Old 19-06-2010, 10:43 AM   #1 (permalink)
Default Maximum number of hard disk partitions reached
i have a seagate 1tb hard disk, when i bought it, i created 5 partitions on
it. but yesterday when i installed ubuntu linux on the system, it merged
all those partitions into one, so i tried to format it again(with xp) but this
time i was just able to create only two partitions although unallocated
space was remaining.Now, after recovering all the data lost due to
formatting, when i tried to create partitions again i was only able to
create 4 partitions and i was given a msg that maximum number of
partitions for the disk reached and you cannot create more
partitions...please guide me on this
vjunloc is offline   Reply With Quote
Old 19-06-2010, 10:49 AM   #2 (permalink)
The Unknown's Avatar
Default Re: Maximum number of hard disk partitions reached
4 is the maximum number of primary partitions. You will have to add the 4th one as extended block and then create partitons inside the extend block.
KDE on ArchLinux
The Unknown is offline   Reply With Quote
Old 19-06-2010, 04:23 PM   #3 (permalink)
Cool Buddy's Avatar
You need to create extended partition & then create logical drives inside this partition from XP, you may not be able to create more than 4 primary partitions as the unknown said
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 19-06-2010, 04:25 PM   #4 (permalink)
Not necessarily IMO, fdisk or better cfdisk can do it
KDE on ArchLinux
Old 21-06-2010, 08:20 AM   #5 (permalink)
thanks for replying guys, actually i solved this problem by installing windows 7 on one of the primary partitions(created using xp cd) and then used diskmgmt.msc to deal with unallocated space....so now i have 3 primary and 2 logical partitions
Old 21-06-2010, 09:11 AM   #6 (permalink)
This is what I'd exactly suggested
KDE on ArchLinux
Hard Disk girishrn Hardware Q&A 5 25-03-2010 07:43 PM
hard disk crash problem anant197 Hardware Q&A 3 17-03-2010 07:57 PM
what exactly is a RAID hard disk ? go_gamez QnA (read only) 10 13-09-2006 08:26 PM
What is inside hard disk? rajat22 Tutorials 2 14-06-2005 05:05 PM
how to format HDD using fdisk? zegulas QnA (read only) 10 18-05-2005 12:41 PM
