Old 25-06-2010, 02:38 PM   #1 (permalink)
abhinav_bipnesh's Avatar
Question Good WIFI N series router
Hi All,
I am looking for good WIFI N router which I can use with my Broadband connection (ADSL one).
So please suggest me some good router which i can look for.
Regards,
Abhinav
abhinav_bipnesh is offline   Reply With Quote
Old 25-06-2010, 02:44 PM   #2 (permalink)
Default Re: Good WIFI N series router
I would strongly suggest Linksys WAG120N - Linksys by Cisco - WAG120N Support. This would cost you 3.5k.
Currently, I'm using a Linksys WAG54G2 which is Wifi G and I'm very satisfied with it's range and performance. I would say NO to Netgear, it sucks.
However, if you have plenty of cash to spend (approx 6.5k), then you can consider Linksys WAG160N - Linksys by Cisco - WAG160N Support
Edit: I have moved your thread to Hardware Q&A because you actually want to buy new stuff.
Old 25-06-2010, 06:20 PM   #3 (permalink)
change is constant!!
khmadhu's Avatar
hmm Belkin is also not bad.. i guess u have read the recent release of new models..
i am using from past 5 months..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 25-06-2010, 06:35 PM   #4 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
But I guess nothing beats Linksys in terms of signal strength and speed. I have personally felt the difference in performance of Linksys and D-Link routers. Linksys was way ahead. No experience on Belkin routers though.
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 28-06-2010, 03:09 PM   #5 (permalink)
royal's Avatar
Wink Re: Good WIFI N series router
Belkin N series wireless routers are real good...using one for last 3 months. No prob regarding signal strength between two floors
royal is offline   Reply With Quote
Old 28-06-2010, 04:03 PM   #6 (permalink)
v2kisad's Avatar
Check out Netgear JWNR2000. I'm using it. Its got decent range and is quite stable. I use Tversity to stream my multimedia contents from my PC to PS3, it works fine.
v2kisad is offline   Reply With Quote
Old 28-06-2010, 08:29 PM   #7 (permalink)
15.0 GHz
VarDOS's Avatar
Netgear is good.. but try Linksys
VarDOS is offline   Reply With Quote
Old 28-06-2010, 09:40 PM   #8 (permalink)
Netgear usually has tons of bugs in their firmwares.
how good are MICROMAX phones andy_65_in Mobiles and Tablets 0 16-04-2010 09:50 AM
Unsecured wifi network asking for router PIN no. spider Hardware Q&A 0 06-03-2010 10:24 AM
How to check if WiFi card is working harmads Hardware Q&A 0 17-02-2010 12:43 PM
5800 XM good? blademast3r Mobiles and Tablets 5 06-02-2010 10:29 PM
Not able to ping Wifi router jamesbond007 Networking 17 26-11-2007 03:28 PM
- by kool
- by ax3
