Old 19-06-2010, 10:24 PM   #1 (permalink)
Default DDR3 at 686MHz
Hi guys
Today i bought a new computer. The spec is
Athlon 2 X4 630
Biostar TA785G3-HD
Coolermaster 600w
Zion 2GB DDR3 1333
I installed amd's Toverclocker and its showing my RAM's maximum bandwidth as 686MHz. Is this normal or should i be getting 1333MHz?
Sorry if what i said is stupid. I really am new in this. I haven't overclocked this system.
[IMG]file:///C:/Users/Nimesh/Desktop/Toverclocker.jpg[/IMG]
I have attached the screenshot of Toverclocker..
wrongelk is offline   Reply With Quote
Old 19-06-2010, 11:12 PM   #2 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Re: DDR3 at 686MHz
The term DDR means Dual Data Rate.So your max is 686 X 2 = 1372.Hope this clears your doubt.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 19-06-2010, 11:48 PM   #3 (permalink)
Oh i see.. so the 686MHz is completely normal.. So glad to know that..
Old 20-06-2010, 03:45 AM   #4 (permalink)
evewin89's Avatar
from where n for how much u bought
Athlon 2 X4 630
Biostar TA785G3-HD
Zion 2GB DDR3 1333
last week i bought the following stuffs from kolkata
Athlon 2 X4 630 RS-4900
Biostar TA785G3-HD RS-4200
corsair 2GB DDR3 1333MHz RS-2700
my price included 4% tax.
Evil Lives 4ever......
evewin89 is offline   Reply With Quote
Old 20-06-2010, 06:05 AM   #5 (permalink)
Cool Buddy's Avatar
If you have a single module of 2GB, the speed is fine. for the RAM to work at 1333Mhz, you'll need to plug in 2 modules of exactly same specifications.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 20-06-2010, 07:54 AM   #6 (permalink)
oh i see.. i thought a single ram will work in that rate.. my mistake..
---------- Post added at 07:54 AM ---------- Previous post was at 07:50 AM ----------
@evewin89 guess i got a bit cheaper..
athlon 2 x4 cost me 4842
ta785g3-hd for 3952
zion 2 gb for 2700
all including vat.
just a small difference i think..
Old 20-06-2010, 09:32 AM   #7 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
I dont think so.single or double module, the ram will work in 1333Mhz.But its shown as half the frequency as its DDR ram.Dual Data Rate.
Old 20-06-2010, 11:29 AM   #8 (permalink)
Super Moderator
asingh's Avatar
I doubt the memory controller will see the dual channel architecture with 1x stick.
asingh is online now   Reply With Quote
DDR2 or DDR3? Is Price 2 Performance justified? aksharatg Hardware Q&A 7 24-03-2010 07:24 PM
Kingston 2400MHz DDR3 'World's Fastest Memory' topgear Technology News 11 17-03-2010 04:18 PM
DDR3 is here!! Help~Is~Here Technology News 7 06-06-2007 12:59 PM
