1. What is the purpose of the computer?
basically i need to buy a new tv and a laptop/pc for my home. already heaving a laptop.also interested in buying xbox 360 in future so right now just need a basic pc which can handle hd movies on 22/24 inch monitor with HDMI out so that i can buy a HD set top box of any provider and connect it directly to monitor without worrying about tv tuner card? if its possible?? dont know....
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
yes i need a VFM offer not behind Intel inside brand name. i m open to all.
3. What is your MAX budget?
35K. want to save some for xbox in future so happy with basic system.
4. Planning to overclock?
never assembled a pc before. not planning to overclock.
i have a free copy of windows 7 ultimate.
500 gb is more than enough for me.
7. What resolution will the screen run at & whats the size of the screen?
preferable 24 inch can compromise to 22. true HD resolution. HDMI port.
may be 3
never done before. mostly by an assembler.
next 15 days to one month.
no i need basic one mostly ll b used by my wife.
Gujarat. mostly ll be buying from Ahmedabad/ rajkot.
i dont mind age old c2d processor. i dont know minimum graphic card requirement to run true HD movie on 24 inch screen without skiping frames.
also dont know if i can connect a STB to monitor with HDMI cable without using tvtuner card.
suggestions needed.
