Results 1 to 2 of 2
  1. #1
    Broken In ANURAG SHARMA's Avatar
    Sep 2005
    Noida
    Default TV Tuner to buy with LCD?
    Frnds........plz suggest which tv tuner to buy with a 22" LCD.
    I'm going to buy today
    SAMSUNG 22"
    Attached Images Attached Images
    BE THE BEST EITHER HACKED IN THE QUEST
  2. #2
    Broken In lahratla's Avatar
    Jun 2004
    Default Re: TV Tuner to buy with LCD?
    You can go for AVerMedia AVerTV DVI Box9 which supports Full HD resolution of 1900x1200 with PIP, Picture Pause etc. features. You can also hook up with larger monitor later or even with your LCD TV. The chips used in this tuner are excellent.
  1. TV Tuner and DTH
    By GhorMaanas in forum Broadband and DTH
    Last Post: 18-11-2011, 12:41 PM
  2. USB FM tuner
    By abhijitroy in forum Peripherals
    Last Post: 08-05-2009, 09:43 PM
  3. Should I go for this int tv tuner?
    By saqib_khan in forum QnA (read only)
    Last Post: 20-09-2008, 03:37 PM
  4. TV Tuner
    By geek007 in forum Hardware Q&A
    Last Post: 03-04-2007, 04:41 PM
  5. tv tuner
    By shaunak in forum QnA (read only)
    Last Post: 26-05-2005, 01:42 PM
