Old 17-06-2010, 08:18 AM   #1 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Retention Module Base Query
One of my friends gone crazy and and broke the Retention Module Base of his Asus m3a78-em which is not under warranty. Is there any way to replace it? where can one find that awkward square frame?
Thanks.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 17-06-2010, 10:10 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Retention Module Base Query
What is a retention module..?
asingh is online now   Reply With Quote
Old 17-06-2010, 03:08 PM   #3 (permalink)
AJJU
azzu's Avatar
[URL=http://img3.imageshack.us/i/zalmancnps9500am2am24.jpg/]
guys plz where can i buy it ???
or can i get any am+2 Coolers (HSF ) with screw systems ???
I love and Live to Design
azzu is offline   Reply With Quote
Old 18-06-2010, 08:30 AM   #4 (permalink)
AJJU
azzu's Avatar
btw : thx vamci anna for posting this thread
and guys plzz help
Old 18-06-2010, 10:20 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Tell him to buy a cheap OEM HSF, or else if someone here has removed that spacer to deploy another OEM, they could ship it too him.
Old 18-06-2010, 02:23 PM   #6 (permalink)
AJJU
azzu's Avatar
i didnt get u .
does cheap oem HSF comes with a Retention module ??
BTw : its me who broke his Retention module
Old 18-06-2010, 03:17 PM   #7 (permalink)
Originally Posted by azzu View Post
i didnt get u .
they don't. you simply need to get a CM TX3 for 1.3k. as the retention module already gone (thanks to you), simply bolt down the HSF with the provided backplate. done.
offtopic: what were you trying do with a retention module? click pictures with your Micromax Q5?
Old 18-06-2010, 07:57 PM   #8 (permalink)
AJJU
azzu's Avatar
Found a guy selling Retention modules on Ebay will order from there
but , iam also interested in CM tx3 , anything cheaper than that available ? lol
and will it run on my ordinary 450wts PSU ( the usual zebronics one)
BTw : sam bhai i swear i didnt doo anything i was observing insane temps on Hw monitor and i opened the Cabinet and bamm HSf's off the proccy
but thank god proccy didnt fired up
Old 18-06-2010, 08:33 PM   #9 (permalink)
TX3 is a heatsink with a fan. i don't see any reason to not run on a working PSU. its just a substitute for an Intel or AMD HSF.
WHAT? you opened the cabinet & HSF came out? chances are the retention module's base got loose from the motherboard. but usually its bolted down with a steel backplate. maybe got loose. and thats the reason of the high temperature. cause heatsinks base isn't touching the processor.
and yes, your friend lucky, the processor didn't melted
Old 18-06-2010, 09:57 PM   #10 (permalink)
Super Moderator
asingh's Avatar
i didnt get u .
The retention module is part of the board.
Old 19-06-2010, 12:13 PM   #11 (permalink)
AJJU
azzu's Avatar
It was already Broken .. but when i opened i saaw the HSF was hanging with the HSF Power cable ..
and bolts everything where fine the hanger or clip ,, u can see from the Image broke..
Uploaded with ImageShack.us
Old 19-06-2010, 12:22 PM   #12 (permalink)
and that way the PC was running?
BTW what insane temperature were being displayed in HW monitor?
Old 19-06-2010, 01:19 PM   #13 (permalink)
AJJU
azzu's Avatar
not insane actually.. 50-55c
while my proccy idle's at 25-30
sam bhai ..
do u have a yahoo id ?
Old 19-06-2010, 04:06 PM   #14 (permalink)
sam bhai ..
is that temp while the PC idles? if yes, than in load it'll shoot past 100degree.
yes i got. will PM u.
Old 21-06-2010, 08:49 PM   #15 (permalink)
AJJU
azzu's Avatar
guys
iam gonna buy a Cooler master tx3 tommorow,
Any suggestions of , Screw cpu air coolers other than that ?
Old 21-06-2010, 09:22 PM   #16 (permalink)
Super Moderator
asingh's Avatar
CM Hyper 212 is decent. Bolt down.
Old 21-06-2010, 09:47 PM   #17 (permalink)
AJJU
azzu's Avatar
wats the cost ???
and wat about its availability in Hyderabad ?
Old 21-06-2010, 11:40 PM   #18 (permalink)
Super Moderator
asingh's Avatar
It would be around 1.8K. Do ask if they include the AMD socket back plates.
Old 26-06-2010, 05:32 PM   #19 (permalink)
AJJU
azzu's Avatar
Got the CM tx3 at 1.3k from CTC Hyderabad up and working
cpu idling at 18-19 C and max 28-29 c in load
at 25 c room temperature
Thx all the guys who helped me out
Sam.sahab , Asigh , and vamci anna vvv thx )
One Giant Command Line MetalheadGautham Open Source 23 24-05-2008 02:31 AM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
VIA UniChrome Pro Display Driver ver 0.8 gary4gar Open Source 19 22-12-2007 02:09 PM
Extensions and Their Definitions Sparsh007 QnA (read only) 3 28-11-2006 07:25 PM
Nvidia driver error. kalpik Open Source 2 25-06-2006 08:26 AM
