Digit Technology Discussion Forum
Hardware
Hardware Q&A
HELP : BSNL wifi router WA3002G4 on/off automatically after some time
User Name
Remember Me?
Password
Register
FAQ
Calendar
Mark Forums Read
Hardware Q&A
Discuss basic Hardware problems, find solutions to your hardware queries which don't fit in the other sections.
LinkBack
19-06-2010, 08:45 AM
1
permalink
esumitkumar
Call me Sumit
Hi buddies
I have wired airtel BB connection ..Previously I had BSNL BB connection along with wifi router WA3002G4.
Now from some tutorial from net, I configured my BSNL modem to be.. used in airtel BB as wifi successfully
Prob is that after some minutes of connection, it switchs off automatically thereby disconnecting the network.
after some mins, it switches on...
Could you all plz help me in resolving this router prob
Thanks
Sumit
19-06-2010, 09:52 AM
2
permalink
gopi_vbboy
Section Moderator
Re: HELP : BSNL wifi router WA3002G4 on/off automatically after some time
check if there is any loose contact in power adapter
may be thereis some line-problem...try without wifi n check if u have same problem with ethernet...if yes then its phone line prob
do a modem reset at the back of it where u have a small hole to
Digit Tutorials Index
Digit Toolbar
Official I5801 Thread
Pasport and Visa experiences
Follow me on Twitter
19-06-2010, 10:27 AM
3
permalink
esumitkumar
Call me Sumit
without wifi it works very good with airtel 110TC1 ADSL2 Router which is wired
I will check with reset button ...will pressing it will remove all config ?
19-06-2010, 10:55 AM
4
permalink
gopi_vbboy
Section Moderator
^^ will bring back to deafult settings...
Digit Toolbar
19-06-2010, 11:37 AM
5
permalink
chintan786
try this...
BSNL,Karnataka..
20-06-2010, 01:37 AM
6
permalink
burnout.paradise
please specify clearly whether the power light turns off or the DSL/ Link light or the Ethernet/LAN light
01-07-2010, 11:17 PM
7
permalink
Padikkal
Check the power adaptor. It should be 12V 700mA.
Normally it happens for the lower rated power adaptors.
Get an ORIGINAL UTStarcom adaptor and then try. If the problem repeats then replace the modem no other solution.
Digg
del.icio.us
StumbleUpon
Google
Previous Thread
Next Thread
Show Printable Version
Email this Page
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
On
Forum Rules
Thread
Thread Starter
Replies
Last Post
Keep on disconnecting BSNL modem
srishet
Software Q&A
9
18-03-2010
06:37 PM
Every time os crash
sinalkar.sanjay
Software Q&A
3
23-02-2010
06:12 PM
Belkin N+ router vs Belkin N+
Blackfire
Hardware Q&A
0
21-01-2010
06:53 PM
Welcome Linux, Bye Windows...
nitish_mythology
Open Source
174
27-07-2006
10:25 PM
GTA 4 FPS problem
- by
vaibhav23
Must Watch Movies Recommended By Digitians
- by
~Phenom~
The Offtopic discussion thread...
- by
IronManForever
Battlefield 3 discussion!
- by
cyborg47
Official Android discussion thread
- by
amitabhishek
Hitman: Absolution
- by
gameranand
Must Watch Movies in High-Definition
- by
trublu
Urgent help required!
- by
nikhilnayak
What song are you addicted to at the moment?
- by
Rockstar11
the FOOTBALL channel
- by
Arsenal_Gunners
08:22 PM
Contact Us
Thinkdigit.com
Archive
Top
LinkBack
LinkBack URL
About LinkBacks
Search Engine Optimization by
vBSEO
3.3.2
