Old 16-06-2010, 01:55 PM   #1 (permalink)
change is constant!!
khmadhu's Avatar
Question USB dvd Drive with WD live Tv
Hi All,
I wanted to buy WD live tv. since its not having inbuilt DVD player, can I use external usb DVD Drive ,and attach it to the WD live USB port..? will this setup allows me to play DVD and other video formats which are in DVD.?
I already have USB DVD Drive. so don't want to go for new DVD Player..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 16-06-2010, 05:15 PM   #2 (permalink)
Default Re: USB dvd Drive with WD live Tv
Yes, it can do it.
You need to mod it.
PraKs is offline   Reply With Quote
Old 16-06-2010, 05:52 PM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
other alternative is to create DVD ISO and play it using WD Live. WD playes DVD ISOs with full DVD menus just like its playing the actual DVD through a DVD drive....
sam9s is offline   Reply With Quote
Old 17-06-2010, 02:38 PM   #4 (permalink)
khmadhu's Avatar
@sam9s i know WD wil play DVD Iso's but, but i have lots of DVD's so every time i cannot make iso.. waste of time and space..
i just want to know whether it needs and converter or tweaking or just if i plug USB DVD writer into WD's USB port is enough..?
has anyone tried..?
Old 17-06-2010, 09:55 PM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
Well I am not sure about WD Live but with WD TV you can connect DVD drive BUT with a hacked firmware, though I have never tried this as I also have AC Ryan POHD with which I can connect a DVD drive officially (if I have to - again never felt the need to as I also have a Philips DVP5500 DVD player and a Bluray Player). BTW If you have more DVDs than rips, I'd say invest on a decent DVD player rather than this.
Old 18-06-2010, 12:39 AM   #6 (permalink)
@OP
Just hack firmware of WDTV Live, connect external DVD ROM & play
Latest Hardware Prices & Quotes..!! suave_guy Hardware Q&A 5604 14-03-2011 02:05 PM
DVD drive doesn't play Digit DVDs meetdenis Hardware Q&A 5 23-04-2010 09:33 PM
How to Install Windows ISO File via USB Gauravs90 Tutorials 3 20-03-2010 12:43 PM
