
i was looking for a mobo proccy combo in 9k
and i3 530 comes nowhere near that price range(it comes to 11k!)
the athlon setup just fits nicely into my budget :
AMD Athlon II X4 635 - 5k
Biostar TA785G3 - 4k
That's 9k
i am glad you proved me wrong
p.s.
could you comment in my thread about the mobo?
27-06-2010, 09:54 PM
#26 (permalink)
Now that things have been resolved, returning to original question
8.
Sorry man, the way you insist on Intel and the reasons you are giving, you are highly overrating your hardware knowledge. At your budget, AMD will be a better choice, you can improve the overall performance of the PC with a better graphics card
And we are not reluctant to recommend Intel, most people do not have enough budget to buy Intel processors (50k is the minimum for i5, i3 is not much advantage, X4 is better). You can check threads where people have mentioned budgets of 70-80k, they have been suggested i7 configs.
27-06-2010, 10:33 PM
#27 (permalink)
@funkysourav
If you have some queries, then please start your own thread. You ended up hijacking this thread unintentionally. Consider this as a warning.
28-06-2010, 08:53 AM
#28 (permalink)
Thanks Jaskanwar,
That's 9k
p.s.
no problem dude,
just change that mobo to Biostar TA785G3 HD @ 4.2K
30-06-2010, 03:23 PM
#29 (permalink)
Re: Intel Only: Gaming PC @40-45K
Thanks for all ur suggestions.
I want to ask few questions here:
1. Give ur opinion abt i5 661.
2. Have u heard about CIRCLE cabinets? I have seen COSMO model & its a VFM cabinet with very good cooling & ventilation, option for atleast 3 fans & without PSU it costs just ~1K. I believe its much better for value when compared to NZXT & Cooler master Elite series.
3. Is a latest INTEL Quadcore is better option for gaming with a good graphics card than an i5 proccy?
4.Should I go for ATI graphics card only or NVIDIA is also good value for money?
Please plz.......reply to these points only & don't flood the post with unnecessary arguments.
---------- Post added at 03:23 PM ---------- Previous post was at 03:19 PM ----------
Nobody suggested the i7 config with extra budget stretch........!!!
Plz suggest decent i7 config also. A config that is not too costly but better than i5 750.
30-06-2010, 03:52 PM
#30 (permalink)
What The.... !!!
i5 661 is a total waste of money
dont even look towards it
if you want to build an i7 gaming pc it would cost you a premium of at least 15k over the i5 750 pc
there is no difference in performance between i5 750 and i7 930
but still if you want to go for i7
i can suggest you one for about 100k!!
dont blame me the cheapest i7cpu mb combo alone costs about 32k!!!
plus they use triple channel memory
which comes at 10k minimum
so i7 is not going to stretch your budget
it is going to double it simple!!
regarding your other questions i cant really help you if i dont know how much you are willing to spend!!
follow the template
