Originally Posted by spm
can you tell me more about the unlocking thing.
Which all proccy can be unlocked and can this phenom dual core be unlocked to a quad. is it safe to do this as many in this forum say they are locked for a reason. and can they always be unlocked and will it damage the proccy...
I know this is a lot of questions. just had all this doubt about this thing
anyway thanks sam
well unlocking is a simple mechanism. turn ACC on in Bios (provided mother supports ACC) and voila, you'll either get 1 or 2 more cores for free or BSOD. cause these locked cores are damaged. sometimes what happens is in some of the locked cores something is damaged. maybe the L2 cache got error. or the core material itself (transistors) are damaged. so unlocking is simply allowing these damaged cores to work. if they are still functional, they will. else BSOD.
now problem is, i not sure but Phenom II X2s, maybe ship with stock Athlon II coolers (not phenom II coolers). so they good for 2 core + L3 cache or 4 cores without L3 cache. when you turn all 4 cores + L3 cache. the coolers is found ineffective to cool the extra cores, resulting in higher temperature. it isn't dangerous. but not good in long run. if you able cool the processor, its good.
now many times if cores doesn't unlock you can try adding .1V extra. or maybe 0.05V extra. this may result in stable unlock (unlock is guarantee, stability is the issue).
hope all your questions were answered. if not, don't hesitate to ask
