Hi all!
I have a Wipro emerge UPS (300Watt) (Model: WeP BNT 500-A) (it has two outputs, one for the PC & second for the monitor) , which came with my PC (Pentium-4) (Model: LG MyPC), which I bought few years back. Now it's gone crazy. It doesn't provide enough battery backup. Whenever there's a power-cut, backup is around only few seconds, so it's almost impossible to save data & properly shutdown the PC. What may be the reason? Is it battery issue or something else?
Pictures of my UPS (Got them by googling
http://images.naaptol.com/usr/local/...WeP500VA-1.jpg
http://whitesindia.com/shoppe/images/wep500va.jpg
(1) If it's the battery problem, where can I get the battery replaced? At any "battery-wallah" shop or somewhere else
(2) How much would be the cost of the battery in my case?
(3) Of which company & rating battery should I buy? Can I buy battery from APC (I prefer APC But if there is better option tell me plz.) OR I have to go for wipro?
(4) Can I go for the higher rating of battery (At backside of my UPS is written "300W" I don't know about AV rating, I think it should be 500VA
(5) Soon I am going to upgrade the DDR-1 RAM to at-least one GB OR at-most two GB. Do they draw the more power? & will it affect the UPS? (AT top of the SMPS (Power Unit) is printed "200W")
(6) What is the battery rating, model etc. of my WeP UPS?
(I don't have manual etc.) (If anyone else has the same UPS plz. help)
If I go for a new UPS (I prefer APC But if there is better option tell me plz.):
(1) Which Model (& of what rating) should I buy? would 500VA-600VA be enough OR at-least 1KVA?
(2) What is the starting price for "online UPSes"?, since I've heard that they are better than their offline counterparts but are very expensive too. So what should I choose online OR offline?
(3) Do cheap "offline" UPSes provide the option to connect to PC via USB etc. to automatically shutdown the PC whenever there is not enough power?
(4) Do cheap offline UPSes have "AVR (automatic voltage regulator)", surge protection, EMI/RFI suppression, Telephone / Modem Surge Protection etc.
(5) If I go for a new UPS would I have to buy new power cables, cause my current UPS has IEC connector (
IEC connector - Wikipedia, the free encyclopedia) variation so I have two cables (one to connect with the PC & the other one to connect with the my CRT monitor) which have C13 (
IEC connector - Wikipedia, the free encyclopedia) at one end (to connect to PC & monitor) and C14 at another end (to connect with the UPS), So my UPS has C13 output socket not the Indian standard socket but most of the UPSes available in market have Indian standard output sockets. [My output sockets look like this
File:UPSRearView.jpg - Wikipedia, the free encyclopedia this picture has three sockets but mine has two.]
Here is another question though Not related with this but concerned with this issue:
(1) Is there any software which can show the power consumption in WATTs of the PC in real time? in BIOS I can only know about volts but can't understand it, So I need a solution to calculate the power consumption in WATTs, cause at different times we use different peripherals running like- CD burner while burning a disc.
Please reply my queries in details, thanks.
