17-06-2010, 10:00 AM
ive got 65 k to blow on a new PC
im finally upgrading from my Jurassic amd athlon xp ,ive got 65 grand but apart from the speakers (altec lansing vs4121 ,which has served me faithfully for the past 30 months ) i need everything ....i did visit my favorite shop in sp road ,bangalore recently ........ this is what i got
COMPONENTS PRICE
core i5 750 ....................... 9700***
corsair vx450...................... 3500***
2*2gb ddr3 1333 kingston......5100
seagate 500gb 7200.11 .........1900
coolermaster 690...................4000
benq e2400..........................12400
lg h55n DVD writer.................1050
logitech keb/mouse ................1250
sapphier HD radeon 5850..........15850***
sennheiser hd 201...................1500
apc 550 w ups........................1900
biostar tpower i55 ...................?????***
tv card ..................................?????
TOTAL______________________58150
NOW my questions
1) what is the market price of biostar tpower i55 AND a decent tv card ???
2) im using the PC for some mid level gaming ----1-2 hours each day for gaming + 2-3 hours for internet and photoshop so
A) is the core i5 ,RADEOON HD 5850 an over kill for my requierments and should i go for AMD PHENOM X4 and a lower spec. graphics card
B) is the power supply, ups enough for this above config ????
3) the components having a *** means im not sure about them
for the monitor is the benq 2400 better or 2420 ...im not sure about it but i need a 24 inch monitor
and i want it to be future proof for atleast 3 years
thank you all suggestions are welcome
---------- Post added at 10:00 AM ---------- Previous post was at 09:46 AM ----------
1. What is your MAX budget?
65,000 INR
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
Definitely.
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
> lots Gaming at medium resolutions .
> photoshop ...i am gonna join some classes ,and maybe some basic animation too
4. Planning to overclock?
no want to run on stock settings
> Windows 7
> and some flavor of Linux just to fool around a bit.
> 500 GB ... 1 TB is not necessary for now ....if needed later ill add another 500GB latr
7. What resolution will the screen run at?
currently 1024 X 768 ..I ve got used to it ...so i think it will stay
> 7
ive built desktops before i will be building this one too
> Within this month
> nothings future proof but if this serves me well for the next 3 years ill be happy
speakers
> Bangalore; and prefer Bangalore
i need a tv card badly and i have no knowledge in that dept.
i5 or i7 or phenom x6????? THIS IS A MAJOR HEADACHE
17-06-2010, 10:12 AM
Re: ive got 65 k to blow on a new PC
That monitor is full HD, so you can easily use a resolution of 1920 x 1080. There is no reason to use such a low resolution as 1024 x 768 in today's times. It doesn't take anything to get used to, I shifted from 800 x 600 resolution to 1600 x 900 resolution after using the former for more than 5 years.
17-06-2010, 11:10 AM
i would recommend these -
Core i5 750 2.66GHz @ 9.5k
MSI P55-GD65 @ 8.2k
Kingston 2 * 2GB 1333MHz @ 5.2k
Sapphire HD5850 1GB GDDR5 @ 15.8k
Western Digital Caviar Blue 500GB @ 2k
LG H55N @ 1.1k
Corsair VX550W @ 4.7k
NZXT Gamma @ 2k
AOC 2236Vw 22" FULL HD LCD Monitor @ 8.7k
Logitech MX518 @ 1.3k
Logitech multimedia @ 0.4k
Sennheiser HD 201 @ 1.5k
Total - 60.4k
rest on a ups and tv card. others suggest please
17-06-2010, 11:31 AM
+1. yes. go for HD resolution. 1024X768 is old now with todays standards.
MSI P55-GD65 @ 8.2k
LG H55N @ 1.1k
NZXT Gamma @ 2k
Total - 60.4k
better go for Dell or Benq. also for UPS, go for a 800VA or 1100VA UPS from APC. cause if he into Photoshop works, it'll need some backup. also that rig will draw quite a bit of power.
17-06-2010, 11:49 AM
i dont know much about monitors. this AOC one was recommended by digit...
17-06-2010, 12:07 PM
laborare est orare
The AOC one is a very good monitor at the price point and performance is alos very good. I', using the 19" AOC for long time. Only downside is, it is not glossy.
Also you can go for the BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k.
It is also a very good monitor and got the best buy award by DIGIT in some recent Edition.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
17-06-2010, 01:11 PM
hello veterans dont get offended but op wants 3 year future proofing .
why didnt you point out that lynnfield is gonna die after 7-8 moths .
and bloomfield wil die next august.?
if hes desperate , bloomfields the way to go for isnt it.
or maybe buy a dell laptop with that humougous budget and postpone the rig till march.
if a desktop should be bought ,then ill go with the above confg.
though i would look for benq g2220 hd for 7.5k as cilus said.
and if u are really get into animation.
i would suggest dell 2209wa e-Ips panel which will cost you around 15k
if you dont get a deall
go for e2200hd for 12k it has hdmi too.
17-06-2010, 01:36 PM
cause buddy. nowadays technology evolve so fast. futureproof word should be avoided. theres nothing futureproof now. this winter AMD Souther islands coming. successor to AMD evergreen family of GPUs. so. if you though HD5*** was futureproof, ask yourself now.
getting back to your question, i5 750 & the likewise processors enough powerful to go for about 3-4yrs. and if they feel slow OC them. they are highly OverClockable.
its best to ask your pocket
~9k
17-06-2010, 02:01 PM
No one can predict what will be happening one year from now, so 3 years is too long a time. However, if you talk future proof only from performance point of view, I think a HD5850 will be able to run games 3 years from now (at least at moderate settings).
And if you feel you will be uncomfortable with high resolutions, go for a 24" full HD monitor so that text (and other things) don't look too small.
Also if you use photoshop for professional purpose, get an IPS panel, otherwise Tn Panels are OK.
17-06-2010, 02:27 PM
yup i knew from the time cypress started crunching that whole radeon 5000 is a wip for 6000.
though a bit of dissapoointment sothern islands has been pushed back and only the
entry level 5400 and 5600 series are being replaced by caicos and turks by end of year.
dont know even thats goona come.
ya but if its lynnfield why not 860? its well within the budget.
and bloomfield will cost max 2k over his budget , but thats for OP's to decide.
860 will make the total go up buy 4.3k i.e. 64.7k.
if he chooses benq g2220 hd hell save 1.2k = 63.5k
cool buddy also says ips , so how good was my ips suggestion?
17-06-2010, 02:31 PM
laborare est orare
ctually aby geek is right, at least in some extent. Intel has a very bad reputation of backward compatibility. Whenever they release something new, they make sure it won't be supported in any of thheir old system. So for upgrading, probably you have to go for an extensive upgrade, which may not lead to a high performance upgrade all the time.
If you want something future proof, then AMD is much suggested as they have an excellent record of backward compatibility. Their AM3 processors are supported in AM2+ and even in the old AM2 motherboards.
And they have already cleared that their upcoming 32nm X6 processors can be used with current gen AM3 borads (7XX and 8XX chipset).
So I am suggesting an AMD config also. May be gaming it will be a little behind the Core i5 750, but will be far more future proof.
Here goes the suggestion
Phenom II X6 1055T 2.8GHz @ 9.6k
Biostar TA890GXE @ 6.6k
Kingston 2 X 2 GB 1333 MHz DDR3 @ 5.4k
SeaGate 1 TB (32 MB Cache) @ 4k
Cooler Master GX-650W @ 5.5k
Zebronics Reaper or NXT Gama without SMPS @ 2k (approx)
Keyboard And Mouse @ your choice @ 1k
PowerColour HD5870 1GB GDDR5 @ 24k
Total is 65.6k. In most of the cases you will get street price lower than the mentioned. So better opt for it.
Reason:
1. Gaming: Although 1055T is not as good as Core i5 750 in gaming, you can now accomodate an HD 5870 and 1055T+HD 5870 is better than HD i5 750 + HD 5870.
2. Multitasking: In multi tasking and multi threaded applications, X6 is having an advantage due to its extra 2 cores
3. Most Important Futureproof: It is far futureproof than any intel based solution as AMD's upcoming processors will fit in the 890 Chipset without any complain. So future upgrade for next 2 Yr I think won't be any problem
4. Features: AMD always offer better feature set than Intel. You will have SATA 3 and USB 3
---------- Post added at 02:31 PM ---------- Previous post was at 02:30 PM ----------
17-06-2010, 02:46 PM
this one reason Intel launches a new platform for ever new processor generation. cause previous platforms can act as bottlenecks.
is it really so? than it'll be great. though i feel the APU wll require new motherboard.
1. Gaming: Although 1055T is not as good as Core i5 750 in gaming, you can now accomodate an HD 5870 and 1055T+HD 5870 is better than i5 750 + HD 5870.
you mean to say i5 750 + HD5850, maybe.
17-06-2010, 03:02 PM
thank you guys ....i think AMD is the way to go ...ive been using mine for the last 6 years and still works like a charm
so i will get a 1055t then ,please sugest a good board and a card to go with it
will a 550 W psu be enough ? ...if i get these things right i can manage the rest
...and what is the news about sata 3 and usb 3.0 ???
---------- Post added at 03:02 PM ---------- Previous post was at 03:00 PM ----------
thank you mate i think it wont be a problem :-P
17-06-2010, 03:14 PM
am3+(am3r2) will be released with bulldozer . the r2 chips will work in r1 but with some features disabled.
so no wories i think a 890 based board is gonna go long way.
in the end it comes down to the vendor writing the bios .
smack them hard on the back of the neck if they waste your money.
17-06-2010, 03:18 PM
get a board based on 880G or 870X if you don't require CrossfireX (2X HD5870 in Xfire  )
for crossfire, look out of 890GX based board (though Biostar's 890GX don't have crossfire).
about PSU, 550W can handle. though i'll suggest go with a 650W from Corsair or Cooler Masters GX series.
both will take time to become mainstream. cause conventional HDDs not fast enough. also USB 3.0 external HDDs & pen drives damn costly.
17-06-2010, 03:24 PM
laborare est orare
The Biostar motherboard I suggested is already having SATA 3. Read the detail specification here. You can add Add-On Cards released by ASUS, Via etc as less as $30 to add USB 3 functionality.
I already suggested PowerColour HD5870 1GB GDDR5 @ 24k. The most powerful single GPU card from ATI and when overclocked, easily match the Nvidia GEforce 480.
The power requirement for HD 5870 is little high. So I mentioned the 650W PSU, to be at safe side. If you go with HD 5850, then the Corsair VX550W @ 4.7k will be sufficient.
17-06-2010, 03:25 PM
chances are the onboard memory controller won't work or the Northbridge will be turned off (provided the chips ships with inbuilt graphics).
 OP will go to Taiwan to kick Biostars a**
17-06-2010, 03:47 PM
@ cilius thank you dude  ill stick with 5850 HD ,550W PSU
@ aby geek ,sam.shab LOL
and anyone with some know how about tv cards ????
---------- Post added at 03:47 PM ---------- Previous post was at 03:38 PM ----------
and guys i saw this recently there are 2 1055t prossys
Phenom IIX6 1055T(HDT55TFBK6DGR),2.8GHz,125W,rev.E0
Phenom IIX6 1055T(HDT55TWFK6DGR),2.8GHz,95W,rev.E0
what is the difference between 95W and 125W version
17-06-2010, 05:22 PM
#19 (permalink)
the 95W version coming Q3-Q4 2010. it maybe available, not sure but AMD will lower TDP to 95W & maybe stepping to E1 or E2.
17-06-2010, 06:08 PM
#20 (permalink)
laborare est orare
I think you mean TV Tuner card. Well it basically lets you watch TV in your PC. You need to connect it to your Cable service provider.
It can be internal, need to plugged it to your PCI or PCI E (for the new ones) slot or External, connected to your PC via USB.
The simple ones, priced within 1k, only let you watch TV, but the advanced versions let you watch TV, records TV show, Live TV Pause, Schedule Recording etc. Normally you can connect any kind of analogue sorces to it like your old VCR/VCD, miniDV(digital) and Hi-8 handy-cams to it and record the data in your computer.
Most of them save data in MPEG1/MPEG2 and MPEG4 (Mpeg 4 ASP or Divx/Xvid) format, but the new ones let you save in H264 or Mpeg4 AVC format, which means gr8 quality in less size.
Avermedia AverTV Super M733 PCI TV Tuner Card is a very good card to start with. Priced at 1.3k, it supports almost all the features mentioned above. Check the details here.
17-06-2010, 06:40 PM
#21 (permalink)
@ sam lol he could launch our exclusive SAM missile with the extreme edition cool buddy chip.  biostar will have to make a new socket for thre behind to fit anywhee if that hits them.
cmng back to the topic
northbridge will be completely removed from the mother board , that is the fusion platform.its cpu plus gpu. and the gpu will handle floating point units now.
and yes am3r is to support quad channel memory and the family is called llano.
its more of like phenom II deneb. its not on buldozer core.
17-06-2010, 07:04 PM
#22 (permalink)
laborare est orare
I think Aby geek is right. I made a mistake while saying current gen AMD mobos will support 32 nm Llano will be needing a new motherboard chip-set. It is predicted in Andnatech and Tomshardware.
But still AMD based solution is better future proof than the Intel based one.
17-06-2010, 07:27 PM
#23 (permalink)
theres a missing link cilus , the 32nm x6 which are due this year they am a lil sure will support AM3 , coz no ones a fool to launch a new socket at the end of the year just for fun.
though i am loving the idea of 4/8-core zambezi based on buldozer.by the way APU is accelerated processing unit , few tech sites and blogs are writing it wrong.
cilus any way i dont think chiroo can wait till march or even jan for that matter.
the only thing wrong with soon to be replace (STR) lineups they wil run for 3 years no doubt i dont think a lynnfield will be replaced after april or blomfiel after december
2011 if prob occurs.
and i dont believe intel will handout equivalent sandy bridges for compensation.
aah and there was somethng i hard about clarkdales going to servers and workstations.
17-06-2010, 08:49 PM
#24 (permalink)
I think people are confusing between futureproof and compatibility. Future proof means you PC should able to the run the games/programs that would be available in future. It doesn't mean it would require lesser hardware upgrades, to move to the latest technology.
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
17-06-2010, 09:03 PM
#25 (permalink)
pulsar what about that portion of the consumer who have heart attack after hearing "u got obsolete pc dude"
just for those who want exclusive bragging rights. i thought that way.
though you are absolutely right , but phasing out of a product line gradually kills service for it too.
though its negligiable in most cases , but sometimes its a big boulder.
17-06-2010, 09:09 PM
#26 (permalink)
for the price given the core i5 rig rocks at gaming. One can OC it easily to close to 4Ghz, when the need arises.
17-06-2010, 09:39 PM
#27 (permalink)
where you came to know Llano will support quad memory channel?
& yes. that bit of info right. the first APU will be based on Phenom II architecture, maybe shrinking it to 32nm.
any link to that 32nm 6 cores coming this year? i doubt.
also its actually a 4core. OS see it as 8 cores. its much more efficient than Intel stupid HT.
not much in case of processors, but graphics cards & motherboards it matters a lot. but also as motherboard matters so its directly related to processors too. forcing upgrade both.
i5 750 can be OC to 4.5Ghz with a good cooler.
17-06-2010, 11:53 PM
#28 (permalink)
AMD Game Forums - Bulldozer CPU will require new socket?
sam here these people are discussing about the new ssocket , though i did not mean to imply that llano is final with quad channle , but these guys say amd is skiping tripple channel and it will eitthere be quad or double.
and since am3r is for llano i think quad may be true.
though its most possible quad will be exclusive to 12 core opterons "morellano"
pulsar no qualms about the abv confg , jaskanwar never dissapoints.
but seriously why not these :
core i7 860 + msi p55 gd65 : increses total by 4.3k i.e 64.7 (well within budget.)
core i7 930 +msi x58 pro : 13.9k+10.8k +42.7k = 67400
and if opting for benq g2220 hd , then 1200 bucks more are saved .
so 860 setup comes out to 63.5k and 930 setup will be 66200.
i was just quiet curious and surprised to see why didnt sam and jaskanwar suggest it.
though, i think i got their point now.
its that buy most affordable now so that ur heart doesnt flinch throwing it away for sandybridge.
so now op can see his upgradation span , if it is to be huge then amd if its moderate then intel.
i hope iam right now?
sorry about the confusion sam theres no 32 nm x6 but actually thuban based x4's. wch are for q3 2010.
and heres al clarif ication for the lineup.
http://en.wikipedia.org/wiki/List_of...icroprocessors
18-06-2010, 12:33 AM
#29 (permalink)
for now its best to take that quad memory ch as a grain of salt. cause i7, its powerful enough & can handle 3 memory channels. so it got. now quad channels will need a even powerful proccy (to utilize it fully). else it may turn out to be like a 9500GT with 2Gb DDR2 memory.
yes, i agree with the second part. quad memory should be according to me limited to Magny Cours's successor. cause desktop can't utilize 2Gb memory well. what will peoples do with 4X1Gb or say 4X2Gb
about the Core i7 860 thing, i not so good on the Intel side. so not suggested. with a hell lot of combinations, i'll end up getting more confused than OP
---------- Post added at 12:33 AM ---------- Previous post was at 12:25 AM ----------
as i thought. 32nms will take sometime to appear. & a 32nm X5 in 2010. its almost impossible for AMD.
18-06-2010, 01:07 AM
#30 (permalink)
lol i manged to make a veteran dizzy. maybe amd should launch me in q4 2010.
intel will have to sell potato chips then.
