1. What is the purpose of the computer?
Gaming
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
Yes
3. What is your MAX budget?
40K
4. Planning to overclock?
No
Windows 7 Home Premium 64bit
Ubuntu 10.04LTS
500GB would do
7. What resolution will the screen run at & whats the size of the screen?
20"@1600x900
8. How would you rate your hardware knowledge from the count of 1-10?
6
Assembler
In less than 2 Weeks
Maybe
12. Are there going to be any components that you don't want to include in this new rig?
NO, i want everything from scratch
Will buy from Kolkata or Asansole
i live in West Bengal
14: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement
CPU - Amd Phenom II x2 555be
or
AMD Athlon II X4 635
or
AMD Athlon II X3 440
open to Intel Core I3
Motherboard -Gigabyte MA-785GMT-US2H
GPU - HD 5770(preferably powercolor)
RAM - 4GB(2*2) 1333MHz Kingston DDRIII RAM
HDD - 500 GB WD Blue
Monitor-20" DELL S2009W
Cabinet - CM Elite 310
PSU/SMPS - Corsair CX400
(not really sure about this ,the CORSAIR PSU CALCULATOR recommends this , but the HD5770 system requirements say it needs at least a 450w psu)
Key Board+Mouse - Logitech SET - Optical Blk Mouse+ MMKB
ODD - L.G. GH22NS50 OEM SATA DVD-Writer
Speakers - Altec Lansing 2.1 BXR1121
