Old 25-06-2010, 02:25 PM   #1 (permalink)
Default Blue screen on new PC
Hey i purchased a new pc with followi ng config
amd phenom2 X6 1055t
4gb ddr3 A-data ram
500 GB seagate baracuda HDD
LG DVD writer
XFX ati radeon HD5770 graphix
Asus M4A88T-M/USB3 board
When i play games, they work fine for sometimes(random) and then PC just hangs with a screen with stripes.....Plz tell me what the problem is all about
here are the details
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 16393
Additional information about the problem:
BCCode: 124
BCP1: 00000000
BCP2: 8659C6F4
BCP3: 00000000
BCP4: 00000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\062510-16052-01.dmp
C:\Users\Aniruddha\AppData\Local\Temp\WER-26785-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
HERE IS THE DIRECTED FILE
Is there any problem with my parts??
I am using windows 7 licsensed.
The game which i tried are... Company of Heroes(tales of Valor), Hitman bloodmoney, Virtua tennis 3, Burn out paradise...
ani1751 is offline   Reply With Quote
Old 25-06-2010, 02:35 PM   #2 (permalink)
Default Re: Blue screen on new PC
please run some graphics benchmark & report the temperature of the card here. i feel the card is the core of problem. or maybe Asus is the antagonist again
Old 25-06-2010, 02:37 PM   #3 (permalink)
Plz confirm whether the game supports AMD proccy & Windows 7 OS.
Ensure that u have latest DirectX updates & all drivers are properly instlled.
Mr.Digital is offline   Reply With Quote
Old 25-06-2010, 03:06 PM   #4 (permalink)
geek........
Gauravs90's Avatar
you are getting screen with stripes? This may be RAM problem or graphics card temperature going high
I suggest check yor RAM by running memtest86+ for an hour
Also list your PSU and its power rating. and do what sam.shab said
Gauravs90 is offline   Reply With Quote
Old 25-06-2010, 03:09 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Please do the following, and check.
1. Remove the problem signature text. It is far too long. Attach it a text/notepad attachment.
2. Attach the last three(3) BSOD dumps you have.
3. Reset the system BIOS.
4. Update to the latest ATI Radeon drivers (Also let CCC install, and all the .NET frameworks).
5. Update to latest DirectX 11 Runtime.
6. Fully patch/update your system OS.
7. Install all chipset drivers for your board.
If you are not being able to remove legacy drivers use this method:
1. Remove all ATI entries from 'Uninstall Manager'.
2. Run CCleaner Registry Cleaner.
3. Create a restore point.
4. Reboot to save mode.
5. Run Driver Sweeper, and remove all ATI remnants and residual crumbs.
6. Reboot to normal windows and install the Catalyst flavor of choice.
7. Restart.
8. Verify driver version via GPU-Z and Hardware devices utility in Windows.
Link to Driver Sweeper is here.
Also which PSU are you using..?
asingh is offline   Reply With Quote
Old 25-06-2010, 05:56 PM   #6 (permalink)
I think PSU must be the problem as u people have suggested(by just asking)
At present i am using intex 450w power supply,
my corsair vx550 is on its way from chandigarh....
Old 25-06-2010, 06:00 PM   #7 (permalink)
Intel 450W & HD5770? add to it 125W proccy? GOD help you.
Old 25-06-2010, 06:01 PM   #8 (permalink)
Super Moderator
asingh's Avatar
What I mentioned above will not harm your system, so you can do those. Meanwhile do NOT game on the system and/or run any stressing software (OCCT/Furmark/Intel Burn test etc..). Change the PSU when the Corsair unit arrives.
Old 25-06-2010, 06:46 PM   #9 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
so if there is a graphics card (XFX NVIDIA GeForce 9600 GT 512MB) and three SATA HDDs with Intel Dual Core which PSU would you suggest?
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 25-06-2010, 07:11 PM   #10 (permalink)
a good 400-450W PSU. that can deliver. not something that isn't even 50% efficient. FSP Saga II 400W/Gigabyte 460W/FSP Saga II 500W. all these 3 are good buys. get 500W if you plan to upgrade to a better card.
Old 25-06-2010, 07:15 PM   #11 (permalink)
Cool Buddy's Avatar
ow man, got something against intel?
It's Intex
Change your PSU (SMPS) to a corsair VX 450@3.7k or FSP Saga II 500W @2.6k immediately. I know the price will hurt, but if you don't change the PSU now, a burnt/blown up PC will hurt even more later on.
In the mean while, don't play games so that the gfx card is at low load & power consumption is low.
---------- Post added at 07:15 PM ---------- Previous post was at 07:13 PM ----------
FSP Saga II 400W or corsair CX 400 should suffice
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 26-06-2010, 10:10 AM   #12 (permalink)
I too think that i should not game...
I also dont have a good cabby, in gwalior they only have local stuff, the only good cabbys available are of navtech, can u suggest me some site for buying cabby with economical rates....
---------- Post added at 10:10 AM ---------- Previous post was at 10:08 AM ----------
Old 26-06-2010, 10:25 AM   #13 (permalink)
Super Moderator
asingh's Avatar
PrimeABGB
theITwares
delta peripherals
Old 26-06-2010, 10:34 AM   #14 (permalink)
It's Intex
Old 26-06-2010, 02:06 PM   #15 (permalink)
Okay, It happened again, while playing the local win7 default chess....Now this thing is getting on my nerves....Shall i wait for the tests suggested by asigh and others until i get myt new PSU....
this is problem detail...
Problem signature:
Locale ID: 16393
BCCode: 124
BCP1: 00000000
BCP2: 86659434
BCP3: 00000000
BCP4: 00000000
Service Pack: 0_0
Product: 256_1
C:\Windows\Minidump\062610-47081-01.dmp
C:\Users\Aniruddha\AppData\Local\Temp\WER-49998-0.sysdata.xml
Old 26-06-2010, 05:31 PM   #16 (permalink)
Super Moderator
asingh's Avatar
Wait for the new PSU.
blue screen error harperstan27 Software Q&A 4 19-05-2010 09:21 PM
problem due to BLUE SCREEN.. medmonster Software Q&A 3 09-05-2010 07:57 AM
Blue Screen at Shut Down icekid Software Q&A 10 02-05-2010 05:40 PM
Compaq Presario over heating and blue screen error spider Hardware Q&A 1 22-02-2010 11:52 PM
- by kool
- by ax3
