Old 19-06-2010, 01:35 PM   #1 (permalink)
sharma_atul85's Avatar
Question Using monitor as TV too
Hi my PC config is dual core 2.2GHz, 2 GB DDRII, ASUS P5KPL-CM motherboard, 17" CRT monitor
I am using Windows 7 .
Now I want to replace my CRT monitor with 22" LCD monitor. So please suggest the best one according to my needs.
My main purpose to purchase LCD is to use it as a TV
Also are speakers inbuilt into the LCD monitors(preference LCD with built in speakers) or my 2.1 speakers will work too ?
n do I need to purchase TV Tuner card as well ? please suggest best one . Will plugin cable for the time but will shift to Airtel Dish TV later on . So please suggest according to the compatibility.
Thanks !
sharma_atul85 is offline   Reply With Quote
Old 19-06-2010, 04:45 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Using monitor as TV too
You can buy LG TV Monitor (model No. LG M227WA). This comes with a remote, has full HD resolution. you can also consider Benq 22" LCD Monitor TV (Model No. SE2231) @ 12500
However, a normal 22" full HD LCD monitor from benQ or AOC for 8000 along with a TV Tuner card may be a cheaper solution. But if TV is a primary use, TV monitors are better unless you get a RF remote with a TV Tuner card.
Keep in mind though that pictures won't look as vibrant on these monitors as they do on 26", 32" or bigger LCD TVs as these are TN Panels while LCD/LED TVs are IPS panels which are much more expensive.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 19-06-2010, 07:59 PM   #3 (permalink)
crazydevil's Avatar
Hi Cool Buddy... which company will you suggest for a 17/19 inch Full HD LCD TV
for me main purpose is PC only and all my videos in my PC will look good in small resolutions only...TV will be just an addon for me
crazydevil is offline   Reply With Quote
