View Poll Results: Which is better?
Core i7 930 9 60.00%
Phenom X6 1090 6 40.00%
Voters: 15. You may not vote on this poll
Old 19-06-2010, 01:41 PM   #1 (permalink)
bringing the world down
hdknitro's Avatar
Question which is better
Phenom II X6 1090T 3.2GHz B.E.
VS
Core i7 930 2.8GHz
Which processor can give the best performance in a gaming scenario/rig???
hdknitro is offline   Reply With Quote
Old 19-06-2010, 01:53 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: which is better
In short--
core i7 930--->gaming
1090t--->multithreaded apps.
Old 19-06-2010, 04:54 PM   #3 (permalink)
Super Moderator
asingh's Avatar
You can multi thread also on i7 930..!
asingh is online now   Reply With Quote
Old 19-06-2010, 07:49 PM   #4 (permalink)
nooooo, you just misunderstood me.
i meant that if someone is doing encoding, 3d rendering and all stuff he should choose 1090t for that purpose as it excels in this field for which it is made also.
in overall performance, i7 930 is just a beast.
Old 19-06-2010, 09:26 PM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
both are of same grade
the difference if of the physical cores
some may say that the i7 is better and some may not think the same
the smart buyer is one who gets the "value for money" performance keeping in mind that his needs are satisfied
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 20-06-2010, 06:06 AM   #6 (permalink)
Cool Buddy's Avatar
for a pure gaming experience, i7 would be a better choice
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 20-06-2010, 04:52 PM   #7 (permalink)
hdknitro's Avatar
I just came to know that i7 is much more effecient when OC. And as far as the price is concerned they both cost the same, its is just that the motherboard for i7 costs more. But performance is much better
'''LET THE POWER BE RAW'''
AMD Phenom X6 1090 T, Gigabyte 88O, G-Skill ribjaw 1600mhz (4 gb), WD Caviar Black 1.5 TB, Sapphire HD6870 1GB, CM GX 650, CM Centurion 590, 6 fan cooling system
Old 20-06-2010, 06:20 PM   #8 (permalink)
I am the night! I am....
vickybat's Avatar
Not that much.Msi's X58PRO is the best board for its price somewhere around 10k.
Actually you can get good multithreaded performance from i7 930 cause it supports hyperthreading.Also nothing beats an overclocked i7 in performance.
But the x6 1090t is also a very good option and actually has 6 physical cores.Since its a black edition processor,it comes with an unlocked multiplier.So overclocking will be easy as you can increase the multiplier count keeping the bus frequency constant & therefore no need to increase v-core.
Either way, you can't go wrong.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is online now   Reply With Quote
Old 20-06-2010, 09:13 PM   #9 (permalink)
Wise Old Ghoul
Piyush's Avatar
right
but x6 seems to be more future proof
--Get Backers
Old 20-06-2010, 10:27 PM   #10 (permalink)
pulsar_swift's Avatar
Its Core i7 930 all the way, except video encoding. Open anandtech and do a comparision. Results are there to see
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 20-06-2010, 10:40 PM   #11 (permalink)
Wise Old Ghoul
Piyush's Avatar
If you want the better gaming chip, you want Lynnfield.
---------- Post added at 10:37 PM ---------- Previous post was at 10:36 PM ----------
ok dudes
i agree
---------- Post added at 10:40 PM ---------- Previous post was at 10:37 PM ----------
OCed at stock heatsinkfan
--Get Backers
Old 20-06-2010, 11:27 PM   #12 (permalink)
go for cheapest and best mobo and cpu so u can upgrade in march.
aby geek is offline   Reply With Quote
Old 27-06-2010, 05:04 PM   #13 (permalink)
hdknitro's Avatar
I won't be upgrading my PC for atleast 2-3 years. So, I need the best gaming procs
Old 27-06-2010, 05:16 PM   #14 (permalink)
for gaming i7 930 is the way to go..
Old 27-06-2010, 09:34 PM   #15 (permalink)
Wise Old Ghoul
Piyush's Avatar
abey tu to mujhe bol raha tha ki x6 finalized he
now what?
--Get Backers
Old 29-06-2010, 05:39 PM   #16 (permalink)
hdknitro's Avatar
now what?
Abe mere kehne ka matlab hai ki abi change karwaunga, fir 2-3 saal ki chutti
