Old 22-06-2010, 11:09 AM   #1 (permalink)
Default New Motherboard and Proccy - suggestions please!
Hi Guys,
My current setup is:
Proccy: Intel P4 3.2 Ghz
Mobo: Intel 945 GNT
RAM: 3 Gigs Value ram (2x1 , 2x 512 - dual channel)
HDD: 1x 160 GB , 1x 250 GB , 1x 1 TB (all seagate)
GFX CARD: Palit 9600 GT 1 GB (Factory Overclocked)
PSU: Cooler Master Extreme Power 500W
DVD Writer: LG
I intend to upgrade mainly my processor and motherboard to contemporary standards . I use my machine mostly for gaming and other general purpose computing. Please suggest a good config. My budget is 15k-20k max.
I was thinking of getting AMD Phenom X4 965 BE and one of the possible motherboards:
Asus M4A89GTD Pro/USB3 (or) MSI 890GXM-G65 (or) Biostar TA890GXE (or) GIGABYTE GA-890GPA-UD3H . A good motherboard with USB 3.0 support is preferable so that it is a bit future proof. It needn't have on board graphics since I shall be using my graphics card anyways.
Only Mobo+Proccy are my priorities but some good config including some ddr3 ram will really hit the sweet spot.
Also Do I need to upgrade my PSU for the new components?
Thank you in advance. All suggestions are welcome!
kageiit is offline   Reply With Quote
Old 22-06-2010, 12:11 PM   #2 (permalink)
Default Re: New Motherboard and Proccy - suggestions please!
Originally Posted by kageiit View Post
Hi Guys,
Mobo: Intel 945 GNT
DVD Writer: LG
for 20k, get these:
Athlon II X4 630 2.8GHz @ 4.7k
Biostar TA785G3 HD @ 4.2k
Corsair 4GB Kit 1333Mhz Value @ 5.8k
Corsair VX450W @ 3.8k (sell your current PSU)
Total: 17.5k.
if you want Sata 3.0. you may add a card later on or you may go with Biostar TA890GXE. but do remember. selling out 2.5k for something you not going use now isn't a good deal. better get a PCIe card that have USB 3.0 as well as Sata 3.0 when it becomes cheap.
Old 22-06-2010, 12:28 PM   #3 (permalink)
just a quick question , where can i sell my current PSU i.e Cooler Master Extreme Power 500W . I bought it 3 months ago on Ebay. its brand new. Can you suggest some potential places so that i can sell it. please...
Old 22-06-2010, 12:47 PM   #4 (permalink)
post a thread in bazaar section. someone maybe interested. i suggesting you sell this PSU cause of its unusual characteristics. it may blow up damaging your card & also the rest of the hardware. so better get rid of it.
Old 22-06-2010, 12:54 PM   #5 (permalink)
Jaskanwar Singh's Avatar
Just change the procy to athlon 2 x4 635 @ 5.4k. Rest go with sams suggestion
Old 22-06-2010, 01:07 PM   #6 (permalink)
I am the night! I am....
vickybat's Avatar
I have posted it before but got no replies so i'm doing it again. please help out this time guys...
My brother has an amd based system consisting of the athlon x2 4400+, asus m2a-vm mobo, 4gigs ddr2 ram and sapphire 4650. The proccy in my opinion is very weak and is a big bottleneck for the rest of the system as it can't even play full hd movies.
Recently tried running AVATAR FULL HD which is 19.5gb in size and it slowed down to a crawl.
So i want to know what proccys can i add to this mobo without changing anything else so that atleast it can last a year.Can i add athlon 2 x4 635 or 630?
Please give me the compatible proccys for this mobo which is an am2 or am2+ socket.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is online now   Reply With Quote
Old 22-06-2010, 01:24 PM   #7 (permalink)
cute.bandar's Avatar
I have a similar proccy. I have no problems playing 720p videos and I don't tink this proccy is out of date . Although I haven't run such a large 20gb video . But I don't personally think you need to upgrade the proccy(I could be wrong) .
cute.bandar is offline   Reply With Quote
Old 22-06-2010, 01:54 PM   #8 (permalink)
X4 635 is too costly currently. 600-800 bucks more just for a 100Mhz jump. this just a ridiculous decision & should be avoided.
its an AM2 socket based motherboard so AM2 or AM2+ processor will only fit. not AM3, i guess.
do have a look here.
and if that motherboard have a Bios release, may support X4 940 (AM2+ processor).
Old 22-06-2010, 02:07 PM   #9 (permalink)
laborare est orare
Cilus's Avatar
I don't think the problem is your CPU or GPU. For playing Blue Ray rips (ur mentioned one is a blue ray rip), even on-board HD 4200 is sufficient and you are having a HD 4650 which is far powerful than HD 4200.
For playing full HD movies, you also need proper codecs. For example new Divx HD is codec for H264 or MKV decoding is not good enough.
If you are using XP, then download ffdshow decoder and Haali Media player. Also update your graphics card driver and motherboard driver. You can also use Media Player Classic Home Cinema, which supports DXVA acceleration (using Graphics card for playing and applying some post processing). Then try to play the video again.
Because even with my old Athlon 64 bit single core and a Nvidia 9500GT I was able to play some of the blue ray rips, like LOTR (10.2 GB)
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 22-06-2010, 02:07 PM   #10 (permalink)
how about this config:
CPU: AMD Phenom II 3.2 Ghz. 955 X4 Black Edition - 7.4k
MOBO: MSI 890GXM-G65 - 7.4k
PSU: Corsair 450W VX - 3.7k
Total - 18.5k
(all prices excluding tax)
I can try to get the DDR3 ram if I can sell my current PSU . Also will my existing DDR2 ram work fine with this setup?
Comments please!
Old 22-06-2010, 02:54 PM   #11 (permalink)
laborare est orare
Cilus's Avatar
Guys, as per the PSU thing, I differ with most of the people. For running a 9600 GT, I think the Cooler Master Extreme Series 500W is more than enough, even with its bad reputation. A lot of forum members reported that they are running 8800GT or 9800GT/GTS 250 with Cooler Master Extreme series PSU and I did not find a single member, reporting their PSU is blown to flame.
If Op is planing to buy a High end Gfx card like HD 5770,then may be he can think to change the PSU.
But for now, I don't think he needs a new PSU.
kageiit, Your suggested config is very good. Instead of PSU, get 2X2 GB Kingston 1333 MHz DDR3 ram @ 5.5k
For mobo, you can also get the Biostar TA890GXE @ 6.6k. Very good board.
Old 22-06-2010, 08:40 PM   #12 (permalink)
vickybat's Avatar
@ Sam,Cilus,cute_bandar Thanks for your valuable suggestions guys.But one thing i don't understand i.e since am3 proccy's have both ddr2 & ddr3 memory controllers why won't phenom2 and athlon 2 won't work in socket am2+? I guess amd's are popular for backward compatibility unlike intel.
So what should i do & will the x4 630 fit in the board with a bios update?
If no, should i go for old phenom quadcore proccys like sam provided in the list?
Old 22-06-2010, 09:05 PM   #13 (permalink)
AM3 processors should run but only if Bios update is available. or do one thing, check if Phenom II X4 920 or 940 proccies available in market & just drop one in. they'll run surely. but AM3 processors will need a bios update surely. no bios update, no comparability.
Old 22-06-2010, 09:05 PM   #14 (permalink)
laborare est orare
Cilus's Avatar
Who said that Phenom II and Athlon II (AM3 Processors) don't work on AM2 or AM2+ motherboards. Yes they work just fine. But the opposite is not true. You cannot plug an AM2/AM2+ CPU into a AM3 socket mobo. This is because AM2/AM2+ socket is based on 940 pin Pin Grid Array whereas AM3 processors are based on 938 pin socket type, hence making it impossible to plug a AM2 processors like Phenom 9850 to an AM3 board.
The motherboard you mentioned, ie. Asus m2a-Vm based on AMD 690G chipset and supports Phenom II and Athlon II CPUs with a Bios update. Check here for the CPU support List of your mobo.
Go for a AMD Athlon II series CPu now. Don't spend much money to Phenom seroes as AMD is going to relaease their new gen processors in the end of 2010.
Old 22-06-2010, 09:55 PM   #15 (permalink)
Wise Old Ghoul
Piyush's Avatar
u know what?!?!
the owner of the SMC showed me his rig
he was running HD5870 with CM extreme+ 650W
my eyes were popped out
he even showed me crysis at full settings at 1900 resolution(19xx if its not correct)
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 22-06-2010, 10:32 PM   #16 (permalink)
Originally Posted by piyush120290 View Post
u know what?!?!
maybe. he having a good Extreme Power. but its highly not recommended. if it blows up, OP will sue us
Old 23-06-2010, 09:56 AM   #17 (permalink)
How about FSP Saga 400W or 500W instead of the corsair VX450? I think its a bit cheaper. Any opinions please?
Old 23-06-2010, 11:24 AM   #18 (permalink)
you can settle for. but FSP low on warranty & not as efficient as Corsair units. Corsair unit can provided more than their rated power under load. FSP can't. but still they value PSU. you can't expect these units go head to head with worlds best power supplies
Old 23-06-2010, 01:47 PM   #19 (permalink)
laborare est orare
Cilus's Avatar
It is not going to blow up Sam. If there is any problem, then Op can easily understand it. Even my friend runs a GTX 285, Core 2 Quad 6600 with a Cooler Master Extreme 650W and he plays games all the time. Sometimes temp reached to 80-85 degree C and no problem for 2 years.
Got a review about the Extreme Plus series. They are saying it is not as good as the others but not a bomb as mentioned here.
And again, for running a 9600Gt , the existing PSU is enough
Old 23-06-2010, 01:56 PM   #20 (permalink)
Super Moderator
asingh's Avatar
u know what?!?!
I do not care what a retailer/seller would show you. You really believe he has time to game/OC as much as we all do. No ways will the CM Extreme series deliver clean ripple free power at the ratings. I have read/heard/seen many users saying they are fine with CM E series, but honestly, have seen more cases where this unit failed and caused issues.
asingh is online now   Reply With Quote
Old 23-06-2010, 03:07 PM   #21 (permalink)
Ok so now im officially freaked out. will the PSU blow up for real? , I mean i had a CM exterme 460W when i bought my 9600gt and it worked fine for one year then due to a power surge , my spike burnt along with my CM 460w . So i got the 500w one recently about 3 months ago. I havnt faced any issues after that and I have gamed quite well using that PSU. My only concern is will it be able to power the new processor also . I dont wanna change the PSU unless it might blow up seriously and damage all my parts in future . any suggestions?
Old 23-06-2010, 04:59 PM   #22 (permalink)
guys have a look at the screenshot below & please tell me whats the total power output on the various rails:
as seen its a FSP Saga II 400W thats quite famous here. so want to know if its rally a good one.
also its 12V rail is divided into 2 parts? its good or bad compared to a single 12V rail?
Old 23-06-2010, 06:20 PM   #23 (permalink)
laborare est orare
Cilus's Avatar
Sam.Shab,
multiple 12 V rail is used for stabiliy. If you provide too much current (normally over 25A) to a single rail,it may generate significant amount of heat which leads to less life time of that PSU, unless very high level components are used.
So for budget or Mid range PSU, instead of providing a single 12V rail, multiple 12V rails are provided, one of them is having rating over or near 20A and other one is like 15 to 20A.
Theoretically total wattage should be [(1st 12V X Current Rating of it)+( 2nd 12V X Current Rating of it)], but practically it stays within +/-8% of the total Wattage. The problem is, it not possible to distribute the load identically to different 12V rails properly.
But it is observed that multiple 12V rail is good for the lifespan of the PSU.
Old 23-06-2010, 07:30 PM   #24 (permalink)
ok thanks a lot Cilus bro. solved my confusion
Old 23-06-2010, 08:00 PM   #25 (permalink)
pulsar_swift's Avatar
Originally Posted by Cilus View Post
Sam.Shab,
All corsair PSUs starting from Vx450 till TX850 have single 12V rail config. All of them come with 5yr warranty.
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 24-06-2010, 08:21 AM   #26 (permalink)
Super Moderator
asingh's Avatar
Read this about multi rails.
Old 24-06-2010, 12:32 PM   #27 (permalink)
nice post asigh. thank you
Old 24-06-2010, 01:58 PM   #28 (permalink)
ok thanks asigh. got it.
Old 24-06-2010, 06:45 PM   #29 (permalink)
laborare est orare
Cilus's Avatar
Nice post Asigh.
Ya, that is true, the main problem with multiple 12V rails is that in run time it is not possible to distribute the load proportionately to the 12 V rails as per their current rating.
So using a single 12V rail with large current rating is always good. But for this you need very good component also (with minimal resistance for minimizing power loss and heat generation).
So for Mid range CPUs which are normally used with not so high configured System, a multiple 12V rail is a good option as most of the times their power requirement does not reach to a point where they can fetch more than 20A from one of the 12V rail, having low current rating. It is good for these middle range of PSUs as they don't use very high quality components. It is also mentioned in Wikipedia.
Old 26-06-2010, 12:02 PM   #30 (permalink)
So here is what i decided to go with finally:
Processor: Phenom II X4 955 3.2 Ghz. Black Edition - 7.8k
Motherboard: Biostar TA890GXE - 6.2k
RAM: 2 x G-Skill Ripjaws 2GB DDR3 1600 MHz Dual Channel Gaming Memory CL9 (4GB Kit) - 5k (getting via friend from Canada from newegg)
PSU: will stick with what I have now (CM Extreme 500W) , but planning to upgrade in few months to Corsair VX450 W , when I can get me some cash
Total: 19k (all prices including taxes) , will purchase next week
Any comments? I hope I made the right decisions, and thank you all for helping me all the way
Budget desktop config suggestions required ! Xeno PC Components / Configurations 26 12-03-2010 08:10 AM
Please suggest a good latest Intel mainstream motherboard and proccy p_d5010 Hardware Q&A 68 12-08-2008 03:36 PM
New Motherboard suggestions. ECE0105 Hardware Q&A 9 13-05-2008 10:03 PM
problems finding drivers for windows vista for intel d102ggc2 motherboard Dr.tweaker CPU / Motherboards 1 12-05-2008 11:28 PM
Processor and Motherboard choices sakumar79 Hardware Q&A 10 28-07-2007 11:25 PM
